 the issue is as follows:
1. When using the Type-C interface to connect to an external monitor, the display works normally if the monitor is connected after the development board has started.
2. If the monitor is disconnected and then reconnected after approximately several hours (possibly more than 6 hours), the display fails to show any image.
I used the `armbianmonitor -u` command, and it output the following URL.
https://paste.armbian.com/foyecusoju
If the Type-C interface is functioning normally, the latest output from `dmesg -w` would show the following:
[ 1155.922647] xhci-hcd xhci-hcd.15.auto: xHCI Host Controller
[ 1155.922692] xhci-hcd xhci-hcd.15.auto: new USB bus registered, assigned bus number 7
[ 1155.922885] xhci-hcd xhci-hcd.15.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0002008002010010
[ 1155.922937] xhci-hcd xhci-hcd.15.auto: irq 116, io mem 0xfc000000
[ 1155.923133] xhci-hcd xhci-hcd.15.auto: xHCI Host Controller
[ 1155.923152] xhci-hcd xhci-hcd.15.auto: new USB bus registered, assigned bus number 8
[ 1155.923173] xhci-hcd xhci-hcd.15.auto: Host supports USB 3.0 SuperSpeed
[ 1155.923455] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1155.923476] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1155.923491] usb usb7: Product: xHCI Host Controller
[ 1155.923502] usb usb7: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd
[ 1155.923515] usb usb7: SerialNumber: xhci-hcd.15.auto
[ 1155.924750] hub 7-0:1.0: USB hub found
[ 1155.924811] hub 7-0:1.0: 1 port detected
[ 1155.925434] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1155.925607] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1155.925625] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1155.925638] usb usb8: Product: xHCI Host Controller
[ 1155.925649] usb usb8: Manufacturer: Linux 6.1.115-vendor-rk35xx xhci-hcd
[ 1155.925660] usb usb8: SerialNumber: xhci-hcd.15.auto
[ 1155.928950] hub 8-0:1.0: USB hub found
[ 1155.929019] hub 8-0:1.0: 1 port detected
[ 1156.590377] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 10(if:DP0, flag:0x0) for vp2 dclk: 533120000
[ 1156.590574] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out2 div: 2 dclk_core2 div: 2
[ 1156.590639] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop2 to 533120000, get 533119995
[ 1156.621808] dw-dp fde50000.dp: full-training link: 4 lanes at 5400 MHz
[ 1156.635430] dw-dp fde50000.dp: clock recovery succeeded
[ 1156.644918] dw-dp fde50000.dp: channel equalization succeeded
[ 1156.657348] rockchip-vop2 fdd90000.vop: [drm] vop enable intf:200
[ 1157.337766] dw-dp fde50000.dp: test_type0 is not support
[ 1157.339516] dw-dp fde50000.dp: test_type0 is not support
[ 1159.801886] usb 7-1: new high-speed USB device number 2 using xhci-hcd
[ 1159.942247] usb 7-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 1159.942271] usb 7-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1159.942278] usb 7-1: Product: USB 2.0 Hub
[ 1159.978762] hub 7-1:1.0: USB hub found
[ 1159.978833] hub 7-1:1.0: 4 ports detected
[ 1160.375255] usb 7-1.3: new full-speed USB device number 3 using xhci-hcd
[ 1160.583425] usb 7-1.3: New USB device found, idVendor=222a, idProduct=0001, bcdDevice= 0.02
[ 1160.583438] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1160.583441] usb 7-1.3: Product: ILITEK-TP
[ 1160.583443] usb 7-1.3: Manufacturer: ILITEK
[ 1160.653326] input: ILITEK ILITEK-TP as /devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.15.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:222A:0001.0005/input/input26
[ 1160.708695] input: ILITEK ILITEK-TP Mouse as /devices/platform/usbdrd3_0/fc000000.usb/xhci-hcd.15.auto/usb7/7-1/7-1.3/7-1.3:1.0/0003:222A:0001.0005/input/input28
[ 1160.709353] hid-multitouch 0003:222A:0001.0005: input,hiddev97,hidraw2: USB HID v1.10 Mouse [ILITEK ILITEK-TP] on usb-xhci-hcd.15.auto-1.3/input0
If it is not functioning normally, it will not output any content.
My brief experience in trying out a USB-C display wasn't great. I was never able to get any video at all until / unless I was fully booted into an OS, and even then it was shotty. Both USB-C connectors on the Orange PI 5 Plus (on mine anyway) are poorly made and intermittently lose connection if moved around at all. I recently read that's a real problem with SBCs in general that get their power over USB-C... clearly a very poor design.
I also read somewhere that a similar board required proprietary drivers for USB-C display output to function. My experience indicates at least something like that likely applies here as well. Dysfunctional hardware design.
