Ducdanh Nguyen Posted September 2 Author Posted September 2 @Nick A based on chatgpt with website research, it depends on with box meaning that mine still have a h313, its cortex a53. 64 bit, then what is it? (I can give you more proof that mine is allwinner h313) 0 Quote
Ducdanh Nguyen Posted September 2 Author Posted September 2 Do you mean gpu model? Like mail-g31? 0 Quote
Nick A Posted September 2 Posted September 2 (edited) @Ducdanh Nguyen Yes does it tell you in android Google Ai: To find your Android device's GPU, download a hardware info app like Dev Check from the Google Play Store, go to Settings > About Phone > Hardware Information (though this is less reliable on some Android versions), or use developer tools like Android GPU Inspector (AGI) for detailed profiling. Edited September 2 by Nick A 0 Quote
SteeMan Posted September 2 Posted September 2 8 hours ago, Ducdanh Nguyen said: its cortex a53 There are probably 20 different CPUs that have cortex a53 (cpus from Allwinner, Rockchip and Amlogic). TV box manufacturers all the time will use different CPUs in TV boxes that have the same external markings. Which ever component is the cheapest at the time of manufacture is what gets used. The only way to really be sure what you have is to look at the chip on the board (but even then there are cases where chip markings have been altered to make you think you have something else). Welcome to the world of TV boxes (and why Armbian doesn't support them officially because they are a mess). 1 Quote
SteeMan Posted September 2 Posted September 2 A google search indicates that the MXQ Pro 4K 5G often uses a RK3229 quad-core CPU 1 Quote
Ducdanh Nguyen Posted September 3 Author Posted September 3 @SteeMani also did some commands prompted by chatgpt since it said it was manufactored by allwinner also related to cortex-a53, aida64 said it too, so i doubt that mine are using a allwinner h313 chip 0 Quote
Ducdanh Nguyen Posted September 7 Author Posted September 7 Hello @Nick A i was busy on school and my cable is delivered, i was able to use adb. Could you show me how to dunp the boot.img? @SteeMan, My box is fake and it is allwinner h313, is in 32 bit mode 0 Quote
Sergey Lepeshkin Posted September 8 Posted September 8 Hi! @Ducdanh Nguyen , which port have you used to connect it through adb? Those on the back side (where hdmi and power connectors located), or one of those on the right side (where sd card slot located)? Was it working in standard Android boot mode ("Debug over usb" enabled through "Developer settings") or somehow else? I also own such tv box and this is what I've found crawling web and playing with this device: 1. More PCB pics is here: https://4pda.to/forum/index.php?showtopic=1016510&view=findpost&p=136516719 2. "Heatsink" (just a small piece of thick aluminium foil) is bonded to SoC using 2-sided adhesive tape (I doubt it have good thermal conductivity). I recommend to replace it with more adequate heatsink. 3. SoC seems to be fake. It doesn't have Allwinner logo on it (there are 2 pics attached: one is ours, and one is genuine). 4. There is no AXP PMIC. Instead, there are 3 separate fixed step down converters. 5. There is no transformer in ethernet circuitry! Signals from jack goes directly to SoC. So be careful with static electricity while handling it's ethernet connection. 6. First button, located near "AV" jack, just resets tv box to factory defaults (if power switched on while it's pressed - and after that "update" screen with Chinese text on it will be shown). Purpose of second button (located near "S/PDIF" jack) is mystery for me. Can anyone suppose what it is for? 7. There are two exposed test points on the bottom side of pcb under SoC. Both tied through 10k resistors to +3.3V. After power-on, one of them seems to be some input (current between pin and gnd is about 3.3/10000=0.33mA), and other is definitely driven by something else (current is about 14mA and varying in both directions). I wonder if it's uart tx and rx pins - I'll see it with oscilloscope later. Anyway, shorting this test points together doesn't influence on boot process. 8. It's highly probable there is some backdoor (something like well-known Badbox 2.0). Original firmware exhibits some suspicious network behavior: just after factory reset, once it connected to network, it opens different connections to tcp port 12000 to hosts located in China. If I close outgoing traffic on firewall to tcp port 12000, after a while, it opens similar connections, but to port 9090 to different hosts. It seems to me it's trying to join some botnet. Furthermore, if you compare process list just after first (after factory reset) connection to network, and after it been connected for a while, you will find some new processes, which doesn't belong to Android and have strange names - I think it downloads something without asking user. Summary: this cheap tv box is a full scam. It seems to me manufacturer made all to prevent re-flashing of this device. But it will be very interesting to make something useful out of it. 0 Quote
