laibsch Posted October 26 Posted October 26 I received a Helios4 and was finally able to get it to boot. As per instructions, I booted from microSD and flashed the latest Armbian image to sda1 via the nand-sata-install command. This reboots fine now, but only with the microSD-card present and the SW1 dipswitch set to "SD card boot mode". Is anybody here using "SPI NOR Flash" or "SATA1" boot mode to get rid of the microSD card? I am bit handicapped here since my serial port on the microUSB only comes up maybe 1 in 10 times. I wonder if it's worn out or if I am simply doing something wrong. Related Links: 1 2 3 4 0 Quote
jimbolaya Posted October 27 Posted October 27 Unfortunately I don't have experience with the onboard flash, but I've never had an issue with the serial port. You've tried different cables i assume? 0 Quote
laibsch Posted October 27 Author Posted October 27 Thank you for your quick answer, Jimbolaya. Yes, I did try different cables all with the same result. I wonder if there is another way to access the serial console, J13 perhaps? Albeit with some required soldering, I suppose. Then remains the question of which headers exactly relate to GND, TX and RX. 0 Quote
laibsch Posted 1 hour ago Author Posted 1 hour ago With the latest changes in Armbian and most importantly the update of u-boot to v2025.10 for Helios4, it is now possible to boot SATA and USB from u-boot flashed to SPI NOR flash, with the dip switch set to SPI boot mode. This even includes booting straight from u-boot to btrfs now. 0 Quote
