SoSie Posted 3 hours ago Posted 3 hours ago (edited) Hello all, I succeed to boot on sata usb by seting the UUID of the armbian_root from mmcblk1p1 to sda1 I tested several M2 SSD enclosures both NVME and NGFF most of the time, one in the middle, has a USB Hub and micro SDCARD port. Now if the USB enclosures is not connected, we are stuck in initramfs stage because the UIID partition given in /boot/ArmbianEnv.txt does not exist. I changed the UUID of emmc armbian_root (mmcblk1p1) thinking it would be overmapped with partition of S2 usb enclosure (sda1). It is not the case, it will only boot on emmc , ignoring S2 enclosures when mmcblk1p1 and sda1 shares the same UUID. I suggest USB enclosures should comes in higher boot priority than emmc after a bootable sdcard is present or not, so the end user is not lost in initramfs jungle. Edited 3 hours ago by SoSie Fix 0 Quote
going Posted 2 hours ago Posted 2 hours ago 31 минуту назад, SoSie сказал: It is not the case, it will only boot on emmc , ignoring S2 enclosures when mmcblk1p1 and sda1 shares the same UUID. Each attached memory disk must have its own unique UUID. This is its essence. 37 минут назад, SoSie сказал: I suggest USB enclosures should comes in higher boot priority than emmc after a bootable sdcard is present or not This depends on the platform (BROM bootloader flashed into the chip) and possibly the switch soldered to the board. 0 Quote
