I have problem installing the program. It always stops on the message: "Setting up shared-mime-info (1.5-2ubuntu0.1)"
I try reinstalling system, format micro sd card etc...still same error...
So I solved it. When trying to install any program I received not just the above error.  All problems were caused by the first setup/startup - resize problem collision with h3disp first setup
Solution:
When selecting the display resolution (first run/setup), you must choose n / Y - "n" NO (h3disp). Then reboot due to resizing. After reboot when sd card resize you can change the resolution over h3disp command.
So problem is by the first run amrbian. When I choose change resolution Y. Then filesystem not resize....(error as lock filesystem, bugs...etc)
