Maharshi Oza Posted October 13, 2025 Posted October 13, 2025 DDR d5483af87d cym 23/11/23-16:15:24,fwver: v1.15 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB Manufacturer ID:0x0 ch:0 dq0 fail,write:0x1,read:0x0 ch:0 dq1 fail,write:0x2,read:0x0 ch:0 dq2 fail,write:0x4,read:0x0 ch:0 dq3 fail,write:0x8,read:0x0 ch:0 dq4 fail,write:0x10,read:0x0 ch:0 dq5 fail,write:0x20,read:0x0 ch:0 dq6 fail,write:0x40,read:0x0 ch:0 dq7 fail,write:0x80,read:0x0 ch:0 dq8 fail,write:0x100,read:0x0 ch:0 dq9 fail,write:0x200,read:0x0 ch:0 dq10 fail,write:0x400,read:0x0 ch:0 dq11 fail,write:0x800,read:0x0 ch:0 dq12 fail,write:0x1000,read:0x0 ch:0 dq13 fail,write:0x2000,read:0x0 ch:0 dq14 fail,write:0x4000,read:0x0 ch:0 dq15 fail,write:0x8000,read:0x0 ch:0 dq0 fail,write:0xfffffffe,read:0x0 ch:0 dq1 fail,write:0xfffffffd,read:0x0 ch:0 dq2 fail,write:0xfffffffb,read:0x0 ch:0 dq3 fail,write:0xfffffff7,read:0x0 ch:0 dq4 fail,write:0xffffffef,read:0x0 ch:0 dq5 fail,write:0xffffffdf,read:0x0 ch:0 dq6 fail,write:0xffffffbf,read:0x0 ch:0 dq7 fail,write:0xffffff7f,read:0x0 ch:0 dq8 fail,write:0xfffffeff,read:0x0 ch:0 dq9 fail,write:0xfffffdff,read:0x0 ch:0 dq10 fail,write:0xfffffbff,read:0x0 ch:0 dq11 fail,write:0xfffff7ff,read:0x0 ch:0 dq12 fail,write:0xffffefff,read:0x0 ch:0 dq13 fail,write:0xffffdfff,read:0x0 ch:0 dq14 fail,write:0xffffbfff,read:0x0 ch:0 dq15 fail,write:0xffff7fff,read:0x0 error ERR I am using Orangepi5B, OS: Copy of Orangepi5b_1.0.8_debian_bookworm_desktop_xfce_linux6.1.43 Providing sufficient power, with 5V and 4A. any solution to recover from this phase ? i have also inserted the SD card, but using that i am also getting error, it is not booting up. 0 Quote
Werner Posted October 13, 2025 Posted October 13, 2025 moved to offtopic. not using Armbian. If you need support with that image, ask at the place where you downloaded from. 0 Quote
