Hello, guys,
may I ask you to fix the code below so that I can put my custom "sun6i.conf" file into "userpatches/sources/" ?
Currently your code makes it impossible because LINUXFAMILY variable is forcibly set to "sunxi" in sunxi_common.inc file.
What you can easily do is introducing a new variable so that one can know that LINUXFAMILY was overwritten.
configuration.sh
[[ ! -f $SRC/config/sources/$LINUXFAMILY.conf ]] && \
        exit_with_error "Sources configuration not found" "$LINUXFAMILY"
source $SRC/config/sources/$LINUXFAMILY.conf
if [[ -f $SRC/userpatches/sources/$LINUXFAMILY.conf ]]; then
        display_alert "Adding user provided $LINUXFAMILY overrides"
        source $SRC/userpatches/sources/$LINUXFAMILY.conf
fi
Thanks
