mitu Posted September 7 Posted September 7 I have an Orange Pi 5 board, installed with the 25.8 Debian Bookworm + Cinnamon desktop system. I have switched (using armbian-config) to the edge kernel in order to test the HDMI audio support in the new Linux kernel, but I'm not getting any audio out. The ALSA HDMI card seems to be present (see below), but there's no sound using speaker-test or aplay. Quote $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: hdmi0 [hdmi0], device 0: fddf0000.i2s-i2s-hifi i2s-hifi-0 [fddf0000.i2s-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: rockchipes8388 [rockchip,es8388], device 0: fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 I have enabled the hdmirx overlay through armbian-config also, but the result is the same. Is there anything extra that should be configured in order to get audio output ? Output from armbianmonitor - https://paste.armbian.com/gegorimako 0 Quote
IBV Posted September 7 Posted September 7 Hi, always check with "amixer" (alsa mixer) if your outputs are not muted. 0 Quote
mitu Posted September 7 Author Posted September 7 amixer doesn't show any controls on the first card (and so does alsamixer) - amixer -c 0 shows nothing, while amixer -c 1 has a lot of output, but I think it's just showing the controls for the rockchipes8388 audio card (the analog output, not the HDMI). 0 Quote
Dantes Posted September 7 Posted September 7 On what kernel version are you ? HDMI Audio was introduced in the Linux Kernel in 6.15-rc1 0 Quote
mitu Posted September 7 Author Posted September 7 The kernel version reported by armbianmonitor (see my first post) is 6.16.4-edge-rockchip64. 0 Quote
IBV Posted September 7 Posted September 7 What does "aplay -L" show ? How do you test the HDMI sound ? 0 Quote
mitu Posted September 7 Author Posted September 7 (edited) 4 minutes ago, IBV said: What does "aplay -L" show ? Here's the output, shows PCMs for both the HDMI and analog audio outputs: Quote null Discard all samples (playback) or generate zero samples (capture) lavrate Rate Converter Plugin Using Libav/FFmpeg Library samplerate Rate Converter Plugin Using Samplerate Library speexrate Rate Converter Plugin Using Speex Resampler jack JACK Audio Connection Kit oss Open Sound System pipewire PipeWire Sound Server pulse PulseAudio Sound Server speex Plugin using Speex DSP (resample, agc, denoise, echo, dereverb) upmix Plugin for channel upmix (4,6,8) vdownmix Plugin for channel downmix (stereo) with a simple spacialization default Default ALSA Output (currently PipeWire Media Server) hw:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Direct hardware device without any conversions plughw:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Hardware device with all software conversions sysdefault:CARD=hdmi0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Default Audio Device dmix:CARD=hdmi0,DEV=0 hdmi0, fddf0000.i2s-i2s-hifi i2s-hifi-0 Direct sample mixing device usbstream:CARD=hdmi0 hdmi0 USB Stream Output hw:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Direct hardware device without any conversions plughw:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Hardware device with all software conversions sysdefault:CARD=rockchipes8388 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Default Audio Device dmix:CARD=rockchipes8388,DEV=0 rockchip,es8388, fe480000.i2s-es8328-hifi-analog es8328-hifi-analog-0 Direct sample mixing device usbstream:CARD=rockchipes8388 rockchip,es8388 USB Stream Output > How do you test the HDMI sound ? speaker-test or aplay (with a .wav file). Edited September 7 by mitu 0 Quote
IBV Posted September 7 Posted September 7 1 minute ago, mitu said: speaker-test or aplay (with a .wav file). Sorry I mean Which kind of output device: TV, Monitor with build in speakers? If you try "aplay -D plughw:0,0 your_audio_file.wav", still no sound? 0 Quote
mitu Posted September 7 Author Posted September 7 4 minutes ago, IBV said: 9 minutes ago, mitu said: Sorry I mean Which kind of output device: TV, Monitor with build in speakers? I have a HDMI monitor with speakers included. 4 minutes ago, IBV said: If you try "aplay -D plughw:0,0 your_audio_file.wav", still no sound? Yes. 0 Quote
IBV Posted September 7 Posted September 7 aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 your_audio_file.wav ? this will force a more common audio format (in case the monitor supports specific audio formats. If not working, no idea, hw detection looks ok. 0 Quote
mitu Posted September 7 Author Posted September 7 4 minutes ago, IBV said: aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 your_audio_file.wav ? It doesn't seem to make a difference: Quote aplay -D plughw:0,0 -f S16_LE -r 48000 -c 2 Alesis-Fusion-Nylon-String-Guitar-C4.wav Playing WAVE 'Alesis-Fusion-Nylon-String-Guitar-C4.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo 0 Quote
IBV Posted September 8 Posted September 8 Do you get sound (HDMI) through your monitor speakers with the official vendor image? 0 Quote
mitu Posted September 9 Author Posted September 9 8 hours ago, IBV said: Do you get sound (HDMI) through your monitor speakers with the official vendor image? I haven't tried the vendor image, but I have another SBC (RasPi4) that can succesfully output audio through the monitor speakers, so the monitor is ok. I could re-test the HDMI cable I guess, but since the video signal is ok I don't expect the audio to have issues. 0 Quote
