0
XX7
teamviewer on Armbian for Android TV box
hi
I am newbie and need help regarding instaling teamviewer on armbian.
I have TVbox M8Spro+ with armbian mate, all working well except wifi, but this is minorr problem LAN working ok.
But my biggest problem is how to instal and start working with teamviewer.
I try to follow command :
wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb
sudo dpkg -i teamviewer-host_armhf.deb
sudo apt install -f
cat /etc/teamviewer/global.conf | grep ClientID
teamviewer passwd my_password
After that I try to find out ID in the: /etc/teamviewer/global.conf, and some ID is recorder.
I check but ID always is offline.
I try to start teamviewer with comand sudo teamviewer daemon start, I get feedback from system:
systemctl start teamviewerd.service
Failed to start teamviewerd.service: Unit teamviewerd.service not found.
fail
Pls advise, thx.
Share this post
Link to post
Share on other sites
In my research I find out that possible problem is because teamviewer not support architecture arm64, only support armHF.
Possibel this two version have some similarity and can be hack, but I did't find the way.
Pls correct me if I am wrong.
Share this post
Link to post
(edited)
Have you tried this?:
Ops, sorry,  i see now you want unattended access, you may need to install some other armhf dependencies.
Edited by @lex
unattended access info
Share this post
Link to post
0
