Tomi Skies Posted 22 hours ago Posted 22 hours ago So there is some conflicting naming between the name of the unit and the name on the board revision code. The name of the unit would suggest that it's a X96-Q clone, but the revision number suggests that it's a T95 mini. Like as seen in this video 0 Quote
SteeMan Posted 12 hours ago Posted 12 hours ago What you are reporting is quite common with tv boxes. The case markings often are different than the internals. What is it you are looking for? Your post didn't really ask for anything other than to report that you got a common tv box with internals that differ from the case. 0 Quote
Nick A Posted 2 hours ago Posted 2 hours ago @Tomi Skies try the x96q images https://github.com/NickAlilovic/build/releases/tag/20250306 0 Quote
