Hello. I have easily managed to get armbian up and running of a usb stick, in fact everything worked perfect (hdmi, wifi, gbit ethernet, etc.). The tv box is h96-air-gbit (as the dtb is named), amlogic s905x3 soc, 32gb mmc, 4gb RAM, gigabit ethernet, 2xusb 2.0, 1xusb 3.0, sd card, hdmi, av port (reset button inside), spdif. The thing is, I wanted to benefit from the 32gb internal mmc storage, since I was running armbian from a 8gb usb stick (had a lot of those hanging around, and didn't want to buy a bigger one). I did notice the image I used had not armbian-install script, nor nand-sata-install. I did a manual install (snapshot copy) of my current system with the help of Claude.ai
1. step - create an setup another partition on the emmc (currently there were 2x 4M partitions - the bootloader I presume)
sudo fdisk /dev/mmcblk1
sudo mkfs.ext4 -L ARMBIAN_ROOT /dev/mmcblk1p1
Note: Doing this seems enough reasonable to me (well, to my limited knowledge), no overwriting should have happened
2. step - snapshot copy the OS
sudo mkdir -p /mnt/emmc sudo mount /dev/mmcblk1p1 /mnt/emmc sudo rsync -aAXv --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} / /mnt/emmc/
Note: This also seems alright, and the commands exited with no errors
3. step - update the extlinux.conf, the cmdline to point to the right UUID - the one from the emmc
sudo blkid /dev/mmcblk1p1
sudo nano /mnt/emmc/boot/extlinux/extlinux.conf
4. step - just confirm everything is set, and shutdown, disconnect power and reconnect
cat /mnt/emmc/boot/extlinux/extlinux.conf
sync
sudo umount /mnt/emmc
Note: Everything seemed fine and correct.
So after the whole process, I shut it down, removed the usb and booted. It didn't come online after a while, so I rebooted with hdmi connected (I did face some issues before, like unusally slow boot times in headless mode). It just never turned on. The logo was gone, so I figured something went quite wrong. Currently, the situation is the following: I reopened the board to connect uart for diagnostics. So The board without external storage (usb, sd card) doesn't boot, it does a certain sequence, but fails and just hangs (no reboot loop). If I have an external usb, the one which worked before (correct setup), it reboots in loop - it does try to boot from the usb, but fails. Chatgpt suggests that I probably overwrote some portions of the bootloader or firmware files on which armbian relied (some or most of the env vars are probably gone). Claude has a similar suggestion (FDT_BAD_MAGIC, get partition table from dts faild - the bootloader is messed up). I did try booting from usb and from sd - forcing multi boot (reset button), but that's definitely not the issue. The bootloader seems to be working up to a certain point - but booting from usb or sd produce the same error - last few lines of the log, right before the reboot (and it reboots indefinitely in loop):
Device: SDIO Port B
Manufacturer ID: fe
OEM: 3456
Name: ASTCTran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.3 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: fe
OEM: 3456
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.3 GiB
mmc clock: 40000000
Bus Width: 4-bit
reading aml_autoscript
800 bytes read in 11 ms (70.3 KiB/s)
## Executing script at 01080000
## Error: "bootfromsd" not defined
get partition info failed !!
reboot use default mode: normal
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
Since, the aml_autoscript should definitely be working, the bootloader is the most probable issue.
So, what Claude suggests is to flash s905x3 compatible u-boot. I managed to get the board in usb burn mode by mask rom (toothpick reset method didn't work). Currently I have the board plugged to pc (usb male to male) and uart connected (improvised RP2040 zero uart bridge). Please provide me with instructions and what to do. I soft bricked the board by following plausible instructions from ai, I don't want to hard brick it (I really liked it:) Also, I keep the board connected, since I don't know if I could reintroduce mask rom mode if turned off.