Sergey Lepeshkin Posted September 8 Posted September 8 (edited) I've managed to pull out some system files out of it. Binaries is ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), so its not Allwinner H313. Edited September 8 by Сергей Лепёшкин 0 Quote
Ducdanh Nguyen Posted September 8 Author Posted September 8 @Sergey LepeshkinThank you, is there anyway to get it out and reveal the cpu (may fake, but worth trying) Also, i don't even know why they put a fake update screen on a fake tv box but i found a guy with same problem on me : I don't know what to do, my box does have the usb debugging and i will try to debug it 0 Quote
Sergey Lepeshkin Posted September 8 Posted September 8 1 hour ago, Ducdanh Nguyen said: found a guy with same problem No, he's problem is much more simpler. He have JTAG and UART wired on his board, so it's not a problem to do virtually anything with his box. 1 hour ago, Ducdanh Nguyen said: my box does have the usb debugging Are you sure? Have you successfully connected adb on PC to this tv box using usb cable? 1 Quote
Ducdanh Nguyen Posted September 8 Author Posted September 8 @Sergey LepeshkinThanks! But i mean the reset button, but i will try since i dont have time and on school 0 Quote
Sergey Lepeshkin Posted September 9 Posted September 9 So i have found what's we dealing with: it is HiSilicon hi3798mv310. See attached proc_version and config.gz. Furthermore, I've installed eset nod32 antivirus on this box and it found some suspicious apps (see photo). I will send them to eset for more thorough analysis. Overall this news is "Not great, not terrible". @Ducdanh Nguyen, I think there is no pre-built armbian or other linux distro images for this chip. I did a brief google search and found only this SDK: https://github.com/JasonFreeLab/HiSTBLinuxV100R005C00SPC050 As it seems to me, you can compile it and get some clean linux for this box. Let us know if it works. BTW, author of this SDK recommend to burn it using HiTool. But HiTool uses UART (only?) to interact with chip, and we don't have UART wired on our board. There are seems to be option to upgrade it from usb flash, but how will this work - idk... Also, here is related discussion: What about debugging by usb - either through enabling Android "Debug over usb" function or booting with reset button pushed - I doubt it will work. Nevertheless, this tv box is usable for its direct purpose. All that should be done, is replacing heatsink and changing firmware to trusted one (without any trojans and viruses). BTW, funny fact: hi3798mv310 have only 3 USB interfaces, but on our board there are 4 USB connectors. LOL! I'm wondering if there any scam museum in the world? If any, this box will be a very interesting piece for them. config.gz proc_version 0 Quote
Sergey Lepeshkin Posted September 9 Posted September 9 @Ducdanh Nguyen, can you contact seller of your tv box and ask if they can provide firmware (or "firmware update") for it? 0 Quote
Sergey Lepeshkin Posted September 19 Posted September 19 If someone interested on this tv box: I've managed to download original firmware image (update.zip) from backup partition. Also I cleaned it from malware (at least I think so) and packed as modified update.zip. Files are located here: https://drive.google.com/drive/folders/1etPmH8ZG4UtPHI3Vf1U9MUHl5_gK_s-E Further info available here (in Russian): https://4pda.to/forum/index.php?showtopic=1016510&view=findpost&p=139209499 1 Quote
Gallahad Posted Tuesday at 03:13 PM Posted Tuesday at 03:13 PM i too am facing this problem, i bought this box for round 1500 inr with armbian in mind i thought it would be h3 but it was h313 and then i also noticed that the fonts looked different on the soc, well here i am. the main purpose for this purchase was installing armbian to run home assistant server but that aint gonna happen and raspberry pi's and other alternatives are too expensive still not what i bought it for but yeah gotta live with it now btw any updates on this 1 Quote
