Hi, welcome everyone. I’m using an H50 TV box that I was about to throw away because I thought I had completely bricked it.
I disassembled it and found the pins to activate maskrom mode.
I think this could be useful for everyone.
I then installed the current image, and everything seems to work except for the HDMI output (blank screen).
Do you have any suggestions? Thanks. Some data and photo below.
In case you want to install please note that also multitool fails to activate the HDMI, so you will need SSH to config.
SOC: RK3188 (Hopefully - I did not remove the heatsink)
eMMC: Samsung KLMBG4GEAC-B001 32GB (64x4)
eMCP: Samsung KMQN10006B 8 GB eMMC + 1 GB LPDDR3 RAM
Wi-Fi IC 339S0209 2.4G/5G
LAN working
WIFI Working
root@rk3318-box:~# lscpu
Architecture:                aarch64
  CPU op-mode(s):            32-bit, 64-bit
  Byte Order:                Little Endian
CPU(s):                      4
  On-line CPU(s) list:       0-3
Vendor ID:                   ARM
  Model name:                Cortex-A53
    Model:                   4
    Thread(s) per core:      1
    Core(s) per cluster:     4
    Socket(s):               -
    Cluster(s):              1
    Stepping:                r0p4
    CPU(s) scaling MHz:      60%
    CPU max MHz:             1008.0000
    CPU min MHz:             600.0000
    BogoMIPS:                48.00
    Flags:                   fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
Caches (sum of all):
  L1d:                       128 KiB (4 instances)
  L1i:                       128 KiB (4 instances)
  L2:                        256 KiB (1 instance)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-3
Vulnerabilities:
  Gather data sampling:      Not affected
  Indirect target selection: Not affected
  Itlb multihit:             Not affected
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Not affected
  Reg file data sampling:    Not affected
  Retbleed:                  Not affected
  Spec rstack overflow:      Not affected
  Spec store bypass:         Not affected
  Spectre v1:                Mitigation; __user pointer sanitization
  Spectre v2:                Not affected
  Srbds:                     Not affected
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Not affected
root@rk3318-box:~# free -l
               total        used        free      shared  buff/cache   available
Mem:         1504636      291372     1037440       46940      297848     1213264
Low:         1504636      467196     1037440
High:              0           0           0
Swap:         752316           0      752316
SOME TESTS ON THE HDMI ISSUE:
hdmi_debug_20251008_230528.log
hdmi_test_20251008_230948.log
image.png.620cb09fdd581c9b157974b31092b337.pngimage.png.7acea9fc8288316239dfb666f9d4ed3a.pngimage.png.ce2cb1f4ab2f1f4655292e257e4c19ad.png
if you have tweezers and pin location for Maskroom rockchip will never be bricked
thanks for sharing
I use the best technique of all, trial and error, tears, screams and anger.
Search for the work from @jock as @paolosabatino in github
You will find all variants dts files for this chip rk3318 and rk3328
test all of them
https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.6/dt/rk3318-box.dts
https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.17/dt/rk3318-box.dts
also, this chip allready have a topic
https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/
the solution was inside of it, just search
­DISCLAIMER (PLEASE READ): everything you can find in this thread (binaries, texts, code snippets, etc...) are provided AS-IS and are not part of official Armbian project. For this reason not people from Armbian project nor myself are responsible for misuse or loss of functionality of hardware.
Thank you for the answer.
Yes I will try the various dts, so far I have found that librelec - despiite not running at all, is crashing giving a visible prompt on the HDMI.
I will try to compare that dtb/dts to the default rk3318-box and be back.
One suggestion I can give you is to try a fresh image from https://github.com/armbian/community/releases. Make a backup of the eMMC and clean it up (multitool can do both things), then try to boot from sdcard with the new image.
Newer images come with u-boot v2025.10-rc5 and a "fix" to reset the VOP before entering the kernel. Some people on the other thread reported that disabling u-boot HDMI made the HDMI work once in Linux. With kernel 6.17 this issue hit my box and I could arrange a fix, perhaps this fix will address your problem too (for reference: https://github.com/armbian/build/pull/8674/files#diff-70c2c867b6e2024080868c0d5c3230d58be2d2c4b88a24291b0469c7d2229629)
Hi, thanks a  lot for pointing me in the right direction. Indeed so far I am booting from the SD card. I have erased eMMC with multitool via SSH, as multitool as well is not visible via HDMI. Used the newer images as suggested, same situation: everything works via SSH cmd line, no output on HDMI. Log contains mainly errors as the ones posted above.
Still not clear why HDMI not working, However VFD display based n FD650 is working. Attached the vfd.conf file for openvfd: clock , USB, ETH,WIFI and COLON working.
vfd.conf
Very weird HDMI is not functional in both armbian and multitool: they use very different kernels. Multitool uses the 4.19 vendor kernel, which should be supposed to provide "best" compatibility.
The dmesg error is highly related to the missing HDMI, but in a way I can't recognize.
