Ducdanh Nguyen Posted 11 hours ago Author Posted 11 hours ago @Nick A based on chatgpt with website research, it depends on with box meaning that mine still have a h313, its cortex a53. 64 bit, then what is it? (I can give you more proof that mine is allwinner h313) 0 Quote
Ducdanh Nguyen Posted 5 hours ago Author Posted 5 hours ago Do you mean gpu model? Like mail-g31? 0 Quote
Nick A Posted 3 hours ago Posted 3 hours ago (edited) @Ducdanh Nguyen Yes does it tell you in android Google Ai: To find your Android device's GPU, download a hardware info app like Dev Check from the Google Play Store, go to Settings > About Phone > Hardware Information (though this is less reliable on some Android versions), or use developer tools like Android GPU Inspector (AGI) for detailed profiling. Edited 3 hours ago by Nick A 0 Quote
SteeMan Posted 3 hours ago Posted 3 hours ago 8 hours ago, Ducdanh Nguyen said: its cortex a53 There are probably 20 different CPUs that have cortex a53 (cpus from Allwinner, Rockchip and Amlogic). TV box manufacturers all the time will use different CPUs in TV boxes that have the same external markings. Which ever component is the cheapest at the time of manufacture is what gets used. The only way to really be sure what you have is to look at the chip on the board (but even then there are cases where chip markings have been altered to make you think you have something else). Welcome to the world of TV boxes (and why Armbian doesn't support them officially because they are a mess). 0 Quote
SteeMan Posted 3 hours ago Posted 3 hours ago A google search indicates that the MXQ Pro 4K 5G often uses a RK3229 quad-core CPU 0 Quote
