mjc Posted October 26, 2017 Posted October 26, 2017 Hi Guys, I buy me in LCD-Display (BL035-RGB). This will be connect to my Banana PRO. All this I do, how it is described on this page "here". After change the config, add the script.bin and reboot, the display do nothing. It all the time black. It come no flash or something. My question is, what I have to change on my Banana Pro? I have install ARMBINA 5.31 (4.11.6-sunxi). One thing. How I can test the LCD-Display for conection? Can I send commandos to the Display? thanks for YOU help.
Guest Posted June 2, 2018 Posted June 2, 2018 (edited) Hello Everybody, just having the same question.I want to use a 7" display on my banana PI with the current version of Armbian (4.14.14).Do I still have to go through the build process? I could find this comment telling that the drivers are now integrated https://docs.armbian.com/boards/bananapi/. How do I use the drivers? Thanks for any information! Regards Vore Edited June 2, 2018 by vore76
Green Daddy Posted August 2, 2018 Posted August 2, 2018 On 6/20/2018 at 10:12 PM, vore76 said: Anybody? The driver you quoted is for legacy kernel. LCD enabling is much simpler with legacy. Mainline needs the steps mentioned in the tutorial. Hope that helps!
Guest Posted September 9, 2018 Posted September 9, 2018 Hello! Ok, I followed the tutorial. But I'm having issues with the file "sun7i-a20-bananapi.dtb". I'm quite sure that I'm doing everything as mentioned in the tutorial but something seams to be wrong. I get this during the build process: DTC arch/arm/dts/sun7i-a20-bananapi.dtb arch/arm/dts/sun7i-a20-bananapi.dtb: ERROR (phandle_references): Reference to non-existent node or label "reg_dcdc2" arch/arm/dts/sun7i-a20-bananapi.dtb: ERROR (phandle_references): Reference to non-existent node or label "edt_ft5x06_pins_a" arch/arm/dts/sun7i-a20-bananapi.dtb: ERROR (phandle_references): Reference to non-existent node or label "edt_ft5x06_pins_b" arch/arm/dts/sun7i-a20-bananapi.dtb: ERROR (phandle_references): Reference to non-existent node or label "led_pins_bananapi" arch/arm/dts/sun7i-a20-bananapi.dtb: ERROR (phandle_references): Reference to non-existent node or label "gmac_power_pin_bananapi" ERROR: Input tree has errors, aborting (use -f to force output) scripts/Makefile.lib:327: recipe for target 'arch/arm/dts/sun7i-a20-bananapi.dtb' failed make[2]: *** [arch/arm/dts/sun7i-a20-bananapi.dtb] Error 2 dts/Makefile:44: recipe for target 'arch-dtbs' failed make[1]: *** [arch-dtbs] Error 2 Makefile:908: recipe for target 'dts/dt.dtb' failed make: *** [dts/dt.dtb] Error 2 [ error ] ERROR in function compile_uboot [ compilation.sh:173 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated Could somebody check the file? Maybe I'm overseeing something? Thank you! sun7i-a20-bananapi.dts
Guest Posted September 21, 2018 Posted September 21, 2018 Hello! Finally I could solve the issues and compile the files. I had issues with strange characters in the files after editing them.
