gnutux landia Posted February 5 Posted February 5 I'm been trying to install Armbian on this TV.BOX console. I already test bookworm xfce image of Armbian as like the last XFCE image → Armbian_community_26.2.0-trunk.357_Aml-s9xx-box_noble_current_6.18.7_xfce_desktop I als test minimal images ad they don't work. The spces of console are : Processor (CPU)Amlogic S905X3 Quad-core ARM Cortex-A55, up to 1.91GHz Graphics (GPU)Mali-G31 MP2 RAM4GB DDR3 Storage (ROM)32GB eMMC Video OutputHDMI, supports up to 8K@24fps (Android system) and 1080p (EmuELEC system) Connectivity2.4G/5G Dual-band Wi-Fi, 10/1000M Ethernet LAN, Bluetooth 4.0 Ports1x USB 3.0, 4x USB 2.0, HDMI, Ethernet, DCIN (Power), TF card slot, AV output I test to boot the stock images just after download them and the boot shows the HK1Series and then goes to internal android system (tvbox) so failed. When I do the steps to put dtb file, edit extlinux.conf and rename properly u-bott to u-boot.ext (I search and test test many dtb files as like meson-sm1-hk1box-vontar-x3.dtb, meson-sm1-h96max-x3.dtb, sm1_s905x3_4g_1gbit.dtb, sm1_s905x3_4g.dtb as like others that I download on web when I search info about install armbian on s905x tv boxes). I also try to see if I can edit a .dts file and then convert to .dtb qhen I did It doesn't work. So none of steps above works. But I find one image system that works called devmfc that has only a minimal image similar to a server image only with tty text. https://github.com/devmfc/debian-on-amlogic/releases I inspect the .image of this system, and I find that if I copy the boot.scr, boot.script and cfgload to the /boot partiton of the armbian systems and boot the Sper Console it goes to a pink screen and then after a minute just reboot or goes to hkseries system. So I think if I can edit boot.scr, bootscript and cfgload maybe I can put the right data to force boot the real kernel of armbian. Maybe then armbian works. I use Linux and try to open those files with text editor but doesn't work. Anyone knows How I can edit this files ? Any user can boot armbian on this console TvBox ? Thanks. 0 Quote
SteeMan Posted February 5 Posted February 5 1 hour ago, gnutux landia said: When I do the steps to put dtb file, edit extlinux.conf and rename properly u-bott to u-boot.ext Please explain in more detail what you mean by these statements. "put dtb file" - there is no dtb file to put, just test the ones that are in the build and I would start with meson-sm1-sei610.dtb (which is the reference board for the s905x3 cpu). And what u-boot-* are you using? Also have you run any other linux distribution on this box other than an official Armbian build downloaded from this site? 0 Quote
gnutux landia Posted February 5 Author Posted February 5 I put extra dtb files that I download on /boot/amlogic . For example I find that devmfc uses meson-sm1-ac2xx-generic.dtb on /boot/dtb/amlogic. So I copy it to Armbian boot partition on dtb/amlogic/meson-sm1-ac2xx-generic.dtb Then I edit extlinux/extlinux.conf label Armbian_community kernel /Image initrd /uInitrd fdt /dtb/amlogic/meson-sm1-ac2xx-generic.dtb append root=UUID=7dc5c0a3-acfc-4d51-a066-6c14d983a9de rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles I also test with other dtb files ad of course with the stock (default) image of Armbian just when donwload it, I use balenaetcher to write image on sd-card put it on a usb with sd-card reader and boot the tvbox, but doesn't work at all. The u-boot that I use is the u-boot-s905x3 that I copy to a directory and rename as u-boot.ext and then copy It to /boot. I oly try to run Armbian Systems from here → https://www.armbian.com/amlogic-s9xx-tv-box/ And I find devmfc when I search on google for " Debain s905x tv boxes" → thiss ystem works perfect, I only need to put on sd-card and put the sd-card on the usb with the sd-card reader and Tv Box shows HKSERIES and then go enter on the system devmfc. But I want some graphical friendly image to test the performance of tvbox as mini pc and because this I try to install xfce version of armbian. Thanks. 0 Quote
gnutux landia Posted February 6 Author Posted February 6 (edited) I decompile the dtb [meson-sm1-sei610.dtb] to dts any idea if I can edit some option on it ? meson-sm1-sei610.txt Spoiler /dts-v1/; / { interrupt-parent = < 0x01 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; compatible = "seirobotics,sei610\0amlogic,sm1"; model = "SEI Robotics SEI610"; aliases { mmc0 = "/soc/sd@ffe05000"; mmc1 = "/soc/mmc@ffe07000"; mmc2 = "/soc/sd@ffe03000"; serial0 = "/soc/bus@ff800000/serial@3000"; ethernet0 = "/soc/ethernet@ff3f0000"; }; chosen { #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; stdout-path = "serial0:115200n8"; framebuffer-cvbs { compatible = "amlogic,simple-framebuffer\0simple-framebuffer"; amlogic,pipeline = "vpu-cvbs"; clocks = < 0x02 0xa8 0x02 0x35 0x02 0x3a >; status = "disabled"; power-domains = < 0x03 0x00 >; phandle = < 0x5e >; }; framebuffer-hdmi { compatible = "amlogic,simple-framebuffer\0simple-framebuffer"; amlogic,pipeline = "vpu-hdmi"; clocks = < 0x02 0xa8 0x02 0x35 0x02 0x3a >; status = "disabled"; power-domains = < 0x03 0x00 >; phandle = < 0x5f >; }; }; efuse { compatible = "amlogic,meson-gxbb-efuse"; clocks = < 0x02 0x6a >; #address-cells = < 0x01 >; #size-cells = < 0x01 >; read-only; secure-monitor = < 0x04 >; phandle = < 0x60 >; }; opp-table-gpu { compatible = "operating-points-v2"; phandle = < 0x37 >; opp-124999998 { opp-hz = < 0x00 0x773593e >; opp-microvolt = < 0xc3500 >; }; opp-249999996 { opp-hz = < 0x00 0xee6b27c >; opp-microvolt = < 0xc3500 >; }; opp-285714281 { opp-hz = < 0x00 0x1107a769 >; opp-microvolt = < 0xc3500 >; }; opp-399999994 { opp-hz = < 0x00 0x17d783fa >; opp-microvolt = < 0xc3500 >; }; opp-499999992 { opp-hz = < 0x00 0x1dcd64f8 >; opp-microvolt = < 0xc3500 >; }; opp-666666656 { opp-hz = < 0x00 0x27bc86a0 >; opp-microvolt = < 0xc3500 >; }; opp-799999987 { opp-hz = < 0x00 0x2faf07f3 >; opp-microvolt = < 0xc3500 >; }; }; psci { compatible = "arm,psci-1.0"; method = "smc"; }; reserved-memory { #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; secmon@5000000 { reg = < 0x00 0x5000000 0x00 0x300000 >; no-map; phandle = < 0x61 >; }; secmon@5300000 { reg = < 0x00 0x5300000 0x00 0x2000000 >; no-map; phandle = < 0x62 >; }; linux,cma { compatible = "shared-dma-pool"; reusable; size = < 0x00 0x10000000 >; alignment = < 0x00 0x400000 >; linux,cma-default; }; }; secure-monitor { compatible = "amlogic,meson-gxbb-sm"; phandle = < 0x04 >; }; soc { compatible = "simple-bus"; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; pcie@fc000000 { compatible = "amlogic,g12a-pcie\0snps,dw-pcie"; reg = < 0x00 0xfc000000 0x00 0x400000 0x00 0xff648000 0x00 0x2000 0x00 0xfc400000 0x00 0x200000 >; reg-names = "elbi\0cfg\0config"; interrupts = < 0x00 0xdd 0x04 >; #interrupt-cells = < 0x01 >; interrupt-map-mask = < 0x00 0x00 0x00 0x00 >; interrupt-map = < 0x00 0x00 0x00 0x00 0x01 0x00 0xdf 0x04 >; bus-range = < 0x00 0xff >; #address-cells = < 0x03 >; #size-cells = < 0x02 >; device_type = "pci"; ranges = < 0x81000000 0x00 0x00 0x00 0xfc600000 0x00 0x100000 0x82000000 0x00 0xfc700000 0x00 0xfc700000 0x00 0x1900000 >; clocks = < 0x02 0x30 0x02 0x2d 0x02 0xc9 >; clock-names = "general\0pclk\0port"; resets = < 0x05 0x0c 0x05 0x0f >; reset-names = "port\0apb"; num-lanes = < 0x01 >; phys = < 0x06 0x02 >; phy-names = "pcie"; status = "disabled"; power-domains = < 0x03 0x03 >; phandle = < 0x63 >; }; ethernet@ff3f0000 { compatible = "amlogic,meson-g12a-dwmac\0snps,dwmac-3.70a\0snps,dwmac"; reg = < 0x00 0xff3f0000 0x00 0x10000 0x00 0xff634540 0x00 0x08 >; interrupts = < 0x00 0x08 0x04 >; interrupt-names = "macirq"; clocks = < 0x02 0x26 0x02 0x02 0x02 0x0d 0x02 0x02 >; clock-names = "stmmaceth\0clkin0\0clkin1\0timing-adjustment"; rx-fifo-depth = < 0x1000 >; tx-fifo-depth = < 0x800 >; status = "okay"; power-domains = < 0x03 0x06 >; phy-handle = < 0x07 >; phy-mode = "rmii"; phandle = < 0x64 >; mdio { #address-cells = < 0x01 >; #size-cells = < 0x00 >; compatible = "snps,dwmac-mdio"; phandle = < 0x10 >; }; }; bus@ff600000 { compatible = "simple-bus"; reg = < 0x00 0xff600000 0x00 0x200000 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0xff600000 0x00 0x200000 >; phandle = < 0x65 >; hdmi-tx@0 { compatible = "amlogic,meson-g12a-dw-hdmi"; reg = < 0x00 0x00 0x00 0x10000 >; interrupts = < 0x00 0x39 0x01 >; resets = < 0x05 0x13 0x05 0x42 0x05 0x4f >; reset-names = "hdmitx_apb\0hdmitx\0hdmitx_phy"; clocks = < 0x02 0xa8 0x02 0x35 0x02 0x3a >; clock-names = "isfr\0iahb\0venci"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; #sound-dai-cells = < 0x00 >; status = "okay"; pinctrl-0 = < 0x08 0x09 >; pinctrl-names = "default"; phandle = < 0x18 >; port@0 { reg = < 0x00 >; phandle = < 0x66 >; endpoint { remote-endpoint = < 0x0a >; phandle = < 0x20 >; }; }; port@1 { reg = < 0x01 >; phandle = < 0x67 >; endpoint { remote-endpoint = < 0x0b >; phandle = < 0x49 >; }; }; }; bus@30000 { compatible = "simple-bus"; reg = < 0x00 0x30000 0x00 0x2000 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x30000 0x00 0x2000 >; phandle = < 0x68 >; rng@218 { compatible = "amlogic,meson-rng"; reg = < 0x00 0x218 0x00 0x04 >; clocks = < 0x02 0x1b >; clock-names = "core"; phandle = < 0x69 >; }; }; audio-controller@32000 { compatible = "amlogic,t9015"; reg = < 0x00 0x32000 0x00 0x14 >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "ACODEC"; clocks = < 0x02 0x24 >; clock-names = "pclk"; resets = < 0x05 0x3d >; status = "disabled"; phandle = < 0x6a >; }; bus@34400 { compatible = "simple-bus"; reg = < 0x00 0x34400 0x00 0x400 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x34400 0x00 0x400 >; phandle = < 0x6b >; pinctrl@40 { compatible = "amlogic,meson-g12a-periphs-pinctrl"; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; phandle = < 0x0c >; bank@40 { reg = < 0x00 0x40 0x00 0x4c 0x00 0xe8 0x00 0x18 0x00 0x120 0x00 0x18 0x00 0x2c0 0x00 0x40 0x00 0x340 0x00 0x1c >; reg-names = "gpio\0pull\0pull-enable\0mux\0ds"; gpio-controller; #gpio-cells = < 0x02 >; gpio-ranges = < 0x0c 0x00 0x00 0x56 >; phandle = < 0x27 >; }; cec_ao_a_h { phandle = < 0x17 >; mux { groups = "cec_ao_a_h"; function = "cec_ao_a_h"; bias-disable; }; }; cec_ao_b_h { phandle = < 0x19 >; mux { groups = "cec_ao_b_h"; function = "cec_ao_b_h"; bias-disable; }; }; emmc-ctrl { phandle = < 0x2f >; mux-0 { groups = "emmc_cmd"; function = "emmc"; bias-pull-up; drive-strength-microamp = < 0xfa0 >; }; mux-1 { groups = "emmc_clk"; function = "emmc"; bias-disable; drive-strength-microamp = < 0xfa0 >; }; }; emmc-data-4b { phandle = < 0x6c >; mux-0 { groups = "emmc_nand_d0\0emmc_nand_d1\0emmc_nand_d2\0emmc_nand_d3"; function = "emmc"; bias-pull-up; drive-strength-microamp = < 0xfa0 >; }; }; emmc-data-8b { phandle = < 0x30 >; mux-0 { groups = "emmc_nand_d0\0emmc_nand_d1\0emmc_nand_d2\0emmc_nand_d3\0emmc_nand_d4\0emmc_nand_d5\0emmc_nand_d6\0emmc_nand_d7"; function = "emmc"; bias-pull-up; drive-strength-microamp = < 0xfa0 >; }; }; emmc-ds { phandle = < 0x31 >; mux { groups = "emmc_nand_ds"; function = "emmc"; bias-pull-down; drive-strength-microamp = < 0xfa0 >; }; }; emmc_clk_gate { phandle = < 0x32 >; mux { groups = "BOOT_8"; function = "gpio_periphs"; bias-pull-down; drive-strength-microamp = < 0xfa0 >; }; }; hdmitx_ddc { phandle = < 0x09 >; mux { groups = "hdmitx_sda\0hdmitx_sck"; function = "hdmitx"; bias-disable; drive-strength-microamp = < 0xfa0 >; }; }; hdmitx_hpd { phandle = < 0x08 >; mux { groups = "hdmitx_hpd_in"; function = "hdmitx"; bias-disable; }; }; i2c0-sda-c { phandle = < 0x6d >; mux { groups = "i2c0_sda_c"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c0-sck-c { phandle = < 0x6e >; mux { groups = "i2c0_sck_c"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c0-sda-z0 { phandle = < 0x6f >; mux { groups = "i2c0_sda_z0"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c0-sck-z1 { phandle = < 0x70 >; mux { groups = "i2c0_sck_z1"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c0-sda-z7 { phandle = < 0x71 >; mux { groups = "i2c0_sda_z7"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c0-sda-z8 { phandle = < 0x72 >; mux { groups = "i2c0_sda_z8"; function = "i2c0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sda-x { phandle = < 0x73 >; mux { groups = "i2c1_sda_x"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sck-x { phandle = < 0x74 >; mux { groups = "i2c1_sck_x"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sda-h2 { phandle = < 0x75 >; mux { groups = "i2c1_sda_h2"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sck-h3 { phandle = < 0x76 >; mux { groups = "i2c1_sck_h3"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sda-h6 { phandle = < 0x77 >; mux { groups = "i2c1_sda_h6"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c1-sck-h7 { phandle = < 0x78 >; mux { groups = "i2c1_sck_h7"; function = "i2c1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c2-sda-x { phandle = < 0x79 >; mux { groups = "i2c2_sda_x"; function = "i2c2"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c2-sck-x { phandle = < 0x7a >; mux { groups = "i2c2_sck_x"; function = "i2c2"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c2-sda-z { phandle = < 0x7b >; mux { groups = "i2c2_sda_z"; function = "i2c2"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c2-sck-z { phandle = < 0x7c >; mux { groups = "i2c2_sck_z"; function = "i2c2"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c3-sda-h { phandle = < 0x7d >; mux { groups = "i2c3_sda_h"; function = "i2c3"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c3-sck-h { phandle = < 0x7e >; mux { groups = "i2c3_sck_h"; function = "i2c3"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c3-sda-a { phandle = < 0x22 >; mux { groups = "i2c3_sda_a"; function = "i2c3"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c3-sck-a { phandle = < 0x23 >; mux { groups = "i2c3_sck_a"; function = "i2c3"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; remote-input { phandle = < 0x7f >; mux { groups = "remote_input"; function = "remote_input"; bias-disable; }; }; mclk0-a { phandle = < 0x80 >; mux { groups = "mclk0_a"; function = "mclk0"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; mclk1-a { phandle = < 0x81 >; mux { groups = "mclk1_a"; function = "mclk1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; mclk1-x { phandle = < 0x82 >; mux { groups = "mclk1_x"; function = "mclk1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; mclk1-z { phandle = < 0x83 >; mux { groups = "mclk1_z"; function = "mclk1"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; nor { phandle = < 0x84 >; mux { groups = "nor_d\0nor_q\0nor_c\0nor_cs"; function = "nor"; bias-disable; }; }; pdm-din0-a { phandle = < 0x85 >; mux { groups = "pdm_din0_a"; function = "pdm"; bias-disable; }; }; pdm-din0-c { phandle = < 0x86 >; mux { groups = "pdm_din0_c"; function = "pdm"; bias-disable; }; }; pdm-din0-x { phandle = < 0x87 >; mux { groups = "pdm_din0_x"; function = "pdm"; bias-disable; }; }; pdm-din0-z { phandle = < 0x13 >; mux { groups = "pdm_din0_z"; function = "pdm"; bias-disable; }; }; pdm-din1-a { phandle = < 0x88 >; mux { groups = "pdm_din1_a"; function = "pdm"; bias-disable; }; }; pdm-din1-c { phandle = < 0x89 >; mux { groups = "pdm_din1_c"; function = "pdm"; bias-disable; }; }; pdm-din1-x { phandle = < 0x8a >; mux { groups = "pdm_din1_x"; function = "pdm"; bias-disable; }; }; pdm-din1-z { phandle = < 0x8b >; mux { groups = "pdm_din1_z"; function = "pdm"; bias-disable; }; }; pdm-din2-a { phandle = < 0x8c >; mux { groups = "pdm_din2_a"; function = "pdm"; bias-disable; }; }; pdm-din2-c { phandle = < 0x8d >; mux { groups = "pdm_din2_c"; function = "pdm"; bias-disable; }; }; pdm-din2-x { phandle = < 0x8e >; mux { groups = "pdm_din2_x"; function = "pdm"; bias-disable; }; }; pdm-din2-z { phandle = < 0x8f >; mux { groups = "pdm_din2_z"; function = "pdm"; bias-disable; }; }; pdm-din3-a { phandle = < 0x90 >; mux { groups = "pdm_din3_a"; function = "pdm"; bias-disable; }; }; pdm-din3-c { phandle = < 0x91 >; mux { groups = "pdm_din3_c"; function = "pdm"; bias-disable; }; }; pdm-din3-x { phandle = < 0x92 >; mux { groups = "pdm_din3_x"; function = "pdm"; bias-disable; }; }; pdm-din3-z { phandle = < 0x93 >; mux { groups = "pdm_din3_z"; function = "pdm"; bias-disable; }; }; pdm-dclk-a { phandle = < 0x94 >; mux { groups = "pdm_dclk_a"; function = "pdm"; bias-disable; drive-strength-microamp = < 0x1f4 >; }; }; pdm-dclk-c { phandle = < 0x95 >; mux { groups = "pdm_dclk_c"; function = "pdm"; bias-disable; drive-strength-microamp = < 0x1f4 >; }; }; pdm-dclk-x { phandle = < 0x96 >; mux { groups = "pdm_dclk_x"; function = "pdm"; bias-disable; drive-strength-microamp = < 0x1f4 >; }; }; pdm-dclk-z { phandle = < 0x14 >; mux { groups = "pdm_dclk_z"; function = "pdm"; bias-disable; drive-strength-microamp = < 0x1f4 >; }; }; pwm-a { phandle = < 0x97 >; mux { groups = "pwm_a"; function = "pwm_a"; bias-disable; }; }; pwm-b-x7 { phandle = < 0x98 >; mux { groups = "pwm_b_x7"; function = "pwm_b"; bias-disable; }; }; pwm-b-x19 { phandle = < 0x99 >; mux { groups = "pwm_b_x19"; function = "pwm_b"; bias-disable; }; }; pwm-c-c { phandle = < 0x9a >; mux { groups = "pwm_c_c"; function = "pwm_c"; bias-disable; }; }; pwm-c-x5 { phandle = < 0x9b >; mux { groups = "pwm_c_x5"; function = "pwm_c"; bias-disable; }; }; pwm-c-x8 { phandle = < 0x9c >; mux { groups = "pwm_c_x8"; function = "pwm_c"; bias-disable; }; }; pwm-d-x3 { phandle = < 0x9d >; mux { groups = "pwm_d_x3"; function = "pwm_d"; bias-disable; }; }; pwm-d-x6 { phandle = < 0x9e >; mux { groups = "pwm_d_x6"; function = "pwm_d"; bias-disable; }; }; pwm-e { phandle = < 0x21 >; mux { groups = "pwm_e"; function = "pwm_e"; bias-disable; }; }; pwm-f-z { phandle = < 0x9f >; mux { groups = "pwm_f_z"; function = "pwm_f"; bias-disable; }; }; pwm-f-a { phandle = < 0xa0 >; mux { groups = "pwm_f_a"; function = "pwm_f"; bias-disable; }; }; pwm-f-x { phandle = < 0xa1 >; mux { groups = "pwm_f_x"; function = "pwm_f"; bias-disable; }; }; pwm-f-h { phandle = < 0xa2 >; mux { groups = "pwm_f_h"; function = "pwm_f"; bias-disable; }; }; sdcard_c { phandle = < 0x2d >; mux-0 { groups = "sdcard_d0_c\0sdcard_d1_c\0sdcard_d2_c\0sdcard_d3_c\0sdcard_cmd_c"; function = "sdcard"; bias-pull-up; drive-strength-microamp = < 0xfa0 >; }; mux-1 { groups = "sdcard_clk_c"; function = "sdcard"; bias-disable; drive-strength-microamp = < 0xfa0 >; }; }; sdcard_clk_gate_c { phandle = < 0x2e >; mux { groups = "GPIOC_4"; function = "gpio_periphs"; bias-pull-down; drive-strength-microamp = < 0xfa0 >; }; }; sdcard_z { phandle = < 0xa3 >; mux-0 { groups = "sdcard_d0_z\0sdcard_d1_z\0sdcard_d2_z\0sdcard_d3_z\0sdcard_cmd_z"; function = "sdcard"; bias-pull-up; drive-strength-microamp = < 0xfa0 >; }; mux-1 { groups = "sdcard_clk_z"; function = "sdcard"; bias-disable; drive-strength-microamp = < 0xfa0 >; }; }; sdcard_clk_gate_z { phandle = < 0xa4 >; mux { groups = "GPIOZ_6"; function = "gpio_periphs"; bias-pull-down; drive-strength-microamp = < 0xfa0 >; }; }; sdio { phandle = < 0x2a >; mux { groups = "sdio_d0\0sdio_d1\0sdio_d2\0sdio_d3\0sdio_clk\0sdio_cmd"; function = "sdio"; bias-disable; drive-strength-microamp = < 0xfa0 >; }; }; sdio_clk_gate { phandle = < 0x2b >; mux { groups = "GPIOX_4"; function = "gpio_periphs"; bias-pull-down; drive-strength-microamp = < 0xfa0 >; }; }; spdif-in-a10 { phandle = < 0xa5 >; mux { groups = "spdif_in_a10"; function = "spdif_in"; bias-disable; }; }; spdif-in-a12 { phandle = < 0xa6 >; mux { groups = "spdif_in_a12"; function = "spdif_in"; bias-disable; }; }; spdif-in-h { phandle = < 0xa7 >; mux { groups = "spdif_in_h"; function = "spdif_in"; bias-disable; }; }; spdif-out-h { phandle = < 0xa8 >; mux { groups = "spdif_out_h"; function = "spdif_out"; drive-strength-microamp = < 0x1f4 >; bias-disable; }; }; spdif-out-a11 { phandle = < 0xa9 >; mux { groups = "spdif_out_a11"; function = "spdif_out"; drive-strength-microamp = < 0x1f4 >; bias-disable; }; }; spdif-out-a13 { phandle = < 0xaa >; mux { groups = "spdif_out_a13"; function = "spdif_out"; drive-strength-microamp = < 0x1f4 >; bias-disable; }; }; spicc0-x { phandle = < 0xab >; mux { groups = "spi0_mosi_x\0spi0_miso_x\0spi0_clk_x"; function = "spi0"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; spicc0-ss0-x { phandle = < 0xac >; mux { groups = "spi0_ss0_x"; function = "spi0"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; spicc0-c { phandle = < 0xad >; mux { groups = "spi0_mosi_c\0spi0_miso_c\0spi0_ss0_c\0spi0_clk_c"; function = "spi0"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; spicc1 { phandle = < 0xae >; mux { groups = "spi1_mosi\0spi1_miso\0spi1_clk"; function = "spi1"; drive-strength-microamp = < 0xfa0 >; }; }; spicc1-ss0 { phandle = < 0xaf >; mux { groups = "spi1_ss0"; function = "spi1"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; tdm-a-din0 { phandle = < 0xb0 >; mux { groups = "tdm_a_din0"; function = "tdm_a"; bias-disable; }; }; tdm-a-din1 { phandle = < 0xb1 >; mux { groups = "tdm_a_din1"; function = "tdm_a"; bias-disable; }; }; tdm-a-dout0 { phandle = < 0x42 >; mux { groups = "tdm_a_dout0"; function = "tdm_a"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-a-dout1 { phandle = < 0xb2 >; mux { groups = "tdm_a_dout1"; function = "tdm_a"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-a-fs { phandle = < 0x43 >; mux { groups = "tdm_a_fs"; function = "tdm_a"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-a-sclk { phandle = < 0x44 >; mux { groups = "tdm_a_sclk"; function = "tdm_a"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-a-slv-fs { phandle = < 0xb3 >; mux { groups = "tdm_a_slv_fs"; function = "tdm_a"; bias-disable; }; }; tdm-a-slv-sclk { phandle = < 0xb4 >; mux { groups = "tdm_a_slv_sclk"; function = "tdm_a"; bias-disable; }; }; tdm-b-din0 { phandle = < 0xb5 >; mux { groups = "tdm_b_din0"; function = "tdm_b"; bias-disable; }; }; tdm-b-din1 { phandle = < 0xb6 >; mux { groups = "tdm_b_din1"; function = "tdm_b"; bias-disable; }; }; tdm-b-din2 { phandle = < 0xb7 >; mux { groups = "tdm_b_din2"; function = "tdm_b"; bias-disable; }; }; tdm-b-din3-a { phandle = < 0xb8 >; mux { groups = "tdm_b_din3_a"; function = "tdm_b"; bias-disable; }; }; tdm-b-din3-h { phandle = < 0xb9 >; mux { groups = "tdm_b_din3_h"; function = "tdm_b"; bias-disable; }; }; tdm-b-dout0 { phandle = < 0xba >; mux { groups = "tdm_b_dout0"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-dout1 { phandle = < 0xbb >; mux { groups = "tdm_b_dout1"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-dout2 { phandle = < 0xbc >; mux { groups = "tdm_b_dout2"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-dout3-a { phandle = < 0xbd >; mux { groups = "tdm_b_dout3_a"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-dout3-h { phandle = < 0xbe >; mux { groups = "tdm_b_dout3_h"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-fs { phandle = < 0xbf >; mux { groups = "tdm_b_fs"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-sclk { phandle = < 0xc0 >; mux { groups = "tdm_b_sclk"; function = "tdm_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-b-slv-fs { phandle = < 0xc1 >; mux { groups = "tdm_b_slv_fs"; function = "tdm_b"; bias-disable; }; }; tdm-b-slv-sclk { phandle = < 0xc2 >; mux { groups = "tdm_b_slv_sclk"; function = "tdm_b"; bias-disable; }; }; tdm-c-din0-a { phandle = < 0xc3 >; mux { groups = "tdm_c_din0_a"; function = "tdm_c"; bias-disable; }; }; tdm-c-din0-z { phandle = < 0xc4 >; mux { groups = "tdm_c_din0_z"; function = "tdm_c"; bias-disable; }; }; tdm-c-din1-a { phandle = < 0xc5 >; mux { groups = "tdm_c_din1_a"; function = "tdm_c"; bias-disable; }; }; tdm-c-din1-z { phandle = < 0xc6 >; mux { groups = "tdm_c_din1_z"; function = "tdm_c"; bias-disable; }; }; tdm-c-din2-a { phandle = < 0xc7 >; mux { groups = "tdm_c_din2_a"; function = "tdm_c"; bias-disable; }; }; eth-leds { phandle = < 0xc8 >; mux { groups = "eth_link_led\0eth_act_led"; function = "eth"; bias-disable; }; }; eth { phandle = < 0xc9 >; mux { groups = "eth_mdio\0eth_mdc\0eth_rgmii_rx_clk\0eth_rx_dv\0eth_rxd0\0eth_rxd1\0eth_txen\0eth_txd0\0eth_txd1"; function = "eth"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; eth-rgmii { phandle = < 0xca >; mux { groups = "eth_rxd2_rgmii\0eth_rxd3_rgmii\0eth_rgmii_tx_clk\0eth_txd2_rgmii\0eth_txd3_rgmii"; function = "eth"; drive-strength-microamp = < 0xfa0 >; bias-disable; }; }; tdm-c-din2-z { phandle = < 0xcb >; mux { groups = "tdm_c_din2_z"; function = "tdm_c"; bias-disable; }; }; tdm-c-din3-a { phandle = < 0xcc >; mux { groups = "tdm_c_din3_a"; function = "tdm_c"; bias-disable; }; }; tdm-c-din3-z { phandle = < 0xcd >; mux { groups = "tdm_c_din3_z"; function = "tdm_c"; bias-disable; }; }; tdm-c-dout0-a { phandle = < 0xce >; mux { groups = "tdm_c_dout0_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout0-z { phandle = < 0xcf >; mux { groups = "tdm_c_dout0_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout1-a { phandle = < 0xd0 >; mux { groups = "tdm_c_dout1_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout1-z { phandle = < 0xd1 >; mux { groups = "tdm_c_dout1_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout2-a { phandle = < 0xd2 >; mux { groups = "tdm_c_dout2_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout2-z { phandle = < 0xd3 >; mux { groups = "tdm_c_dout2_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout3-a { phandle = < 0xd4 >; mux { groups = "tdm_c_dout3_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-dout3-z { phandle = < 0xd5 >; mux { groups = "tdm_c_dout3_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-fs-a { phandle = < 0xd6 >; mux { groups = "tdm_c_fs_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-fs-z { phandle = < 0xd7 >; mux { groups = "tdm_c_fs_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-sclk-a { phandle = < 0xd8 >; mux { groups = "tdm_c_sclk_a"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-sclk-z { phandle = < 0xd9 >; mux { groups = "tdm_c_sclk_z"; function = "tdm_c"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-c-slv-fs-a { phandle = < 0xda >; mux { groups = "tdm_c_slv_fs_a"; function = "tdm_c"; bias-disable; }; }; tdm-c-slv-fs-z { phandle = < 0xdb >; mux { groups = "tdm_c_slv_fs_z"; function = "tdm_c"; bias-disable; }; }; tdm-c-slv-sclk-a { phandle = < 0xdc >; mux { groups = "tdm_c_slv_sclk_a"; function = "tdm_c"; bias-disable; }; }; tdm-c-slv-sclk-z { phandle = < 0xdd >; mux { groups = "tdm_c_slv_sclk_z"; function = "tdm_c"; bias-disable; }; }; uart-a { phandle = < 0x24 >; mux { groups = "uart_a_tx\0uart_a_rx"; function = "uart_a"; bias-disable; }; }; uart-a-cts-rts { phandle = < 0x25 >; mux { groups = "uart_a_cts\0uart_a_rts"; function = "uart_a"; bias-disable; }; }; uart-b { phandle = < 0xde >; mux { groups = "uart_b_tx\0uart_b_rx"; function = "uart_b"; bias-disable; }; }; uart-c { phandle = < 0xdf >; mux { groups = "uart_c_tx\0uart_c_rx"; function = "uart_c"; bias-disable; }; }; uart-c-cts-rts { phandle = < 0xe0 >; mux { groups = "uart_c_cts\0uart_c_rts"; function = "uart_c"; bias-disable; }; }; }; }; temperature-sensor@34800 { compatible = "amlogic,g12a-cpu-thermal\0amlogic,g12a-thermal"; reg = < 0x00 0x34800 0x00 0x50 >; interrupts = < 0x00 0x23 0x01 >; clocks = < 0x02 0xd4 >; #thermal-sensor-cells = < 0x00 >; amlogic,ao-secure = < 0x0d >; phandle = < 0x38 >; }; temperature-sensor@34c00 { compatible = "amlogic,g12a-ddr-thermal\0amlogic,g12a-thermal"; reg = < 0x00 0x34c00 0x00 0x50 >; interrupts = < 0x00 0x24 0x01 >; clocks = < 0x02 0xd4 >; #thermal-sensor-cells = < 0x00 >; amlogic,ao-secure = < 0x0d >; phandle = < 0x3f >; }; phy@36000 { compatible = "amlogic,g12a-usb2-phy"; reg = < 0x00 0x36000 0x00 0x2000 >; clocks = < 0x0e >; clock-names = "xtal"; resets = < 0x05 0x30 >; reset-names = "phy"; #phy-cells = < 0x00 >; phandle = < 0x35 >; }; bus@38000 { compatible = "simple-bus"; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x38000 0x00 0x2000 >; phandle = < 0xe1 >; video-lut@48 { compatible = "amlogic,canvas"; reg = < 0x00 0x48 0x00 0x14 >; phandle = < 0x1f >; }; }; phy@3a000 { compatible = "amlogic,g12a-usb2-phy"; reg = < 0x00 0x3a000 0x00 0x2000 >; clocks = < 0x0e >; clock-names = "xtal"; resets = < 0x05 0x31 >; reset-names = "phy"; #phy-cells = < 0x00 >; phandle = < 0x36 >; }; bus@3c000 { compatible = "simple-bus"; reg = < 0x00 0x3c000 0x00 0x1400 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x3c000 0x00 