About the VFD driver, I guess you're using OpenVFD driver. Latest kernels (both 6.12 and >= 6.16) come with tm16xx driver which is by far much much better and candidate to be upstreamed in the mainline kernel. Here is the github project reference; the driver is already compiled in the kernel, but you may need to edit a device tree overlay by yourself to let it work with your board.
To try some debugging, the complete dmesg output and the original device tree of the stock android firmware would be very useful.
I will try to upgrade to tm16xx driver and be back.
As for the HDMI, do you mean that Multitool shoud work anyway?
THKS
:thumbup:
Yes, or at least there should be less chances to hit some corner case that reduces the compatibility. LibreELEC is using the mainline kernel only for years though, so it is really strange you have issues with both armbian and multitool. I may wonder there is something odd in the device tree, but it would be odd that a misconfiguration in the device tree causes a kernel fault in the DRM code and in particular in the wait for vblank function 🙄
Posted (edited)
Yes you are perfectly right. It took me some "minutes" to figure out. Just in case I do have the overlay dtso for the previous tm16xx version. No scrolling message however. Use ../value instead.
rx3318-H50.dtso-old.txt
Edited by GmP
@GmP ok, so the leds in the previous dtso are wrongly addressed? Because in the latest dtso I see 7 leds addressed on segment 0, instead the previous dtso declares 4 sparsely addressed leds.
edit: note also that your board is T98_RK3318, not T9_RK3318
@jock, sorry for the confusion actually there are two boards (two different TV-BOX) one (here in this post) is an rk3318-H50 as you say T98...  using FD650, the other one is rk3318-T9 (only T9) using FD655. All the dtso files posted are correct: for the H50 (T98) in this post you have the versions for the old kernel and the new one. Same in the other post "HELP WANTED" for the other TV BOX. At the end the two latest dtso are valid for the latest kernel. One of the difference between FD650 and FD655 is that the first one has 4 digits but 8 segments (0-7) on the contrary FD655 drives 5 digits and 7 segments (0..6). DTSO files are configured accordingly and fully working. Hope it clarifies.
@GmP oook, so now I understand the differences between the two dtso files provided here and in the other thread.
Do you spot other differences or peculiarities? Things that are useful are:
* the gpio led (do the separate red/blue/green led blinks on both boards?)
* wifi reset gpio (do wifi get detected in both boards with base configuration?)
* is there a separate PMIC like rk805/rk808 on any of the boards?
Things like these go into the dtso for full board support. The PMIC is very important since missing that could cause stability issues.
the two tv box are quite different.The rk3318-H50 of this post is quite cheap, so are the component inside. By the way for the rk3318-H50:
the PMIC is a DF1517, not an usual one.
The Board has three leds (one red is power on always on the other two are both blu but I have never seen them on) and a 4 digit display plus (colon) usb, lan and wlan icons.
Wifi works with the base configuration  2 and 5 ghz (although some warnings in the log).
Bluetooth is recognized as well.
I do not see any message related to the IR receiver.
By the way it seems to be quite stable.
This is the gpio list:
android_tv_box_32:/ $ cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-31, parent: platform/pinctrl, gpio0:
 gpio-2   (                    |vcc_otg_vbus        ) out hi
 gpio-30  (                    |vcc_sd              ) out hi
gpiochip1: GPIOs 32-63, parent: platform/pinctrl, gpio1:
 gpio-42  (                    |bt_default_rts      ) out lo
 gpio-50  (                    |reset               ) out hi
 gpio-53  (                    |bt_default_poweron  ) out hi
 gpio-56  (                    |fd650_scl           ) out hi
 gpio-57  (                    |fd650_sda           ) out hi
 gpio-58  (                    |bt_default_wake_host) in  hi
gpiochip2: GPIOs 64-95, parent: platform/pinctrl, gpio2:
 gpio-81  (                    |vcc_host_vbus       ) out hi
 gpio-82  (                    |power-led-ir        ) out lo
 gpio-90  (                    |power-led-normal    ) out lo
gpiochip3: GPIOs 96-127, parent: platform/pinctrl, gpio3:
The T9  is an old and quite different TVBOX (cames in two flavours rk3318 and rk3328 from Sunwell) and everything is working "out of the box" - wifi, bluetooh, lan, hdmi, ir receiver. It has no leds but a 5 digit display + 6 icons but if you think it would be useful I can open it and peraphs describe it in a different post to avoid confusion. It seems to me that is more widespread as there are configuration files all around. Let me know if it is of ant interest.
Posted (edited)
@jock this is the user-overlay patch I am using to enable both leds on the board. The "working" led is as usual a couple of alternating leds of red/blue. The led-ir is a standalone blue, I have triggered one to the "timer" and the other to "activity" , both running.
I can confirm bluetooth, IR remote receiver are also working. Bluetooth needs BCM.hd (I have used BCM43342.hcd).
For the wifi 2/5G the correct overlay is rk3318-box-wlan-ap6334.
HDMI, despite apparently is initialized correctly and answering to all commands still gives a black screen.
rk3318-box-led-overlay-ledA.dtso.txt
Edited by GmP
