Monsoft Posted yesterday at 10:20 AM Posted yesterday at 10:20 AM Hi, Recently I reinstalled system on my Odroid C1+ from older Ubuntu with original 3.10.107 to newest Armbian with kernel 6.12.44. Generally it works quite well but I see a lots of stalls detection warnings in logs: Thu Oct 9 02:00:26 2025] rcu: INFO: rcu_sched self-detected stall on CPU [Thu Oct 9 02:00:26 2025] rcu: 0-....: (1799 ticks this GP) idle=a184/1/0x40000004 softirq=1089909/1089910 fqs=488 [Thu Oct 9 02:00:26 2025] rcu: (t=2100 jiffies g=2037329 q=10 ncpus=4) [Thu Oct 9 02:00:26 2025] CPU: 0 UID: 0 PID: 7987 Comm: kworker/0:1 Not tainted 6.12.44-current-meson #2 [Thu Oct 9 02:00:26 2025] Hardware name: Amlogic Meson platform [Thu Oct 9 02:00:26 2025] Workqueue: events dbs_work_handler [Thu Oct 9 02:00:26 2025] PC is at __slab_free+0x0/0x314 [Thu Oct 9 02:00:26 2025] LR is at kmem_cache_free+0x120/0x378 [Thu Oct 9 02:00:26 2025] pc : [<c056fd04>] lr : [<c05716fc>] psr: 800f0113 [Thu Oct 9 02:00:26 2025] sp : f0801b58 ip : ef6a6398 fp : c2387fc0 [Thu Oct 9 02:00:26 2025] r10: c5844380 r9 : c2352740 r8 : 000e6e80 [Thu Oct 9 02:00:26 2025] r7 : c11dd1d4 r6 : c66a0000 r5 : ef7dfe80 r4 : c280ef80 [Thu Oct 9 02:00:26 2025] r3 : c66a0000 r2 : c66a0000 r1 : ef7dfe80 r0 : c280ef80 [Thu Oct 9 02:00:26 2025] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [Thu Oct 9 02:00:26 2025] Control: 10c5387d Table: 062a404a DAC: 00000051 [Thu Oct 9 02:00:26 2025] Call trace: [Thu Oct 9 02:00:26 2025] __slab_free from kmem_cache_free+0x120/0x378 [Thu Oct 9 02:00:26 2025] kmem_cache_free from tcp_rcv_established+0x428/0x6cc [Thu Oct 9 02:00:26 2025] tcp_rcv_established from tcp_v4_do_rcv+0x180/0x284 [Thu Oct 9 02:00:26 2025] tcp_v4_do_rcv from tcp_v4_rcv+0xbc0/0x1068 [Thu Oct 9 02:00:26 2025] tcp_v4_rcv from ip_protocol_deliver_rcu+0x30/0x27c [Thu Oct 9 02:00:26 2025] ip_protocol_deliver_rcu from ip_local_deliver_finish+0x7c/0x98 [Thu Oct 9 02:00:26 2025] ip_local_deliver_finish from ip_sublist_rcv_finish+0x3c/0x50 [Thu Oct 9 02:00:26 2025] ip_sublist_rcv_finish from ip_sublist_rcv+0x174/0x1e4 [Thu Oct 9 02:00:26 2025] ip_sublist_rcv from ip_list_rcv+0xe8/0x114 [Thu Oct 9 02:00:26 2025] ip_list_rcv from __netif_receive_skb_list_core+0x188/0x1f4 [Thu Oct 9 02:00:26 2025] __netif_receive_skb_list_core from netif_receive_skb_list_internal+0x180/0x288 [Thu Oct 9 02:00:26 2025] netif_receive_skb_list_internal from napi_gro_receive+0x15c/0x264 [Thu Oct 9 02:00:26 2025] napi_gro_receive from stmmac_napi_poll_rx+0x9f8/0xfa0 [Thu Oct 9 02:00:26 2025] stmmac_napi_poll_rx from __napi_poll.constprop.0+0x2c/0x1c8 [Thu Oct 9 02:00:26 2025] __napi_poll.constprop.0 from net_rx_action+0x328/0x3a4 [Thu Oct 9 02:00:26 2025] net_rx_action from handle_softirqs+0x114/0x338 [Thu Oct 9 02:00:26 2025] handle_softirqs from irq_exit+0x8c/0xbc [Thu Oct 9 02:00:26 2025] irq_exit from call_with_stack+0x18/0x20 [Thu Oct 9 02:00:26 2025] call_with_stack from __irq_svc+0x98/0xb0 [Thu Oct 9 02:00:26 2025] Exception stack(0xf1851c60 to 0xf1851ca8) [Thu Oct 9 02:00:26 2025] 1c60: c28f4d30 00000000 00000000 00000000 c28f4d80 c282bd80 c282b480 016e3600 [Thu Oct 9 02:00:26 2025] 1c80: 00000000 c28f4240 00000001 f1851d40 800f0013 f1851cb0 c0dec028 c0dec02c [Thu Oct 9 02:00:26 2025] 1ca0: 600f0013 ffffffff [Thu Oct 9 02:00:26 2025] __irq_svc from __clk_recalc_accuracies+0x54/0x68 [Thu Oct 9 02:00:26 2025] __clk_recalc_accuracies from clk_core_set_parent_nolock+0x204/0x274 [Thu Oct 9 02:00:26 2025] clk_core_set_parent_nolock from meson8b_cpu_clk_notifier_cb+0x78/0x8c [Thu Oct 9 02:00:26 2025] meson8b_cpu_clk_notifier_cb from notifier_call_chain+0x8c/0x108 [Thu Oct 9 02:00:26 2025] notifier_call_chain from srcu_notifier_call_chain+0x40/0x98 [Thu Oct 9 02:00:26 2025] srcu_notifier_call_chain from __clk_notify+0x80/0xac [Thu Oct 9 02:00:26 2025] __clk_notify from clk_propagate_rate_change+0x98/0xb0 [Thu Oct 9 02:00:26 