cemzafer Posted August 6 Posted August 6 Hi, I'm looking a newer armbian iso image which contains those futures. Is there any link? I'm going to test on Turing RK1 (RK3588) machine. Regards. 0 Quote
laibsch Posted August 6 Posted August 6 1 hour ago, cemzafer said: Turing RK1 I don't see any images for download from Armbian for the Turing RK1. But the turing-rk1 board definition exists. Your best bet is to compile your own image. 0 Quote
cemzafer Posted August 6 Author Posted August 6 Thanks @laibsch, that is wonderful. Appreciate your help. Regards. 0 Quote
cemzafer Posted August 6 Author Posted August 6 (edited) I have tried ./compile.sh script and find the Turing RK1 model, but in this configuration it does not contain NPU driver. Do you have any idea how to enable NPU option to compile the newer image? Regards. Edited August 6 by cemzafer 0 Quote
Werner Posted August 7 Posted August 7 vendor kernel has rknpu enabled by default. edge will receive initial support for it (called Rocket then) with 6.17 iirc. 1 Quote
cemzafer Posted August 7 Author Posted August 7 Thanks @Werner for the clarification. Regards. 0 Quote
