sgei Posted January 5, 2016 Posted January 5, 2016 Hi, yesterday I moved my root partition to a 128GB SSD by running "nand-sata-install" Everything works fine. Now I got a SD-Card in my Banana Pi with one big partition: fdisk -l Disk /dev/sda: 128.0 GB, 128035676160 bytes 30 heads, 63 sectors/track, 132312 cylinders, total 250069680 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x93d6d043 Device Boot Start End Blocks Id System /dev/sda1 2048 250069679 125033816 83 Linux Disk /dev/mmcblk0: 3965 MB, 3965190144 bytes 46 heads, 9 sectors/track, 18706 cylinders, total 7744512 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00043861 Device Boot Start End Blocks Id System /dev/mmcblk0p1 2048 7744511 3871232 83 Linux df Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf rootfs 123071852 1523900 115296264 2% / /dev/root 123071852 1523900 115296264 2% / devtmpfs 504172 0 504172 0% /dev tmpfs 131072 232 130840 1% /run tmpfs 5120 0 5120 0% /run/lock tmpfs 131072 0 131072 0% /run/shm /dev/mmcblk0p1 3810928 1307224 2343624 36% /media/mmc /dev/mmcblk0p1 3810928 1307224 2343624 36% /boot tmpfs 1048576 128 1048448 1% /tmp /dev/root 123071852 1523900 115296264 2% /var/log.hdd ramlog-tmpfs 262144 11492 250652 5% /var/log What do I have to do to prepare a new SD-Card (256MB) and move the Boot-Partition to it? In /media/mmc is my old /root, isn't it? Thanks. Steffen