2025] clk_propagate_rate_change from clk_propagate_rate_change+0x5c/0xb0 [Thu Oct 9 02:00:26 2025] clk_propagate_rate_change from clk_propagate_rate_change+0x5c/0xb0 [Thu Oct 9 02:00:26 2025] clk_propagate_rate_change from clk_propagate_rate_change+0x5c/0xb0 [Thu Oct 9 02:00:26 2025] clk_propagate_rate_change from clk_core_set_rate_nolock+0xf4/0x31c [Thu Oct 9 02:00:26 2025] clk_core_set_rate_nolock from clk_set_rate+0x30/0x154 [Thu Oct 9 02:00:26 2025] clk_set_rate from _opp_config_clk_single+0x24/0x84 [Thu Oct 9 02:00:26 2025] _opp_config_clk_single from _set_opp+0x10c/0x41c [Thu Oct 9 02:00:26 2025] _set_opp from dev_pm_opp_set_rate+0x124/0x230 [Thu Oct 9 02:00:26 2025] dev_pm_opp_set_rate from __cpufreq_driver_target+0x394/0x6ac [Thu Oct 9 02:00:26 2025] __cpufreq_driver_target from od_dbs_update+0x148/0x174 [Thu Oct 9 02:00:26 2025] od_dbs_update from dbs_work_handler+0x2c/0x58 [Thu Oct 9 02:00:26 2025] dbs_work_handler from process_one_work+0x168/0x3b8 [Thu Oct 9 02:00:26 2025] process_one_work from worker_thread+0x264/0x42c [Thu Oct 9 02:00:26 2025] worker_thread from kthread+0xe0/0xfc [Thu Oct 9 02:00:26 2025] kthread from ret_from_fork+0x14/0x28 [Thu Oct 9 02:00:26 2025] Exception stack(0xf1851fb0 to 0xf1851ff8) [Thu Oct 9 02:00:26 2025] 1fa0: 00000000 00000000 00000000 00000000 [Thu Oct 9 02:00:26 2025] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [Thu Oct 9 02:00:26 2025] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 Is there a way to fix it ? 0 Quote
Solution torz77 Posted yesterday at 11:13 AM Solution Posted yesterday at 11:13 AM Assuming that you installed the standard image, then I suspect this is the same bug that I identified here: I submitted a PR to patch this, which has been accepted into Armbian, but it won't have flowed through into the releases yet, so you will need to build the image (instructions also linked in the subsequent post) 0 Quote
Monsoft Posted yesterday at 02:40 PM Author Posted yesterday at 02:40 PM Thanks for answer. Yep, I installed standard image. Since I was using two storage devices (SD and MMC), I first noticed issues with the mounted file system on the SD card, which I eventually had to remove (only the MMC storage remained). Then I noticed errors causing the processor to freeze, which got me a little worried. It was long time ago when last time I was compiling Linux kernel (FreeBSD more recently) , but maybe I will try to follow your instructions and try to do it. Many Thanks 0 Quote
torz77 Posted yesterday at 03:12 PM Posted yesterday at 03:12 PM I didn't test eMMC, whilst the bug occurred (it definitely impacted the SD card), but I did try using a USB drive and I can confirm (for me at least) the issue went away (the issue impacts the MMC stack, specifically), so if you have a spare USB drive hanging around, and you want an easier interim "fix" you can try putting the rootfs on a USB drive in the meantime. To be clear, the bug still did occur, but as it only impacted the SD card (which was for boot only), it only spammed my log files, but did not impact my day to day running (which with rootfs on SD, it definitely did. Made the device completely unusable pending a hard reset). I'll put the build instructions here too, because it's very simple (This was using a Debian Bookworm/Trixie host): sudo apt install git git clone --depth=1 https://github.com/armbian/build.git cd build ./compile.sh \ BOARD=odroidc1 \ BRANCH=current \ RELEASE=trixie \ BUILD_MINIMAL=yes \ BUILD_DESKTOP=no \ CLEAN_LEVEL= \ PREFER_DOCKER=no \ KERNEL_CONFIGURE=no \ COMPRESS_OUTPUTIMAGE=sha,gpg,img And that's it. Image is saved in: ./output/images 0 Quote
Monsoft Posted 10 hours ago Author Posted 10 hours ago Thanks. I build kernel yesterday. Quite long building process. It's simple with your steps but only what worry me is a size of kernel image as I got 1.3GB kernel file at the end as I assume that kernel is build with all available options selected (but this is only my assumption). Is there any kernel config from current kernel which I could use to build new kernel to make it smaller ? 0 Quote
