ThomasGB Posted January 6, 2016 Posted January 6, 2016 Two things: - If no HDMI is pluged in, /dev/fb0 disapears. Replug and it's there again. Must that be? (This nearly made me crazy 'till I found out!). - Compilation of external Drivers doesn't work anymore after new update. I have the precise error not here because I reinstalled generic version, but it's reproducable. (e.g with that: http://www.linuxdevcenter.com/pub/a/linux/2007/07/05/devhelloworld-a-simple-introduction-to-device-drivers-under-linux.html?page=2). Cheers Thomas
Igor Posted January 6, 2016 Posted January 6, 2016 1. Probably but in u-boot where the init is done. There is another bug if you attach 4k monitor to the HDMI. Error ... 2. Execute make scripts in /usr/src/linux-headers* and don't use generic version. If this won't help paste the error here.
ThomasGB Posted January 6, 2016 Author Posted January 6, 2016 1. Probably but in u-boot where the init is done. There is another bug if you attach 4k monitor to the HDMI. Error ... 2. Execute make scripts in /usr/src/linux-headers* and don't use generic version. If this won't help paste the error here. Part 2: /lib/modules/4.2.3-sunxi/build: No such file or directory. Stop. The reason is, that uname -r gives "4.2.3-sunxi" the correct version should be "4.3.3-sunxi". But that's not the only thing, Because after patching makefile I get: /bin/sh: 1: scripts/basic/fixdep: not found
ThomasGB Posted February 15, 2016 Author Posted February 15, 2016 Is it possible to change the resolution for BPI-M2 to 720p with Armbian?
