m4teush Posted January 21 Posted January 21 Hi, is there any way to install Armbian on the built-in emmc memory on an mxq 4k pro with an s905w processor? Should I follow these guides? https://7ji.github.io/embedded/2022/11/08/alarm-install.html https://7ji.github.io/embedded/2022/11/11/ept-with-ampart.html Or is the built-in script in the system sufficient and will do everything without damaging anything? I would be grateful for any tips 0 Quote
SteeMan Posted January 21 Posted January 21 33 minutes ago, m4teush said: Or is the built-in script in the system sufficient and will do everything without damaging anything? If you mean the built-in script as described in the instructions linked to from the download page (https://www.armbian.com/amlogic-s9xx-tv-box) Then yes that should do everything you need. 0 Quote