Here is the complete log of one of the infinite reboots from the loop:
SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;  EMMC:0; READ:0;0.0;CHK:0;
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:15000020
S1:00000000
B2:20282000
B1:a0f83180
TE: 146487
BL2 Built : 15:21:48, Aug 28 2019. g12a g1bf2b53 - luan.yuan@droid15-sz
Board ID  = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xf ffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIE I prepare done
fastboot data load
00000000
emmc switch 1 ok
ddr saved addr:00016000
Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000,  part: 0
00000000
emmc switch 0 ok
fastboot data verify
verify result: 265
Cfg max: 5, cur: 1. Board id: 255. Force loop cfg
DDR4 probe
ddr clk to 912MHz
Load ddrfw from eMMC, src: 0x00 014200, des: 0xfffd0000, size: 0x0000c000, part: 0
dmc_version 0001
Check phy result
INFO : End of initialization
INFO : End of read enable training
INFO : End of fi ne write leveling
INFO : ERROR : Training has failed!
1D training failed
Cfg max: 5, cur: 2. Board id: 255. Force loop cfg
DDR3 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0002c2 00, des: 0xfffd0000, size: 0x0000c000, part: 0
dmc_version 0001
Check phy result
INFO : End of fine wr ite leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
 INFO : End of write delay center optimization
INFO : End of read delay center optimization
INFO : End of max read latency training
INFO : Td BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000c8000, part: 0
   BL33 CHK: 0xfffffff1 ADDR 01 7a1970
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 1
00000000
emmc switch 1 ok
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000c8000,  part: 1
    bl2z: ptr: 05129330, size: 00001e40
0.0;M3 C HK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12a_v1.1.3390-6ac5299 2019-09-26 14:09:46 luan.yuan@droid15-sz]
OPS=0x10
ring efuse init
2b 0c 10 00 01 07 0e 00 00 0f 32 34 50 4d 50 50
[0.933 001 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  B L31: Built : 15:57:33, May 22 2019
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Jun 1 9 2020 - 20:04:27)
DRAM:  3.8 GiBspi_post_bind(spifc): req_seq = 0
register usb cfg[0][1] = 00000000d7f3ec90
NAND:  get_sys_clk_rate_mtd() 290, clock setting  200!
NAND device id: 0 ff ff ff ff ff
No NAND device found!!!
nand init failed: -6
No NAND device found! !!
MMC:   aml_privemmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
  co-phase 0x3, tx-dly 0, clock 400000
co-phase 0x3, tx-dly 0, clock 40000000
         aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x162000
[mmc_startup] mmc refix success
init_part() 282: PART_TYPE_DOS
[mmc_init] mmc init success
      Amlogic multi-dtb tool
       Cannot find legal dtb!
start dts,buffer=00000000d3e53620,dt_addr=00000000d3e53620
check_valid_dts: FDT_ERR_BADMAGIC
get_partition_from_dts() 91: ret -9
get_partition_from_dts() 94: ret -9
get_ptbl_from_dtb()-272:  get partition table from dts faild
mmc_device_init()-1254: get partition table from dtb  failed
get_ptbl_rsv()-494: magic faild MPT,
mmc_device_init()-1281: dtb&rsv are not exisIn:    serial
Out:   s_verify_dtb_checksum()-3477: calc 0, store 0
update_dtb_info()-3585: cpy 1 is not val id
update_dtb_info()-3585: cpy 0 is not valid
dtb_read()-3694: total valid _verify_dtb_checksum()-3477: calc 0, store 0
update_dtb _info()-3585: cpy 1 is not valid
dtb_read()-3694: total valid 0
emmc - EMMC sub system
Usa ge:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
     vpu: vpu_power_on
vpu:[K M]Error:f[keymanage_dts_get_key_device]L100:/unify not parsed yet!
[KM]Error:f[_get_km_ops_by_name]L248:key eth_exphy_para not know device 4
[KM]Error:f[key_unify_read]L312:key[eth_ exphy_para] no cfg in dts
 dwmac.f f3f0000 Waiting for PHY auto negotiation to complete.             .             .             .             done
    The Bes t Window is index 44
[KM]Error:f[keymanage_dts_get_key_device]L100:/unify not parsed yet!
