I was trying to add the module em28xx (PCTV 460e DVB S2 drivers) but get errors
Cubietruck Vanilla 2.81
What I did:
1. make menuconfig in /usr/src/linux-headers-4.3.3-sunxi
2. add  Device Drivers -> Multimedia support ->  Media USB Adapters -> Empia EM28xx USB devices support -> DVB/ATSC Support for em28xx based TV cards as Module
3. "make scripts" as there was an error with the scripts
4. make modules
I get the following error
root@cubietruck:/usr/src/linux-headers-4.3.3-sunxi# make modules ARCH=arm
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'.  Stop.
arch/arm/Makefile:313: recipe for target 'archprepare' failed
make: *** [archprepare] Error 2
Is there a tutorial how to build additional modules on the cubietruck ?
Could you include the module in future releases ( iirc the S2 adapter works with the legacy image out of the box so the driveres are already in there)
Thanks !
Meanwhile I compiled the image from github sources according to the documention with KERNEL_ONLY=YES and installed it over 4.81 and the USB DVB stick works.
Thanks again !