0x1400 >; phandle = < 0xe2 >; system-controller@0 { compatible = "amlogic,meson-gx-hhi-sysctrl\0simple-mfd\0syscon"; reg = < 0x00 0x00 0x00 0x400 >; phandle = < 0xe3 >; clock-controller { compatible = "amlogic,sm1-clkc"; #clock-cells = < 0x01 >; clocks = < 0x0e >; clock-names = "xtal"; phandle = < 0x02 >; }; power-controller { compatible = "amlogic,meson-sm1-pwrc"; #power-domain-cells = < 0x01 >; amlogic,ao-sysctrl = < 0x0f >; resets = < 0x05 0x05 0x05 0x0a 0x05 0x0d 0x05 0x25 0x05 0x85 0x05 0x86 0x05 0x87 0x05 0x89 0x05 0x8c 0x05 0x8d 0x05 0xe7 >; reset-names = "viu\0venc\0vcbus\0bt656\0rdma\0venci\0vencp\0vdac\0vdi6\0vencl\0vid_lock"; clocks = < 0x02 0x74 0x02 0x7c >; clock-names = "vpu\0vapb"; assigned-clocks = < 0x02 0x6e 0x02 0x70 0x02 0x74 0x02 0x75 0x02 0x77 0x02 0x7b >; assigned-clock-parents = < 0x02 0x03 0x00 0x02 0x70 0x02 0x04 0x00 0x02 0x77 >; assigned-clock-rates = < 0x00 0x27bc86aa 0x00 0x00 0xee6b280 0x00 >; phandle = < 0x03 >; }; }; }; phy@46000 { compatible = "amlogic,g12a-usb3-pcie-phy"; reg = < 0x00 0x46000 0x00 0x2000 >; clocks = < 0x02 0xc9 >; clock-names = "ref_clk"; resets = < 0x05 0x0e >; reset-names = "phy"; assigned-clocks = < 0x02 0xc9 >; assigned-clock-rates = < 0x5f5e100 >; #phy-cells = < 0x01 >; phandle = < 0x06 >; }; mdio-multiplexer@4c000 { compatible = "amlogic,g12a-mdio-mux"; reg = < 0x00 0x4c000 0x00 0xa4 >; clocks = < 0x02 0x13 0x0e 0x02 0xb1 >; clock-names = "pclk\0clkin0\0clkin1"; mdio-parent-bus = < 0x10 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; phandle = < 0xe4 >; mdio@0 { reg = < 0x00 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; phandle = < 0xe5 >; }; mdio@1 { reg = < 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; phandle = < 0xe6 >; ethernet-phy@8 { compatible = "ethernet-phy-id0180.3301\0ethernet-phy-ieee802.3-c22"; interrupts = < 0x00 0x09 0x04 >; reg = < 0x08 >; max-speed = < 0x64 >; phandle = < 0x07 >; }; }; }; bus@60000 { compatible = "simple-bus"; reg = < 0x00 0x60000 0x00 0x1000 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x60000 0x00 0x1000 >; phandle = < 0xe7 >; clock-controller@0 { status = "okay"; compatible = "amlogic,sm1-audio-clkc"; reg = < 0x00 0x00 0x00 0xb4 >; #clock-cells = < 0x01 >; #reset-cells = < 0x01 >; clocks = < 0x02 0x25 0x02 0x0b 0x02 0x0c 0x02 0x0d 0x02 0x0e 0x02 0x4a 0x02 0x03 0x02 0x04 0x02 0x05 >; clock-names = "pclk\0mst_in0\0mst_in1\0mst_in2\0mst_in3\0mst_in4\0mst_in5\0mst_in6\0mst_in7"; resets = < 0x05 0x41 >; phandle = < 0x11 >; }; audio-controller@100 { compatible = "amlogic,sm1-toddr\0amlogic,axg-toddr"; reg = < 0x00 0x100 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TODDR_A"; interrupts = < 0x00 0x94 0x01 >; clocks = < 0x11 0x29 >; resets = < 0x12 0x00 0x11 0x06 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x2000 >; status = "okay"; phandle = < 0x54 >; }; audio-controller@140 { compatible = "amlogic,sm1-toddr\0amlogic,axg-toddr"; reg = < 0x00 0x140 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TODDR_B"; interrupts = < 0x00 0x95 0x01 >; clocks = < 0x11 0x2a >; resets = < 0x12 0x01 0x11 0x07 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "okay"; phandle = < 0x55 >; }; audio-controller@180 { compatible = "amlogic,sm1-toddr\0amlogic,axg-toddr"; reg = < 0x00 0x180 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TODDR_C"; interrupts = < 0x00 0x96 0x01 >; clocks = < 0x11 0x2b >; resets = < 0x12 0x02 0x11 0x08 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "okay"; phandle = < 0x56 >; }; audio-controller@1c0 { compatible = "amlogic,sm1-frddr\0amlogic,axg-frddr"; reg = < 0x00 0x1c0 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "FRDDR_A"; interrupts = < 0x00 0x98 0x01 >; clocks = < 0x11 0x26 >; resets = < 0x12 0x03 0x11 0x09 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x200 >; status = "okay"; phandle = < 0x51 >; }; audio-controller@200 { compatible = "amlogic,sm1-frddr\0amlogic,axg-frddr"; reg = < 0x00 0x200 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "FRDDR_B"; interrupts = < 0x00 0x99 0x01 >; clocks = < 0x11 0x27 >; resets = < 0x12 0x04 0x11 0x0a >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "okay"; phandle = < 0x52 >; }; audio-controller@240 { compatible = "amlogic,sm1-frddr\0amlogic,axg-frddr"; reg = < 0x00 0x240 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "FRDDR_C"; interrupts = < 0x00 0x9a 0x01 >; clocks = < 0x11 0x28 >; resets = < 0x12 0x05 0x11 0x0b >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "okay"; phandle = < 0x53 >; }; reset-controller@280 { status = "okay"; compatible = "amlogic,meson-sm1-audio-arb"; reg = < 0x00 0x280 0x00 0x04 >; #reset-cells = < 0x01 >; clocks = < 0x11 0x1d >; phandle = < 0x12 >; }; audio-controller@300 { compatible = "amlogic,sm1-tdmin\0amlogic,axg-tdmin"; reg = < 0x00 0x300 0x00 0x40 >; sound-name-prefix = "TDMIN_A"; resets = < 0x11 0x01 >; clocks = < 0x11 0x1f 0x11 0x7b 0x11 0x74 0x11 0x82 0x11 0x82 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "okay"; phandle = < 0x4f >; }; audio-controller@340 { compatible = "amlogic,sm1-tdmin\0amlogic,axg-tdmin"; reg = < 0x00 0x340 0x00 0x40 >; sound-name-prefix = "TDMIN_B"; resets = < 0x11 0x02 >; clocks = < 0x11 0x20 0x11 0x7c 0x11 0x75 0x11 0x83 0x11 0x83 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "okay"; phandle = < 0x50 >; }; audio-controller@380 { compatible = "amlogic,sm1-tdmin\0amlogic,axg-tdmin"; reg = < 0x00 0x380 0x00 0x40 >; sound-name-prefix = "TDMIN_C"; resets = < 0x11 0x03 >; clocks = < 0x11 0x21 0x11 0x7d 0x11 0x76 0x11 0x84 0x11 0x84 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "disabled"; phandle = < 0xe8 >; }; audio-controller@3c0 { compatible = "amlogic,sm1-tdmin\0amlogic,axg-tdmin"; reg = < 0x00 0x3c0 0x00 0x40 >; sound-name-prefix = "TDMIN_LB"; resets = < 0x11 0x04 >; clocks = < 0x11 0x22 0x11 0x7e 0x11 0x77 0x11 0x85 0x11 0x85 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "disabled"; phandle = < 0xe9 >; }; audio-controller@400 { compatible = "amlogic,g12a-spdifin\0amlogic,axg-spdifin"; reg = < 0x00 0x400 0x00 0x30 >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "SPDIFIN"; interrupts = < 0x00 0x97 0x01 >; clocks = < 0x11 0x2d 0x11 0x38 >; clock-names = "pclk\0refclk"; resets = < 0x11 0x11 >; status = "disabled"; phandle = < 0xea >; }; audio-controller@480 { compatible = "amlogic,g12a-spdifout\0amlogic,axg-spdifout"; reg = < 0x00 0x480 0x00 0x50 >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "SPDIFOUT_A"; clocks = < 0x11 0x2e 0x11 0x37 >; clock-names = "pclk\0mclk"; resets = < 0x11 0x0f >; status = "disabled"; phandle = < 0xeb >; }; audio-controller@500 { compatible = "amlogic,sm1-tdmout"; reg = < 0x00 0x500 0x00 0x40 >; sound-name-prefix = "TDMOUT_A"; resets = < 0x11 0x0c >; clocks = < 0x11 0x23 0x11 0x7f 0x11 0x78 0x11 0x86 0x11 0x86 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "okay"; phandle = < 0x4d >; }; audio-controller@540 { compatible = "amlogic,sm1-tdmout"; reg = < 0x00 0x540 0x00 0x40 >; sound-name-prefix = "TDMOUT_B"; resets = < 0x11 0x0d >; clocks = < 0x11 0x24 0x11 0x80 0x11 0x79 0x11 0x87 0x11 0x87 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "okay"; phandle = < 0x4e >; }; audio-controller@580 { compatible = "amlogic,sm1-tdmout"; reg = < 0x00 0x580 0x00 0x40 >; sound-name-prefix = "TDMOUT_C"; resets = < 0x11 0x0e >; clocks = < 0x11 0x25 0x11 0x81 0x11 0x7a 0x11 0x88 0x11 0x88 >; clock-names = "pclk\0sclk\0sclk_sel\0lrclk\0lrclk_sel"; status = "disabled"; phandle = < 0xec >; }; audio-controller@740 { compatible = "amlogic,sm1-toacodec\0amlogic,g12a-toacodec"; reg = < 0x00 0x740 0x00 0x04 >; #sound-dai-cells = < 0x01 >; sound-name-prefix = "TOACODEC"; resets = < 0x11 0x17 >; status = "disabled"; phandle = < 0xed >; }; audio-controller@744 { compatible = "amlogic,sm1-tohdmitx\0amlogic,g12a-tohdmitx"; reg = < 0x00 0x744 0x00 0x04 >; #sound-dai-cells = < 0x01 >; sound-name-prefix = "TOHDMITX"; resets = < 0x11 0x18 >; status = "okay"; phandle = < 0x59 >; }; audio-controller@840 { compatible = "amlogic,sm1-toddr\0amlogic,axg-toddr"; reg = < 0x00 0x840 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TODDR_D"; interrupts = < 0x00 0x31 0x01 >; clocks = < 0x11 0xab >; resets = < 0x12 0x06 0x11 0x21 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "disabled"; phandle = < 0xee >; }; audio-controller@880 { compatible = "amlogic,sm1-frddr\0amlogic,axg-frddr"; reg = < 0x00 0x880 0x00 0x2c >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "FRDDR_D"; interrupts = < 0x00 0x32 0x01 >; clocks = < 0x11 0xaa >; resets = < 0x12 0x07 0x11 0x20 >; reset-names = "arb\0rst"; amlogic,fifo-depth = < 0x100 >; status = "disabled"; phandle = < 0xef >; }; }; audio-controller@61000 { compatible = "amlogic,sm1-pdm\0amlogic,axg-pdm"; reg = < 0x00 0x61000 0x00 0x34 >; #sound-dai-cells = < 0x00 >; sound-name-prefix = "PDM"; clocks = < 0x11 0x1e 0x11 0x39 0x11 0x3a >; clock-names = "pclk\0dclk\0sysclk"; resets = < 0x11 0x00 >; status = "okay"; pinctrl-0 = < 0x13 0x14 >; pinctrl-names = "default"; phandle = < 0x5b >; }; }; bus@ff800000 { compatible = "simple-bus"; reg = < 0x00 0xff800000 0x00 0x100000 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0xff800000 0x00 0x100000 >; phandle = < 0xf0 >; sys-ctrl@0 { compatible = "amlogic,meson-gx-ao-sysctrl\0simple-mfd\0syscon"; reg = < 0x00 0x00 0x00 0x100 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0x00 0x00 0x100 >; phandle = < 0x0f >; clock-controller { compatible = "amlogic,meson-g12a-aoclkc"; #clock-cells = < 0x01 >; #reset-cells = < 0x01 >; clocks = < 0x0e 0x02 0x0a >; clock-names = "xtal\0mpeg-clk"; phandle = < 0x16 >; }; pinctrl@14 { compatible = "amlogic,meson-g12a-aobus-pinctrl"; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; phandle = < 0x15 >; bank@14 { reg = < 0x00 0x14 0x00 0x08 0x00 0x1c 0x00 0x08 0x00 0x24 0x00 0x14 >; reg-names = "mux\0ds\0gpio"; gpio-controller; #gpio-cells = < 0x02 >; gpio-ranges = < 0x15 0x00 0x00 0x0f >; phandle = < 0x48 >; }; i2c_ao_sck_pins { phandle = < 0xf1 >; mux { groups = "i2c_ao_sck"; function = "i2c_ao"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c_ao_sda { phandle = < 0xf2 >; mux { groups = "i2c_ao_sda"; function = "i2c_ao"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c_ao_sck_e { phandle = < 0xf3 >; mux { groups = "i2c_ao_sck_e"; function = "i2c_ao"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; i2c_ao_sda_e { phandle = < 0xf4 >; mux { groups = "i2c_ao_sda_e"; function = "i2c_ao"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; mclk0-ao { phandle = < 0xf5 >; mux { groups = "mclk0_ao"; function = "mclk0_ao"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-din0 { phandle = < 0xf6 >; mux { groups = "tdm_ao_b_din0"; function = "tdm_ao_b"; bias-disable; }; }; spdif-ao-out { phandle = < 0xf7 >; mux { groups = "spdif_ao_out"; function = "spdif_ao_out"; drive-strength-microamp = < 0x1f4 >; bias-disable; }; }; tdm-ao-b-din1 { phandle = < 0xf8 >; mux { groups = "tdm_ao_b_din1"; function = "tdm_ao_b"; bias-disable; }; }; tdm-ao-b-din2 { phandle = < 0xf9 >; mux { groups = "tdm_ao_b_din2"; function = "tdm_ao_b"; bias-disable; }; }; tdm-ao-b-dout0 { phandle = < 0xfa >; mux { groups = "tdm_ao_b_dout0"; function = "tdm_ao_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-dout1 { phandle = < 0xfb >; mux { groups = "tdm_ao_b_dout1"; function = "tdm_ao_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-dout2 { phandle = < 0xfc >; mux { groups = "tdm_ao_b_dout2"; function = "tdm_ao_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-fs { phandle = < 0xfd >; mux { groups = "tdm_ao_b_fs"; function = "tdm_ao_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-sclk { phandle = < 0xfe >; mux { groups = "tdm_ao_b_sclk"; function = "tdm_ao_b"; bias-disable; drive-strength-microamp = < 0xbb8 >; }; }; tdm-ao-b-slv-fs { phandle = < 0xff >; mux { groups = "tdm_ao_b_slv_fs"; function = "tdm_ao_b"; bias-disable; }; }; tdm-ao-b-slv-sclk { phandle = < 0x100 >; mux { groups = "tdm_ao_b_slv_sclk"; function = "tdm_ao_b"; bias-disable; }; }; uart-a-ao { phandle = < 0x1b >; mux { groups = "uart_ao_a_tx\0uart_ao_a_rx"; function = "uart_ao_a"; bias-disable; }; }; uart-b-ao { phandle = < 0x101 >; mux { groups = "uart_ao_b_tx_8\0uart_ao_b_rx_9"; function = "uart_ao_b"; bias-disable; }; }; uart-ao-a-cts-rts { phandle = < 0x102 >; mux { groups = "uart_ao_a_cts\0uart_ao_a_rts"; function = "uart_ao_a"; bias-disable; }; }; uart-ao-b-2-3 { phandle = < 0x103 >; mux { groups = "uart_ao_b_tx_2\0uart_ao_b_rx_3"; function = "uart_ao_b"; bias-disable; }; }; uart-ao-b-8-9 { phandle = < 0x104 >; mux { groups = "uart_ao_b_tx_8\0uart_ao_b_rx_9"; function = "uart_ao_b"; bias-disable; }; }; uart-ao-b-cts-rts { phandle = < 0x105 >; mux { groups = "uart_ao_b_cts\0uart_ao_b_rts"; function = "uart_ao_b"; bias-disable; }; }; pwm-a-e { phandle = < 0x106 >; mux { groups = "pwm_a_e"; function = "pwm_a_e"; bias-disable; }; }; pwm-ao-a { phandle = < 0x1c >; mux { groups = "pwm_ao_a"; function = "pwm_ao_a"; bias-disable; }; }; pwm-ao-b { phandle = < 0x107 >; mux { groups = "pwm_ao_b"; function = "pwm_ao_b"; bias-disable; }; }; pwm-ao-c-4 { phandle = < 0x108 >; mux { groups = "pwm_ao_c_4"; function = "pwm_ao_c"; bias-disable; }; }; pwm-ao-c-6 { phandle = < 0x109 >; mux { groups = "pwm_ao_c_6"; function = "pwm_ao_c"; bias-disable; }; }; pwm-ao-d-5 { phandle = < 0x10a >; mux { groups = "pwm_ao_d_5"; function = "pwm_ao_d"; bias-disable; }; }; pwm-ao-d-10 { phandle = < 0x10b >; mux { groups = "pwm_ao_d_10"; function = "pwm_ao_d"; bias-disable; }; }; pwm-ao-d-e { phandle = < 0x1a >; mux { groups = "pwm_ao_d_e"; function = "pwm_ao_d"; }; }; remote-input-ao { phandle = < 0x1d >; mux { groups = "remote_ao_input"; function = "remote_ao_input"; bias-disable; }; }; remote-out { phandle = < 0x10c >; mux { groups = "remote_ao_out"; function = "remote_ao_out"; bias-disable; }; }; }; }; rtc@a8 { compatible = "amlogic,meson-vrtc"; reg = < 0x00 0xa8 0x00 0x04 >; phandle = < 0x10d >; }; cec@100 { compatible = "amlogic,meson-gx-ao-cec"; reg = < 0x00 0x100 0x00 0x14 >; interrupts = < 0x00 0xc7 0x01 >; clocks = < 0x16 0x1b >; clock-names = "core"; status = "disabled"; pinctrl-0 = < 0x17 >; pinctrl-names = "default"; hdmi-phandle = < 0x18 >; phandle = < 0x10e >; }; ao-secure@140 { compatible = "amlogic,meson-gx-ao-secure\0syscon"; reg = < 0x00 0x140 0x00 0x140 >; amlogic,has-chip-id; phandle = < 0x0d >; }; cec@280 { compatible = "amlogic,meson-sm1-ao-cec"; reg = < 0x00 0x280 0x00 0x1c >; interrupts = < 0x00 0xcb 0x01 >; clocks = < 0x16 0x13 >; clock-names = "oscin"; status = "okay"; pinctrl-0 = < 0x19 >; pinctrl-names = "default"; hdmi-phandle = < 0x18 >; phandle = < 0x10f >; }; pwm@2000 { compatible = "amlogic,meson-g12a-ao-pwm-cd"; reg = < 0x00 0x2000 0x00 0x20 >; #pwm-cells = < 0x03 >; status = "okay"; pinctrl-0 = < 0x1a >; pinctrl-names = "default"; clocks = < 0x0e >; clock-names = "clkin1"; phandle = < 0x4c >; }; serial@3000 { compatible = "amlogic,meson-g12a-uart\0amlogic,meson-gx-uart\0amlogic,meson-ao-uart"; reg = < 0x00 0x3000 0x00 0x18 >; interrupts = < 0x00 0xc1 0x01 >; clocks = < 0x0e 0x16 0x04 0x0e >; clock-names = "xtal\0pclk\0baud"; status = "okay"; pinctrl-0 = < 0x1b >; pinctrl-names = "default"; phandle = < 0x110 >; }; serial@4000 { compatible = "amlogic,meson-g12a-uart\0amlogic,meson-gx-uart\0amlogic,meson-ao-uart"; reg = < 0x00 0x4000 0x00 0x18 >; interrupts = < 0x00 0xc5 0x01 >; clocks = < 0x0e 0x16 0x06 0x0e >; clock-names = "xtal\0pclk\0baud"; status = "disabled"; phandle = < 0x111 >; }; i2c@5000 { compatible = "amlogic,meson-axg-i2c"; status = "disabled"; reg = < 0x00 0x5000 0x00 0x20 >; interrupts = < 0x00 0xc3 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x18 >; phandle = < 0x112 >; }; pwm@7000 { compatible = "amlogic,meson-g12a-ao-pwm-ab"; reg = < 0x00 0x7000 0x00 0x20 >; #pwm-cells = < 0x03 >; status = "okay"; pinctrl-0 = < 0x1c >; pinctrl-names = "default"; clocks = < 0x0e >; clock-names = "clkin0"; phandle = < 0x4a >; }; ir@8000 { compatible = "amlogic,meson-gxbb-ir"; reg = < 0x00 0x8000 0x00 0x20 >; interrupts = < 0x00 0xc4 0x01 >; status = "okay"; pinctrl-0 = < 0x1d >; pinctrl-names = "default"; phandle = < 0x113 >; }; adc@9000 { compatible = "amlogic,meson-g12a-saradc\0amlogic,meson-saradc"; reg = < 0x00 0x9000 0x00 0x48 >; #io-channel-cells = < 0x01 >; interrupts = < 0x00 0xc8 0x01 >; clocks = < 0x0e 0x16 0x08 0x16 0x12 0x16 0x10 >; clock-names = "clkin\0core\0adc_clk\0adc_sel"; status = "okay"; vref-supply = < 0x1e >; phandle = < 0x114 >; }; }; video-decoder@ff620000 { compatible = "amlogic,sm1-vdec"; reg = < 0x00 0xff620000 0x00 0x10000 0x00 0xffd0e180 0x00 0xe4 >; reg-names = "dos\0esparser"; interrupts = < 0x00 0x2c 0x01 0x00 0x20 0x01 >; interrupt-names = "vdec\0esparser"; amlogic,ao-sysctrl = < 0x0f >; amlogic,canvas = < 0x1f >; clocks = < 0x02 0x2e 0x02 0x10 0x02 0xcc 0x02 0xcf 0x02 0xd2 >; clock-names = "dos_parser\0dos\0vdec_1\0vdec_hevc\0vdec_hevcf"; resets = < 0x05 0x28 >; reset-names = "esparser"; phandle = < 0x115 >; }; vpu@ff900000 { compatible = "amlogic,meson-g12a-vpu"; reg = < 0x00 0xff900000 0x00 0x100000 0x00 0xff63c000 0x00 0x1000 >; reg-names = "vpu\0hhi"; interrupts = < 0x00 0x03 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; amlogic,canvas = < 0x1f >; power-domains = < 0x03 0x00 >; phandle = < 0x116 >; port@0 { reg = < 0x00 >; phandle = < 0x117 >; }; port@1 { reg = < 0x01 >; phandle = < 0x118 >; endpoint { remote-endpoint = < 0x20 >; phandle = < 0x0a >; }; }; }; interrupt-controller@ffc01000 { compatible = "arm,gic-400"; reg = < 0x00 0xffc01000 0x00 0x1000 0x00 0xffc02000 0x00 0x2000 0x00 0xffc04000 0x00 0x2000 0x00 0xffc06000 0x00 0x2000 >; interrupt-controller; interrupts = < 0x01 0x09 0xff04 >; #interrupt-cells = < 0x03 >; #address-cells = < 0x00 >; phandle = < 0x01 >; }; bus@ffd00000 { compatible = "simple-bus"; reg = < 0x00 0xffd00000 0x00 0x100000 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges = < 0x00 0x00 0x00 0xffd00000 0x00 0x100000 >; phandle = < 0x119 >; reset-controller@1004 { compatible = "amlogic,meson-axg-reset"; reg = < 0x00 0x1004 0x00 0x9c >; #reset-cells = < 0x01 >; phandle = < 0x05 >; }; interrupt-controller@f080 { compatible = "amlogic,meson-sm1-gpio-intc\0amlogic,meson-gpio-intc"; reg = < 0x00 0xf080 0x00 0x10 >; interrupt-controller; #interrupt-cells = < 0x02 >; amlogic,channel-interrupts = < 0x40 0x41 0x42 0x43 0x44 0x45 0x46 0x47 >; phandle = < 0x26 >; }; watchdog@f0d0 { compatible = "amlogic,meson-gxbb-wdt"; reg = < 0x00 0xf0d0 0x00 0x10 >; clocks = < 0x0e >; phandle = < 0x11a >; }; spi@13000 { compatible = "amlogic,meson-g12a-spicc"; reg = < 0x00 0x13000 0x00 0x44 >; interrupts = < 0x00 0x51 0x04 >; clocks = < 0x02 0x17 0x02 0x102 >; clock-names = "core\0pclk"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; status = "disabled"; phandle = < 0x11b >; }; spi@15000 { compatible = "amlogic,meson-g12a-spicc"; reg = < 0x00 0x15000 0x00 0x44 >; interrupts = < 0x00 0x5a 0x04 >; clocks = < 0x02 0x1d 0x02 0x105 >; clock-names = "core\0pclk"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; status = "disabled"; phandle = < 0x11c >; }; spi@14000 { compatible = "amlogic,meson-gxbb-spifc"; status = "disabled"; reg = < 0x00 0x14000 0x00 0x80 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x0a >; phandle = < 0x11d >; }; pwm@19000 { compatible = "amlogic,meson-g12a-ee-pwm"; reg = < 0x00 0x19000 0x00 0x20 >; #pwm-cells = < 0x03 >; status = "okay"; pinctrl-0 = < 0x21 >; pinctrl-names = "default"; clocks = < 0x0e >; clock-names = "clkin0"; phandle = < 0x5d >; }; pwm@1a000 { compatible = "amlogic,meson-g12a-ee-pwm"; reg = < 0x00 0x1a000 0x00 0x20 >; #pwm-cells = < 0x03 >; status = "disabled"; phandle = < 0x11e >; }; pwm@1b000 { compatible = "amlogic,meson-g12a-ee-pwm"; reg = < 0x00 0x1b000 0x00 0x20 >; #pwm-cells = < 0x03 >; status = "disabled"; phandle = < 0x11f >; }; i2c@1c000 { compatible = "amlogic,meson-axg-i2c"; status = "okay"; reg = < 0x00 0x1c000 0x00 0x20 >; interrupts = < 0x00 0x27 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x18 >; pinctrl-0 = < 0x22 0x23 >; pinctrl-names = "default"; phandle = < 0x120 >; }; i2c@1d000 { compatible = "amlogic,meson-axg-i2c"; status = "disabled"; reg = < 0x00 0x1d000 0x00 0x20 >; interrupts = < 0x00 0xd7 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x18 >; phandle = < 0x121 >; }; i2c@1e000 { compatible = "amlogic,meson-axg-i2c"; status = "disabled"; reg = < 0x00 0x1e000 0x00 0x20 >; interrupts = < 0x00 0xd6 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x18 >; phandle = < 0x122 >; }; i2c@1f000 { compatible = "amlogic,meson-axg-i2c"; status = "disabled"; reg = < 0x00 0x1f000 0x00 0x20 >; interrupts = < 0x00 0x15 0x01 >; #address-cells = < 0x01 >; #size-cells = < 0x00 >; clocks = < 0x02 0x18 >; phandle = < 0x123 >; }; clock-measure@18000 { compatible = "amlogic,meson-sm1-clk-measure"; reg = < 0x00 0x18000 0x00 0x10 >; phandle = < 0x124 >; }; serial@22000 { compatible = "amlogic,meson-g12a-uart\0amlogic,meson-gx-uart"; reg = < 0x00 0x22000 0x00 0x18 >; interrupts = < 0x00 0x5d 0x01 >; clocks = < 0x0e 0x02 0x39 0x0e >; clock-names = "xtal\0pclk\0baud"; status = "disabled"; phandle = < 0x125 >; }; serial@23000 { compatible = "amlogic,meson-g12a-uart\0amlogic,meson-gx-uart"; reg = < 0x00 0x23000 0x00 0x18 >; interrupts = < 0x00 0x4b 0x01 >; clocks = < 0x0e 0x02 0x2a 0x0e >; clock-names = "xtal\0pclk\0baud"; status = "disabled"; phandle = < 0x126 >; }; serial@24000 { compatible = "amlogic,meson-g12a-uart\0amlogic,meson-gx-uart"; reg = < 0x00 0x24000 0x00 0x18 >; interrupts = < 0x00 0x1a 0x01 >; clocks = < 0x0e 0x02 0x1c 0x0e >; clock-names = "xtal\0pclk\0baud"; status = "okay"; fifo-size = < 0x80 >; pinctrl-0 = < 0x24 0x25 >; pinctrl-names = "default"; uart-has-rtscts; phandle = < 0x127 >; bluetooth { compatible = "brcm,bcm43438-bt"; interrupt-parent = < 0x26 >; interrupts = < 0x5f 0x04 >; interrupt-names = "host-wakeup"; shutdown-gpios = < 0x27 0x52 0x00 >; max-speed = < 0x1e8480 >; clocks = < 0x28 >; clock-names = "lpo"; vbat-supply = < 0x29 >; vddio-supply = < 0x1e >; }; }; }; sd@ffe03000 { compatible = "amlogic,meson-axg-mmc"; reg = < 0x00 0xffe03000 0x00 0x800 >; interrupts = < 0x00 0xbd 0x04 >; status = "okay"; clocks = < 0x02 0x21 0x02 0x3c 0x02 0x02 >; clock-names = "core\0clkin0\0clkin1"; resets = < 0x05 0x2c >; pinctrl-0 = < 0x2a >; pinctrl-1 = < 0x2b >; pinctrl-names = "default\0clk-gate"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; bus-width = < 0x04 >; cap-sd-highspeed; sd-uhs-sdr50; max-frequency = < 0x5f5e100 >; non-removable; disable-wp; keep-power-in-suspend; mmc-pwrseq = < 0x2c >; vmmc-supply = < 0x29 >; vqmmc-supply = < 0x1e >; phandle = < 0x128 >; wifi@1 { reg = < 0x01 >; compatible = "brcm,bcm4329-fmac"; phandle = < 0x129 >; }; }; sd@ffe05000 { compatible = "amlogic,meson-axg-mmc"; reg = < 0x00 0xffe05000 0x00 0x800 >; interrupts = < 0x00 0xbe 0x04 >; status = "okay"; clocks = < 0x02 0x22 0x02 0x3d 0x02 0x02 >; clock-names = "core\0clkin0\0clkin1"; resets = < 0x05 0x2d >; pinctrl-0 = < 0x2d >; pinctrl-1 = < 0x2e >; pinctrl-names = "default\0clk-gate"; bus-width = < 0x04 >; cap-sd-highspeed; max-frequency = < 0x2faf080 >; disable-wp; cd-gpios = < 0x27 0x2f 0x01 >; vmmc-supply = < 0x29 >; vqmmc-supply = < 0x29 >; phandle = < 0x12a >; }; mmc@ffe07000 { compatible = "amlogic,meson-axg-mmc"; reg = < 0x00 0xffe07000 0x00 0x800 >; interrupts = < 0x00 0xbf 0x04 >; status = "okay"; clocks = < 0x02 0x23 0x02 0x3e 0x02 0x02 >; clock-names = "core\0clkin0\0clkin1"; resets = < 0x05 0x2e >; pinctrl-0 = < 0x2f 0x30 0x31 >; pinctrl-1 = < 0x32 >; pinctrl-names = "default\0clk-gate"; bus-width = < 0x08 >; cap-mmc-highspeed; mmc-ddr-1_8v; mmc-hs200-1_8v; max-frequency = < 0xbebc200 >; non-removable; disable-wp; mmc-pwrseq = < 0x33 >; vmmc-supply = < 0x29 >; vqmmc-supply = < 0x34 >; phandle = < 0x12b >; }; usb@ffe09000 { status = "okay"; compatible = "amlogic,meson-g12a-usb-ctrl"; reg = < 0x00 0xffe09000 0x00 0xa0 >; interrupts = < 0x00 0x10 0x04 >; #address-cells = < 0x02 >; #size-cells = < 0x02 >; ranges; clocks = < 0x02 0x2f >; resets = < 0x05 0x22 >; dr_mode = "otg"; phys = < 0x35 0x36 0x06 0x04 >; phy-names = "usb2-phy0\0usb2-phy1\0usb3-phy0"; power-domains = < 0x03 0x02 >; phandle = < 0x12c >; usb@ff400000 { compatible = "amlogic,meson-g12a-usb\0snps,dwc2"; reg = < 0x00 0xff400000 0x00 0x40000 >; interrupts = < 0x00 0x1f 0x04 >; clocks = < 0x02 0x37 >; clock-names = "otg"; phys = < 0x36 >; phy-names = "usb2-phy"; dr_mode = "peripheral"; g-rx-fifo-size = < 0xc0 >; g-np-tx-fifo-size = < 0x80 >; g-tx-fifo-size = < 0x80 0x80 0x10 0x10 0x10 >; phandle = < 0x12d >; }; usb@ff500000 { compatible = "snps,dwc3"; reg = < 0x00 0xff500000 0x00 0x100000 >; interrupts = < 0x00 0x1e 0x04 >; dr_mode = "host"; snps,dis_u2_susphy_quirk; snps,quirk-frame-length-adjustment = < 0x20 >; snps,parkmode-disable-ss-quirk; phandle = < 0x12e >; }; }; gpu@ffe40000 { compatible = "amlogic,meson-g12a-mali\0arm,mali-bifrost"; reg = < 0x00 0xffe40000 0x00 0x40000 >; interrupt-parent = < 0x01 >; interrupts = < 0x00 0xa2 0x04 0x00 0xa1 0x04 0x00 0xa0 0x04 >; interrupt-names = "job\0mmu\0gpu"; clocks = < 0x02 0xaf >; resets = < 0x05 0x14 0x05 0x4e >; operating-points-v2 = < 0x37 >; #cooling-cells = < 0x02 >; phandle = < 0x41 >; }; }; thermal-zones { cpu-thermal { polling-delay = < 0x3e8 >; polling-delay-passive = < 0x64 >; thermal-sensors = < 0x38 >; phandle = < 0x12f >; trips { cpu-passive { temperature = < 0x14c08 >; hysteresis = < 0x7d0 >; type = "passive"; phandle = < 0x39 >; }; cpu-hot { temperature = < 0x17318 >; hysteresis = < 0x7d0 >; type = "hot"; phandle = < 0x3e >; }; cpu-critical { temperature = < 0x1adb0 >; hysteresis = < 0x7d0 >; type = "critical"; phandle = < 0x130 >; }; }; cooling-maps { map0 { trip = < 0x39 >; cooling-device = < 0x3a 0xffffffff 0xffffffff 0x3b 0xffffffff 0xffffffff 0x3c 0xffffffff 0xffffffff 0x3d 0xffffffff 0xffffffff >; }; map1 { trip = < 0x3e >; cooling-device = < 0x3a 0xffffffff 0xffffffff 0x3b 0xffffffff 0xffffffff 0x3c 0xffffffff 0xffffffff 0x3d 0xffffffff 0xffffffff >; }; }; }; ddr-thermal { polling-delay = < 0x3e8 >; polling-delay-passive = < 0x64 >; thermal-sensors = < 0x3f >; phandle = < 0x131 >; trips { ddr-passive { temperature = < 0x14c08 >; hysteresis = < 0x7d0 >; type = "passive"; phandle = < 0x40 >; }; ddr-critical { temperature = < 0x1adb0 >; hysteresis = < 0x7d0 >; type = "critical"; phandle = < 0x132 >; }; }; cooling-maps { map { trip = < 0x40 >; cooling-device = < 0x41 0xffffffff 0xffffffff >; }; }; }; }; timer { compatible = "arm,armv8-timer"; interrupts = < 0x01 0x0d 0xff08 0x01 0x0e 0xff08 0x01 0x0b 0xff08 0x01 0x0a 0xff08 >; arm,no-tick-in-suspend; }; xtal-clk { compatible = "fixed-clock"; clock-frequency = < 0x16e3600 >; clock-output-names = "xtal"; #clock-cells = < 0x00 >; phandle = < 0x0e >; }; audio-controller-0 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TDM_A"; clocks = < 0x11 0x31 0x11 0x4f 0x11 0x56 >; clock-names = "mclk\0sclk\0lrclk"; status = "okay"; pinctrl-0 = < 0x42 0x43 0x44 >; pinctrl-names = "default"; assigned-clocks = < 0x11 0xa0 0x11 0x9d >; assigned-clock-parents = < 0x11 0x4f 0x11 0x56 >; assigned-clock-rates = < 0x00 0x00 >; phandle = < 0x57 >; }; audio-controller-1 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TDM_B"; clocks = < 0x11 0x32 0x11 0x50 0x11 0x57 >; clock-names = "mclk\0sclk\0lrclk"; status = "okay"; phandle = < 0x5a >; }; audio-controller-2 { compatible = "amlogic,axg-tdm-iface"; #sound-dai-cells = < 0x00 >; sound-name-prefix = "TDM_C"; clocks = < 0x11 0x33 0x11 0x51 0x11 0x58 >; clock-names = "mclk\0sclk\0lrclk"; status = "disabled"; phandle = < 0x133 >; }; cpus { #address-cells = < 0x02 >; #size-cells = < 0x00 >; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a55"; reg = < 0x00 0x00 >; enable-method = "psci"; next-level-cache = < 0x45 >; #cooling-cells = < 0x02 >; cpu-supply = < 0x46 >; operating-points-v2 = < 0x47 >; clocks = < 0x02 0xbb >; clock-latency = < 0xc350 >; phandle = < 0x3a >; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a55"; reg = < 0x00 0x01 >; enable-method = "psci"; next-level-cache = < 0x45 >; #cooling-cells = < 0x02 >; cpu-supply = < 0x46 >; operating-points-v2 = < 0x47 >; clocks = < 0x02 0xfd >; clock-latency = < 0xc350 >; phandle = < 0x3b >; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a55"; reg = < 0x00 0x02 >; enable-method = "psci"; next-level-cache = < 0x45 >; #cooling-cells = < 0x02 >; cpu-supply = < 0x46 >; operating-points-v2 = < 0x47 >; clocks = < 0x02 0xfe >; clock-latency = < 0xc350 >; phandle = < 0x3c >; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a55"; reg = < 0x00 0x03 >; enable-method = "psci"; next-level-cache = < 0x45 >; #cooling-cells = < 0x02 >; cpu-supply = < 0x46 >; operating-points-v2 = < 0x47 >; clocks = < 0x02 0xff >; clock-latency = < 0xc350 >; phandle = < 0x3d >; }; l2-cache0 { compatible = "cache"; phandle = < 0x45 >; }; }; opp-table { compatible = "operating-points-v2"; opp-shared; phandle = < 0x47 >; opp-1000000000 { opp-hz = < 0x00 0x3b9aca00 >; opp-microvolt = < 0xbbfd0 >; }; opp-1200000000 { opp-hz = < 0x00 0x47868c00 >; opp-microvolt = < 0xbe6e0 >; }; opp-1404000000 { opp-hz = < 0x00 0x53af5700 >; opp-microvolt = < 0xc0df0 >; }; opp-1500000000 { opp-hz = < 0x00 0x59682f00 >; opp-microvolt = < 0xc3500 >; }; opp-1608000000 { opp-hz = < 0x00 0x5fd82200 >; opp-microvolt = < 0xc5c10 >; }; opp-1704000000 { opp-hz = < 0x00 0x6590fa00 >; opp-microvolt = < 0xcf850 >; }; opp-1800000000 { opp-hz = < 0x00 0x6b49d200 >; opp-microvolt = < 0xdbba0 >; }; opp-1908000000 { opp-hz = < 0x00 0x71b9c500 >; opp-microvolt = < 0xe7ef0 >; }; opp-2016000000 { opp-hz = < 0x00 0x7829b800 >; opp-microvolt = < 0xf4240 >; }; opp-2100000000 { opp-hz = < 0x00 0x7d2b7500 >; opp-microvolt = < 0xf9830 >; }; }; audio-codec-0 { compatible = "maxim,max98357a"; #sound-dai-cells = < 0x00 >; sound-name-prefix = "U16"; sdmode-gpios = < 0x27 0x49 0x00 >; phandle = < 0x58 >; }; audio-codec-1 { #sound-dai-cells = < 0x00 >; compatible = "dmic-codec"; num-channels = < 0x02 >; wakeup-delay-ms = < 0x32 >; status = "okay"; sound-name-prefix = "MIC"; phandle = < 0x5c >; }; emmc-pwrseq { compatible = "mmc-pwrseq-emmc"; reset-gpios = < 0x27 0x25 0x01 >; phandle = < 0x33 >; }; gpio-keys { compatible = "gpio-keys"; key-1 { label = [ 41 00 ]; linux,code = < 0x100 >; gpios = < 0x27 0x16 0x01 >; interrupt-parent = < 0x26 >; interrupts = < 0x22 0x03 >; }; key-2 { label = [ 42 00 ]; linux,code = < 0x101 >; gpios = < 0x27 0x17 0x01 >; interrupt-parent = < 0x26 >; interrupts = < 0x23 0x03 >; }; key-3 { label = [ 43 00 ]; linux,code = < 0x102 >; gpios = < 0x48 0x02 0x01 >; interrupt-parent = < 0x26 >; interrupts = < 0x02 0x03 >; }; key-mic-mute { label = "MicMute"; linux,code = < 0x0e >; linux,input-type = < 0x05 >; gpios = < 0x48 0x0e 0x01 >; interrupt-parent = < 0x26 >; interrupts = < 0x63 0x03 >; }; key-power { label = "PowerKey"; linux,code = < 0x74 >; gpios = < 0x48 0x03 0x01 >; interrupt-parent = < 0x26 >; interrupts = < 0x03 0x03 >; }; }; hdmi-connector { compatible = "hdmi-connector"; type = [ 61 00 ]; port { endpoint { remote-endpoint = < 0x49 >; phandle = < 0x0b >; }; }; }; led-controller-1 { compatible = "gpio-leds"; led-1 { label = "sei610:blue:bt"; gpios = < 0x27 0x30 0x07 >; default-state = "off"; }; }; led-controller-2 { compatible = "pwm-leds"; led-2 { label = "sei610:red:power"; pwms = < 0x4a 0x00 0x7736 0x00 >; max-brightness = < 0xff >; linux,default-trigger = "default-on"; active-low; }; }; memory@0 { device_type = "memory"; reg = < 0x00 0x00 0x00 0x40000000 >; }; regulator-ao_5v { compatible = "regulator-fixed"; regulator-name = "AO_5V"; regulator-min-microvolt = < 0x4c4b40 >; regulator-max-microvolt = < 0x4c4b40 >; vin-supply = < 0x4b >; regulator-always-on; phandle = < 0x134 >; }; regulator-dc_in { compatible = "regulator-fixed"; regulator-name = "DC_IN"; regulator-min-microvolt = < 0x4c4b40 >; regulator-max-microvolt = < 0x4c4b40 >; regulator-always-on; phandle = < 0x4b >; }; regulator-emmc_1v8 { compatible = "regulator-fixed"; regulator-name = "EMMC_1V8"; regulator-min-microvolt = < 0x1b7740 >; regulator-max-microvolt = < 0x1b7740 >; vin-supply = < 0x29 >; regulator-always-on; phandle = < 0x34 >; }; regulator-vddao_3v3 { compatible = "regulator-fixed"; regulator-name = "VDDAO_3V3"; regulator-min-microvolt = < 0x325aa0 >; regulator-max-microvolt = < 0x325aa0 >; vin-supply = < 0x4b >; regulator-always-on; phandle = < 0x29 >; }; regulator-vddao_3v3_t { compatible = "regulator-fixed"; regulator-name = "VDDAO_3V3_T"; regulator-min-microvolt = < 0x325aa0 >; regulator-max-microvolt = < 0x325aa0 >; vin-supply = < 0x29 >; gpio = < 0x27 0x18 0x06 >; regulator-always-on; phandle = < 0x135 >; }; regulator-vddcpu { compatible = "pwm-regulator"; regulator-name = "VDDCPU"; regulator-min-microvolt = < 0xa8750 >; regulator-max-microvolt = < 0x100590 >; pwm-supply = < 0x4b >; pwms = < 0x4c 0x01 0x5dc 0x00 >; pwm-dutycycle-range = < 0x64 0x00 >; regulator-boot-on; regulator-always-on; phandle = < 0x46 >; }; regulator-vddio_ao1v8 { compatible = "regulator-fixed"; regulator-name = "VDDIO_AO1V8"; regulator-min-microvolt = < 0x1b7740 >; regulator-max-microvolt = < 0x1b7740 >; vin-supply = < 0x29 >; regulator-always-on; phandle = < 0x1e >; }; sdio-pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = < 0x27 0x47 0x01 >; clocks = < 0x28 >; clock-names = "ext_clock"; phandle = < 0x2c >; }; sound { compatible = "amlogic,axg-sound-card"; model = "SEI610"; audio-aux-devs = < 0x4d 0x4e 0x4f 0x50 >; audio-routing = "TDMOUT_A IN 0\0FRDDR_A OUT 0\0TDMOUT_A IN 1\0FRDDR_B OUT 0\0TDMOUT_A IN 2\0FRDDR_C OUT 0\0TDM_A Playback\0TDMOUT_A OUT\0TDMOUT_B IN 0\0FRDDR_A OUT 1\0TDMOUT_B IN 1\0FRDDR_B OUT 1\0TDMOUT_B IN 2\0FRDDR_C OUT 1\0TDM_B Playback\0TDMOUT_B OUT\0TODDR_A IN 4\0PDM Capture\0TODDR_B IN 4\0PDM Capture\0TODDR_C IN 4\0PDM Capture\0TDMIN_A IN 0\0TDM_A Capture\0TDMIN_A IN 3\0TDM_A Loopback\0TDMIN_B IN 0\0TDM_A Capture\0TDMIN_B IN 3\0TDM_A Loopback\0TDMIN_A IN 1\0TDM_B Capture\0TDMIN_A IN 4\0TDM_B Loopback\0TDMIN_B IN 1\0TDM_B Capture\0TDMIN_B IN 4\0TDM_B Loopback\0TODDR_A IN 0\0TDMIN_A OUT\0TODDR_B IN 0\0TDMIN_A OUT\0TODDR_C IN 0\0TDMIN_A OUT\0TODDR_A IN 1\0TDMIN_B OUT\0TODDR_B IN 1\0TDMIN_B OUT\0TODDR_C IN 1\0TDMIN_B OUT"; assigned-clocks = < 0x02 0x0d 0x02 0x0b 0x02 0x0c >; assigned-clock-parents = < 0x00 0x00 0x00 >; assigned-clock-rates = < 0x11940000 0x10266000 0x17700000 >; status = "okay"; dai-link-0 { sound-dai = < 0x51 >; }; dai-link-1 { sound-dai = < 0x52 >; }; dai-link-2 { sound-dai = < 0x53 >; }; dai-link-3 { sound-dai = < 0x54 >; }; dai-link-4 { sound-dai = < 0x55 >; }; dai-link-5 { sound-dai = < 0x56 >; }; dai-link-6 { sound-dai = < 0x57 >; dai-format = "i2s"; dai-tdm-slot-tx-mask-0 = < 0x01 0x01 >; mclk-fs = < 0x100 >; codec-0 { sound-dai = < 0x58 >; }; codec-1 { sound-dai = < 0x59 0x00 >; }; }; dai-link-7 { sound-dai = < 0x5a >; dai-format = "i2s"; dai-tdm-slot-tx-mask-0 = < 0x01 0x01 >; dai-tdm-slot-tx-mask-1 = < 0x01 0x01 >; dai-tdm-slot-tx-mask-2 = < 0x01 0x01 >; dai-tdm-slot-tx-mask-3 = < 0x01 0x01 >; mclk-fs = < 0x100 >; codec { sound-dai = < 0x59 0x01 >; }; }; dai-link-8 { sound-dai = < 0x5b >; codec { sound-dai = < 0x5c >; }; }; dai-link-9 { sound-dai = < 0x59 0x03 >; codec { sound-dai = < 0x18 >; }; }; }; wifi32k { compatible = "pwm-clock"; #clock-cells = < 0x00 >; clock-frequency = < 0x8000 >; pwms = < 0x5d 0x00 0x7736 0x00 >; phandle = < 0x28 >; }; __symbols__ { simplefb_cvbs = "/chosen/framebuffer-cvbs"; simplefb_hdmi = "/chosen/framebuffer-hdmi"; efuse = "/efuse"; gpu_opp_table = "/opp-table-gpu"; secmon_reserved = "/reserved-memory/secmon@5000000"; secmon_reserved_bl32 = "/reserved-memory/secmon@5300000"; sm = "/secure-monitor"; pcie = "/soc/pcie@fc000000"; ethmac = "/soc/ethernet@ff3f0000"; mdio0 = "/soc/ethernet@ff3f0000/mdio"; apb = "/soc/bus@ff600000"; hdmi_tx = "/soc/bus@ff600000/hdmi-tx@0"; hdmi_tx_venc_port = "/soc/bus@ff600000/hdmi-tx@0/port@0"; hdmi_tx_in = "/soc/bus@ff600000/hdmi-tx@0/port@0/endpoint"; hdmi_tx_tmds_port = "/soc/bus@ff600000/hdmi-tx@0/port@1"; hdmi_tx_tmds_out = "/soc/bus@ff600000/hdmi-tx@0/port@1/endpoint"; apb_efuse = "/soc/bus@ff600000/bus@30000"; hwrng = "/soc/bus@ff600000/bus@30000/rng@218"; acodec = "/soc/bus@ff600000/audio-controller@32000"; periphs = "/soc/bus@ff600000/bus@34400"; periphs_pinctrl = "/soc/bus@ff600000/bus@34400/pinctrl@40"; gpio = "/soc/bus@ff600000/bus@34400/pinctrl@40/bank@40"; cec_ao_a_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/cec_ao_a_h"; cec_ao_b_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/cec_ao_b_h"; emmc_ctrl_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/emmc-ctrl"; emmc_data_4b_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/emmc-data-4b"; emmc_data_8b_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/emmc-data-8b"; emmc_ds_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/emmc-ds"; emmc_clk_gate_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/emmc_clk_gate"; hdmitx_ddc_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/hdmitx_ddc"; hdmitx_hpd_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/hdmitx_hpd"; i2c0_sda_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sda-c"; i2c0_sck_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sck-c"; i2c0_sda_z0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sda-z0"; i2c0_sck_z1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sck-z1"; i2c0_sda_z7_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sda-z7"; i2c0_sda_z8_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c0-sda-z8"; i2c1_sda_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sda-x"; i2c1_sck_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sck-x"; i2c1_sda_h2_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sda-h2"; i2c1_sck_h3_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