[KM]E rror:f[key_unify_write]L279:key[eth_exphy_para] no cfg in dts
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <a ddress>" command.
Aborting!
dwmac.ff3f0000[KM]Error:f[keymanage_ta:
        erase the area which is uboot or data
store erase partition <partition_name>:
        erase the area whi ch partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
        scrub the area from offset and size
store dtb i read/read/write addr <size>
        read/write dtb, size is optional
store key read/write ad= 0
info->crc32 = 0
Magic  is incorrect.
boot-info is invalid. Resetting.
save boo t-info
info->magic =
info->version_major = 1
info->version_minor = 0
info->slots[0].priority = 15
 info->slots[0].tries_remaining = 7
info->slots[0].successful_boot = 0
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->slots[1].successful_boot = 0
info->crcion in u-boot
store erase dtb
store erase key
st ore rom_protect on/off
store dtb iread/read/write addr <size>
        read /write dtb, size is optional
store key read/write addr <size>
        read/write key, size is optional
store ddr_parameter read/write addr <size>
        read/write ddr parameter[KM]Error:f[keymanage_dedid preferred_mode is <NULL>[0]
hdr mode is 0
dv  mode is ver:0  len: 0
hdr10+ mode is 0
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]set initrd_high: 0x3d800000
[OSD]fb_addr for logo: 0x3d800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=3840, height=2160
Cannot find dev.
amot
store erase dtb
store erase key
        read/write ddr parameter, size is o[KM]Error:f[keymanage_dnel error
SARADC channel(2) is 0x3ff.
saradc - saradc sub-system
Usage:
saradc saradc open <channel>    - open a SARADC channel
saradc close    - close the SARADC
saradc getval   - get the value in current channel
saradc test     - test the SARADC by channel-7
saradc get_in_range <min> <max> - return 0 if current value in the range of current channel
Command: bcb uboot-command
Start ron_name>:
        erase the area which partition in u-boot
store erase dtb
store erase key
store ddr_parameter read/writeuboot-command
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Unknown command 'ddr_auto_fast_boot_check' - try 'help'
pll tsensor avg: 0x1e95, u_efuse: 0x807a
temp1: 25
ddr tsensor avg: 0x1eaf, u_efuse: 0x8076
temp2: 26
device cool done
CONFIG_SYSTEM_AS_ROOT: systemroot
system_mode: 1
Start read misc partition datas!
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store init flag
store read name addr off|partition size
    read 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
store write name addr off|partitiote addr <size>
        read/write ddr parameter, size is optional
store mbr addr
   update mbr/partition table by dtb
[burnup]Err:store_read_ops,L84:cmd failed, ret=1, [store  read misc 0xd3e4d090  0x0  0x820]
failed to store read misc.
info->magic =
info->version_majosful_boot = 0
info->crc32 = -1075449479
Cannot find dev.
Usage:
store init flag
store write name addr off|partition size
    write 'size' bytes starting at offset 'off'
    to/frarameter read/write addr <size>
store mbr addr
[burnup]Err:store_write_ops,L148:cmd [store  write misc 0xd3e4d090  0x0  0x820] failed active slot = 0
CONFIG_AVB2: null
active_slot: normal
Cannot find dev.
Usage:
store init flag
store r on/off
store mbr addr
[burnup]Err:stornoSof
sof timeout, reset usb phy tuning
card in
co-phase 0x2, tx-dly 0, clock 400000
co-phase 0x2, tx-dly 0, clock 40000000
Device: SDIO Port B
Manufacturer ID: fe
OEM: 3456
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.3 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: fe
OEM: 3456
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.3 GiB
mmc clock: 40000000
Bus Width: 4-bit
system cmd  1.
You should have followed the install instructions on the download page:  https://www.armbian.com/amlogic-s9xx-tv-box
Given where you are now, you need to find an original android image, flash that to return the board to a clean state, and then follow those instructions.
The amlogic s9xx TV box builds use the android bootloader to bootstrap the boot process which at this point you have overwritten part of.
