December 27, 2025Dec 27 Hello everybody, My Box is a oxtagon shapedย t95z plus 2 mb 16 mb chipset: processor arm cortex -a53 mali T820 GPU AP6255 wifi ac + bluetooth 4.2 sandisk SDINAD1F4-16G 16G emmc 16G rom lanson L5TC4G63CFR x2 dram 2GB ย I try to install armbian_community_26_2 _0-trunk.100 aml-s9xx-box_noble_current_6.12.63_cinnamon_dektop.img.xz I use meson-gxm-vega-s96.dtb And u-boot-s905x-s912.dtbย copy and rename as u-boot.ext It boots to ash then it stops No asking for password and user I have no clue what to do next I have entered armbian-config but this returns a error Any tips? Edited December 27, 2025Dec 27 by Herman Hoekstra more info
December 28, 2025Dec 28 Author Progress I installed a command line image Armbian_community_26.2.0-trunk.130_Aml-s9xx-box_noble_current_6.12.63.img.xz This image let me boot to a promt asking me to set a root pw make a user and pw Then it gives me a Prompt can use raspbian-config to make a wifi connection But i have a overscan the prompt so i must type the first letters blind I also miss the first letters of the answer I cannot run xrandr to correct this problem xrandr reports cant open display after the command xrandr --listmonitors Also how can i install and run a desktop on this system Thanks in advance for a anser ย Edited December 28, 2025Dec 28 by Herman Hoekstra
December 28, 2025Dec 28 Author Hello SteeMan I can start armbian-config but i cannot find where to change the display and install a desktop It als displays the current is plucky is not supported or not listed Thanks ย Edited December 29, 2025Dec 29 by Herman Hoekstra
December 29, 2025Dec 29 That isn't some you can do in armbian-config.ย This is Linux, use search to find how others have solved this.
December 30, 2025Dec 30 Author Succes, I lowlevel formatted my SD cart. Now i can install the CLI I think there was something not rightย The next thing to try is install a desktop image. And fix the overscan issue and then install to the emmc internal memory My internal menory is Sandisk SDINADF4-16G so i am hopefull. But when i brick the system, is it stil possible to boot from a SD card or must i try to flash a version of android first using a USB A to USB a cabble? Sorry I am not allowed to upload Image? Edited December 30, 2025Dec 30 by Herman Hoekstra
December 30, 2025Dec 30 3 hours ago, Herman Hoekstra said: But when i brick the system, is it stil possible to boot from a SD card or must i try to flash a version of android first using a USB A to USB a cabble? It depends on how you have bricked it.ย Reflashing Android takes you back to a clean starting point.
December 30, 2025Dec 30 Author Hello SteeMan I mean bricking when trying to install the system to EMMC memory My memory isย SDINADF4-16G
December 30, 2025Dec 30 A lot of things can go wrong, so depending on what goes wrong in a copy from SD to emmc, what steps would be needed to recover could differ.ย But flashing back to the original android firmware will generally always get you back to the starting point.
December 31, 2025Dec 31 Author Hello SteeMan, Thank you I am going to look for a usb a to usb a cable Maybe ik can make one myself Happy New Year ๐๐๐
