Posted (edited)
Hello everybody,
My Box is a oxtagon shaped  t95z plus 2 mb 16 mb
chipset:
processor arm cortex -a53
mali T820 GPU
AP6255 wifi ac + bluetooth 4.2
sandisk SDINAD1F4-16G 16G emmc 16G rom
lanson L5TC4G63CFR x2 dram 2GB
I try to install armbian_community_26_2 _0-trunk.100 aml-s9xx-box_noble_current_6.12.63_cinnamon_dektop.img.xz
I use meson-gxm-vega-s96.dtb
And u-boot-s905x-s912.dtb copy and rename as u-boot.ext
It boots to ash then it stops
No asking for password and user
I have no clue what to do next
I have entered armbian-config but this returns a error
Any tips?
Edited by Herman Hoekstra
more info
Posted (edited)
Progress
I installed a command line image
Armbian_community_26.2.0-trunk.130_Aml-s9xx-box_noble_current_6.12.63.img.xz
This image let me boot to a promt asking me to set a root pw make a user and pw
Then it gives me a Prompt can use raspbian-config to make a wifi connection
But i have a overscan the prompt so i must type the first letters blind
I also miss the first letters of the answer
I cannot run xrandr to correct this problem
xrandr reports cant open display after the command
xrandr --listmonitors
Also how can i install and run a desktop on this system
Thanks in advance for a anser
Posted (edited)
Hello SteeMan
I can start armbian-config but i cannot find where to change the display and install a desktop
It als displays the current is plucky is not supported or not listed
Thanks
Posted (edited)
Succes,
I lowlevel formatted my SD cart.
Now i can install the CLI
I think there was something not right
The next thing to try is install a desktop image.
And fix the overscan issue and then install to the emmc internal memory
My internal menory is Sandisk SDINADF4-16G so i am hopefull.
But when i brick the system, is it stil possible to boot from a SD card or must i try to flash a version of android first using a USB A to USB a cabble?
Sorry I am not allowed to upload Image?
It depends on how you have bricked it.  Reflashing Android takes you back to a clean starting point.