Sergey Lepeshkin Posted Wednesday at 05:28 AM Posted Wednesday at 05:28 AM Yes, there are some updates. First of all I've found two uart interfaces. See attached photos. Two test points located on the bottom side of pcb is for SoC uart, and two near wifi interface is for TXW901 uart. Tx and Rx as on attached pics. Furthermore, AFAIR, powering on while holding SoC Rx low forces SoC to search for bootable usb flash drive. Second is my modified android (not armbian!) firmware v.0.2. You can download it using link in my message above. Changelog also there. Major changes: Google Play is working again, improved wifi stability. Third, there are Linux drivers available for TXW901 (Wifi interface). You can get it here: https://www.taixin-semi.com/Product?prouctSubClass=66 (registration is required, however, all that you need to register is valid e-mail). So, potentially, one could compile armbian image for this box (integrate wifi driver into armbian, obtain memory settings through SoC uart, configure and compile kernel and boot image). 0 Quote
Ducdanh Nguyen Posted 23 hours ago Author Posted 23 hours ago (edited) @Sergey Lepeshkin HOLYthat was the same color, same board layout i think mine is the same as you Btw im busy from school and my phone broke, it was a long time since… Also im not really into soldering can i use a electrical tape instead?? Edit : i have checked the modified version of the file, and the os, all the malwares are on my box i think we have the same box. I have a good specs laptop from 2018, it runs well and i can compile the image, the problem is the memory settings since i think we dont have the same ra, chips accord to the 2 years difference of the ram chip on my board Edited 20 hours ago by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted 23 hours ago Author Posted 23 hours ago @Sergey Lepeshkin from the messages, i bought it online and the seller i know him since i bought wires from the shop. I couldnt contact the seller to provide the rom and i think they dont know since they most resell them. Also is it safe to install that file on my box?? Im scared that is going thr brick the box 0 Quote
Sergey Lepeshkin Posted 15 hours ago Posted 15 hours ago @Ducdanh Nguyen, I don't understand how you could use electrical (insulation?) tape to connect to test points... Nevertheless, all you need is a good electrical contact between wires and test points. Means has no matter. Beware: signal levels is 3.3V. Do not connect directly to RS232 interface! What about flashing my modified update.zip - don't worry. It doesn't alter partition table, bootloader and backup partition. If something goes wrong, or you just want original firmware back - just connect power while holding button near "A/V" jack. This will start reflashing using your original update.zip, located in backup partition. If you want to extract your original update.zip from backup partition, simplest way to do this is using uart. Connect uart to pc, boot tv box normally, open serial port on pc (115200/8/n/1), issue 'su' command, mount /backup and copy /backup/update.zip anywhere you want. About laptop - I don't understand, how it's related to this discussion... If you want to compile armbian using it - go ahead. It doesn't matter what cpu architecture or type of memory it uses. All you need is correct toolchain, which suits our tv box SoC. 1 Quote
Ducdanh Nguyen Posted 7 hours ago Author Posted 7 hours ago @Sergey LepeshkinThank you! You made me feel better, i will flash your modified .zip file since i saw 2 partitions on the file manager, that's why Also, i don't have a uart connector and soldering skills, so is running armbian on my atv box impossible??? 0 Quote
Ducdanh Nguyen Posted 7 hours ago Author Posted 7 hours ago @Sergey Lepeshkin i also note that the picture of the tv boxhttps://drive.google.com/drive/folders/1etPmH8ZG4UtPHI3Vf1U9MUHl5_gK_s-E are from diffrent boxes, but the reflash_from_backup.jpg is probalby mine. But i can't access the recovery menu, is there any way? 0 Quote
Sergey Lepeshkin Posted 2 hours ago Posted 2 hours ago @Ducdanh Nguyen, about uart: just find someone with soldering skills - it's deal of 3 minutes to solder 3 wires. Screenshots: all them taken from one tv box. I've found recovery menu only once - when accidentally flashed update.zip with system and vendor partitions taken from other tv box (also HiSilicon-based). After flashing, something went wrong while starting Android, and box automatically rebooted to recovery. 0 Quote
