HV17 Posted yesterday at 03:53 AM Posted yesterday at 03:53 AM (edited) Hello, i'm trying to make Arch work on my H3, it boots to uboot, loads fine and says RAM size and reads /boot/boot.scr, but when it tries to ext4load something it gives a error of ` ** fs_devread read error - block` and ` ** No partition table - mmc 0`, everything after `321 bytes read in 24 ms (33.2 KiB/s)` loads by arrays of pixels, i never seen these before on Armbian, H3Droid or any other img file. [ EDIT ] Turns out, U-Boot defaults to 400000hz on SD card while saying its mode is SD High Speed (50MHz), i still cant fix the issue... Edited yesterday at 09:02 AM by HV17 0 Quote
Werner Posted yesterday at 05:57 AM Posted yesterday at 05:57 AM moved to off-topic since op is not using Armbian. 0 Quote