torz77 Posted 6 hours ago Posted 6 hours ago (edited) Ok, I was trying to work out what you were doing, as 1.3GB is an insanely large size for the kernel (it is 12MB on my system!), but I think I have now (and why it took so long). I'm guessing at the following. If I am incorrect, I apologise. At a guess I would say that you ran that ./compile command directly on your Odroid? Is that correct? If so, that will be why it took so long (you are meant to build the image on a different, more powerful, host device). What you did was fine, but it is (obviously) slower as it is a fairly underpowered device. Secondly, I think you are misunderstanding what you have done. I believe the file in output/images you are talking about is this (or named similar): -rw-rw-r-- 1 user root 1.4G Oct 10 13:45 Armbian-unofficial_25.11.0-trunk_Odroidc1_trixie_current_6.12.51_minimal.img This is not the kernel. This is the entire Odroid C1+ image (including boot and rootfs partitions) to be burned to SD/eMMC. It is basically an updated version of what you downloaded as a standard image. You are meant to take this file and burn it to your media, as you did with the standard image. That would be the easiest step now (copy that file off your Odroid, burn it to your eMMC, place burned image back into your Odroid and go back through first run setup). It may also be possible to just install your new kernel, which was built as part of the above process. Note: I have never done this before, but I see no reason why it shouldn't work (you can always fallback to burning the whole image if this doesn't work, just copy the .img file off first). This would leave you on Bookworm/Noble though rather than Trixie, which may be fine for you. Within the build/output/debs folder you should find a series of debian (.deb) packages. These will include the kernel (it will be the one which starts linux-image-current-meson_25.11.0-trunk_armhf__6.12.xx). You can install this with: Note: Update <kernel file name> to the correct name of your kernel sudo dpkg -i build/output/debs/<kernel file name>.deb I would also be installing any of the other deb packages in that folder with the kernel version number in the name (ie __6.12.51.xx) as most likely those packages will be required as they will have been built against your new kernel. Whichever way you go, once done, you can reclaim the space from the build process by just deleting the build folder. It is only needed for the build process to generate the images/packages. Once these images/packages have been installed, the build folder is no longer required. Edited 6 hours ago by torz77 0 Quote
Monsoft Posted 4 hours ago Author Posted 4 hours ago I compiled kernel on debian vm which I just brought up via Vagrant but I guess that maybe I assigned not enough vCPUs to this vm (just 1). Yes, you're right, real kernel package is much smaller as around 103M vagrant@test-debian12:~/build/output/debs$ ls -lh linux-image-current-meson_25.11.0-trunk_armhf__6.12.51-Sa915-D8343-P0029-C8d22H47a6-HK01ba-Va132-B14f4-R448a.deb -rw-rw-r-- 1 vagrant root 103M Oct 9 17:43 linux-image-current-meson_25.11.0-trunk_armhf__6.12.51-Sa915-D8343-P0029-C8d22H47a6-HK01ba-Va132-B14f4-R448a.deb I think I will go with using this new Armbian disk Image (this 1.3 GB file ;-)) so it will be easier to get this working. I have copy of my old drive so I don't have to worry about loosing any data . To be honest, I very occasionally compiling something from sources not even mention of cross-compiling kernel even if I use Linux on daily basis (work and home). I really appreciate your time in helping me with this and I think this information is very valuable as many people are still using the Odroid C1 board. Many Thanks !!! 0 Quote
