Fabricio Martínez Tamayo Posted August 24, 2025 Posted August 24, 2025 (edited) Hi, I have attempted to boot with edge and current branches with no success. I am now trying vendor since its what its running. My process is: ./compile.sh BOARD=orangepi5pro BRANCH=current kernel-config I enable tunneling GRE and some broadcom wifi drivers. ./compile.sh BOARD=orangepi5pro BRANCH=current kernel sudo dpkg -i output/debs/linux-image-*.deb sudo dpkg -i output/debs/linux-headers-*.deb sudo dpkg -i output/debs/linux-dtb-*.deb sudo reboot and after this the system does not boot or post through HDMI. I have to go back and erase /boot and restore a backup to be able to get it working again. What am I missing? P.S. I have /boot partition in SD card and the system partition is in an NVME drive. Edited August 24, 2025 by Fabricio Martínez Tamayo 0 Quote
Igor Posted August 24, 2025 Posted August 24, 2025 1 hour ago, Fabricio Martínez Tamayo said: does not boot or post through HDMI. HDMI output might be broken on this kernel - mainline support is still fragile, perhaps for this board there is no device tree yet and it fails early. 1 Quote
The Tall Man Posted August 26, 2025 Posted August 26, 2025 (edited) On 8/24/2025 at 4:46 PM, Igor said: perhaps for this board there is no device tree yet I have a different Orange PI board, but I have two partitiions of Armbian installed (25.8.1), one with the edge kernel, the other with the current (mainline) kernel. I checked my /boot/dtb/rockchip/ directories in each for the Orange PI 5 Pro, and there is a device tree for it with the edge kernel (rk3588s-orangepi-5-pro.dtb), but not with the current kernel. Perhaps a question would be: Is that devicetree (.dtb file) being utilized with the edge kernel? Might be worth looking into. Edited August 26, 2025 by The Tall Man 0 Quote
Igor Posted August 26, 2025 Posted August 26, 2025 2 hours ago, The Tall Man said: but not with the current kernel. Quite possible, actually expected as there is no support for current kernel: https://github.com/armbian/build/blob/main/config/boards/orangepi5pro.csc#L8 and build target is not maintained by core Armbian team https://docs.armbian.com/User-Guide_Board-Support-Rules/#community-maintained 0 Quote
