schunckt Posted September 2, 2025 Posted September 2, 2025 Hi! With latest edge 6.15.4 the board boots fine, shutdown also clean and complete but on reboot it does not again start up. Need to powercycle😒 I gets stuck et end of shutdown. Same for latest bookworm image (I think it's 6.12x). Earlier ones did work. => Any other board also affected? => Is for reboot the watchdog involved? T. 0 Quote
laibsch Posted September 2, 2025 Posted September 2, 2025 probably time for the serial console my suspicion tells me that it will be hard to get proper logs otherwise my suspicion is that some umounts does not come back. <- try to unmount everything you can before the reboot and see if that helps. 0 Quote
Moklev Posted September 30, 2025 Posted September 30, 2025 Quote With latest edge 6.15.4 the board boots fine, shutdown also clean and complete but on reboot it does not again start up. Need to powercycle😒 Fix: run armbian-install, then selected “Install/Update the bootloader on SD card (/dev/mmcblk0)” 0 Quote