IBV Posted September 9 Posted September 9 I suggest to confirm first that it works with the vendor image, just in case. If you boot the vendor image you could also gather some info, like aplay -L, etc. 0 Quote
mitu Posted September 9 Author Posted September 9 1 hour ago, IBV said: I suggest to confirm first that it works with the vendor image, just in case. I can try it, just to check that the cable/port combo is ok. 1 hour ago, IBV said: f you boot the vendor image you could also gather some info, like aplay -L, etc. I'm not sure how would that help - the reason I'm using the edge kernel is to use the upstream/Linux kernel implementation and the implementation may not be the same as the one provided in the outdated vendor image. 0 Quote
mitu Posted September 9 Author Posted September 9 OK, so I installed the latest Debian/Trixie + Cinnamon + vendor kernel available and audio is working. The name of the cards and mixers are different though: Quote $ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: rockchipdp0 [rockchip-dp0], device 0: rockchip-dp0 spdif-hifi-0 [rockchip-dp0 spdif-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: rockchiphdmi0 [rockchip-hdmi0], device 0: rockchip-hdmi0 i2s-hifi-0 [rockchip-hdmi0 i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 2: rockchipes8388 [rockchip-es8388], device 0: dailink-multicodecs ES8323 HiFi-0 [dailink-multicodecs ES8323 HiFi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 $ aplay -L null Discard all samples (playback) or generate zero samples (capture) default Playback/recording through the PulseAudio sound server lavrate Rate Converter Plugin Using Libav/FFmpeg Library samplerate Rate Converter Plugin Using Samplerate Library speexrate Rate Converter Plugin Using Speex Resampler jack JACK Audio Connection Kit oss Open Sound System pulse PulseAudio Sound Server speex Plugin using Speex DSP (resample, agc, denoise, echo, dereverb) upmix Plugin for channel upmix (4,6,8) vdownmix Plugin for channel downmix (stereo) with a simple spacialization hw:CARD=rockchipdp0,DEV=0 rockchip-dp0, rockchip-dp0 spdif-hifi-0 Direct hardware device without any conversions plughw:CARD=rockchipdp0,DEV=0 rockchip-dp0, rockchip-dp0 spdif-hifi-0 Hardware device with all software conversions sysdefault:CARD=rockchipdp0 rockchip-dp0, rockchip-dp0 spdif-hifi-0 Default Audio Device dmix:CARD=rockchipdp0,DEV=0 rockchip-dp0, rockchip-dp0 spdif-hifi-0 Direct sample mixing device usbstream:CARD=rockchipdp0 rockchip-dp0 USB Stream Output hw:CARD=rockchiphdmi0,DEV=0 rockchip-hdmi0, rockchip-hdmi0 i2s-hifi-0 Direct hardware device without any conversions plughw:CARD=rockchiphdmi0,DEV=0 rockchip-hdmi0, rockchip-hdmi0 i2s-hifi-0 Hardware device with all software conversions sysdefault:CARD=rockchiphdmi0 rockchip-hdmi0, rockchip-hdmi0 i2s-hifi-0 Default Audio Device dmix:CARD=rockchiphdmi0,DEV=0 rockchip-hdmi0, rockchip-hdmi0 i2s-hifi-0 Direct sample mixing device usbstream:CARD=rockchiphdmi0 rockchip-hdmi0 USB Stream Output hw:CARD=rockchipes8388,DEV=0 rockchip-es8388, dailink-multicodecs ES8323 HiFi-0 Direct hardware device without any conversions plughw:CARD=rockchipes8388,DEV=0 rockchip-es8388, dailink-multicodecs ES8323 HiFi-0 Hardware device with all software conversions sysdefault:CARD=rockchipes8388 rockchip-es8388, dailink-multicodecs ES8323 HiFi-0 Default Audio Device dmix:CARD=rockchipes8388,DEV=0 rockchip-es8388, dailink-multicodecs ES8323 HiFi-0 Direct sample mixing device usbstream:CARD=rockchipes8388 rockchip-es8388 USB Stream Output speaker-test worked both by specifying the mixer (... -D plughw:CARD=rockchiphdmi0,DEV=0) or through PulseAudio's ALSA emulation after setting the default sink to the rockchiphdmi0 card. The list of audio cards is different in the vendor kernel than what's available OOB with the edge kernel, so I'm not sure if the configuration is comparable. But the audio port/cable combo seems to be fine so there's that.. 0 Quote
Fredrik Posted October 1 Posted October 1 (edited) Audio out of HDMI works for me out of the box. Kind of. I flashed a kernel 6.15 (that I had lying around) Cinnamon image, because all the recent Gnome images I have fail and just boot to initramfs. I then installed Gnome and enabled Wayland. I then used armbian-config to upgrade the kernel to 6.16 something. Sound test in Gnome settings work. I think this should just work with my kernel 6.15 too iirc. But also I seem to remember having problems when not using Gnome. Edited October 1 by Fredrik 0 Quote
mitu Posted October 2 Author Posted October 2 @Fredrik thank you for the reply. I wonder what's Gnome doing to initialize the audio that's different from a regular (non-graphical) boot. FWIW I installed also Pipewire/Wireplumber and tried to test the audio through the PW ALSA emulation, but that didn't work either. Just out of curiosity, does speaker-test work from the CLI once booted into Gnome or is it just the sound test in Gnome settings that's working ? 0 Quote
Fredrik Posted October 5 Posted October 5 (edited) @mitu I'm not sure how to use that program it only plays white noise but it comes through hdmi. I can also play wav files using aplay on command line. Edited October 5 by Fredrik 0 Quote