sck-h3"; i2c1_sda_h6_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sda-h6"; i2c1_sck_h7_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c1-sck-h7"; i2c2_sda_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c2-sda-x"; i2c2_sck_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c2-sck-x"; i2c2_sda_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c2-sda-z"; i2c2_sck_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c2-sck-z"; i2c3_sda_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c3-sda-h"; i2c3_sck_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c3-sck-h"; i2c3_sda_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c3-sda-a"; i2c3_sck_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/i2c3-sck-a"; remote_input_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/remote-input"; mclk0_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/mclk0-a"; mclk1_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/mclk1-a"; mclk1_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/mclk1-x"; mclk1_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/mclk1-z"; nor_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/nor"; pdm_din0_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din0-a"; pdm_din0_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din0-c"; pdm_din0_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din0-x"; pdm_din0_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din0-z"; pdm_din1_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din1-a"; pdm_din1_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din1-c"; pdm_din1_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din1-x"; pdm_din1_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din1-z"; pdm_din2_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din2-a"; pdm_din2_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din2-c"; pdm_din2_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din2-x"; pdm_din2_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din2-z"; pdm_din3_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din3-a"; pdm_din3_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din3-c"; pdm_din3_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din3-x"; pdm_din3_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-din3-z"; pdm_dclk_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-dclk-a"; pdm_dclk_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-dclk-c"; pdm_dclk_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-dclk-x"; pdm_dclk_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pdm-dclk-z"; pwm_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-a"; pwm_b_x7_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-b-x7"; pwm_b_x19_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-b-x19"; pwm_c_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-c-c"; pwm_c_x5_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-c-x5"; pwm_c_x8_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-c-x8"; pwm_d_x3_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-d-x3"; pwm_d_x6_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-d-x6"; pwm_e_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-e"; pwm_f_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-f-z"; pwm_f_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-f-a"; pwm_f_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-f-x"; pwm_f_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/pwm-f-h"; sdcard_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdcard_c"; sdcard_clk_gate_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdcard_clk_gate_c"; sdcard_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdcard_z"; sdcard_clk_gate_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdcard_clk_gate_z"; sdio_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdio"; sdio_clk_gate_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/sdio_clk_gate"; spdif_in_a10_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-in-a10"; spdif_in_a12_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-in-a12"; spdif_in_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-in-h"; spdif_out_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-out-h"; spdif_out_a11_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-out-a11"; spdif_out_a13_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spdif-out-a13"; spicc0_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spicc0-x"; spicc0_ss0_x_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spicc0-ss0-x"; spicc0_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spicc0-c"; spicc1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spicc1"; spicc1_ss0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/spicc1-ss0"; tdm_a_din0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-din0"; tdm_a_din1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-din1"; tdm_a_dout0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-dout0"; tdm_a_dout1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-dout1"; tdm_a_fs_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-fs"; tdm_a_sclk_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-sclk"; tdm_a_slv_fs_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-slv-fs"; tdm_a_slv_sclk_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-a-slv-sclk"; tdm_b_din0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-din0"; tdm_b_din1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-din1"; tdm_b_din2_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-din2"; tdm_b_din3_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-din3-a"; tdm_b_din3_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-din3-h"; tdm_b_dout0_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-dout0"; tdm_b_dout1_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-dout1"; tdm_b_dout2_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-dout2"; tdm_b_dout3_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-dout3-a"; tdm_b_dout3_h_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-dout3-h"; tdm_b_fs_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-fs"; tdm_b_sclk_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-sclk"; tdm_b_slv_fs_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-slv-fs"; tdm_b_slv_sclk_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-b-slv-sclk"; tdm_c_din0_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din0-a"; tdm_c_din0_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din0-z"; tdm_c_din1_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din1-a"; tdm_c_din1_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din1-z"; tdm_c_din2_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din2-a"; eth_leds_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/eth-leds"; eth_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/eth"; eth_rgmii_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/eth-rgmii"; tdm_c_din2_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din2-z"; tdm_c_din3_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din3-a"; tdm_c_din3_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-din3-z"; tdm_c_dout0_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout0-a"; tdm_c_dout0_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout0-z"; tdm_c_dout1_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout1-a"; tdm_c_dout1_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout1-z"; tdm_c_dout2_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout2-a"; tdm_c_dout2_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout2-z"; tdm_c_dout3_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout3-a"; tdm_c_dout3_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-dout3-z"; tdm_c_fs_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-fs-a"; tdm_c_fs_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-fs-z"; tdm_c_sclk_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-sclk-a"; tdm_c_sclk_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-sclk-z"; tdm_c_slv_fs_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-slv-fs-a"; tdm_c_slv_fs_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-slv-fs-z"; tdm_c_slv_sclk_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-slv-sclk-a"; tdm_c_slv_sclk_z_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/tdm-c-slv-sclk-z"; uart_a_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/uart-a"; uart_a_cts_rts_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/uart-a-cts-rts"; uart_b_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/uart-b"; uart_c_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/uart-c"; uart_c_cts_rts_pins = "/soc/bus@ff600000/bus@34400/pinctrl@40/uart-c-cts-rts"; cpu_temp = "/soc/bus@ff600000/temperature-sensor@34800"; ddr_temp = "/soc/bus@ff600000/temperature-sensor@34c00"; usb2_phy0 = "/soc/bus@ff600000/phy@36000"; dmc = "/soc/bus@ff600000/bus@38000"; canvas = "/soc/bus@ff600000/bus@38000/video-lut@48"; usb2_phy1 = "/soc/bus@ff600000/phy@3a000"; hiu = "/soc/bus@ff600000/bus@3c000"; hhi = "/soc/bus@ff600000/bus@3c000/system-controller@0"; clkc = "/soc/bus@ff600000/bus@3c000/system-controller@0/clock-controller"; pwrc = "/soc/bus@ff600000/bus@3c000/system-controller@0/power-controller"; usb3_pcie_phy = "/soc/bus@ff600000/phy@46000"; eth_phy = "/soc/bus@ff600000/mdio-multiplexer@4c000"; ext_mdio = "/soc/bus@ff600000/mdio-multiplexer@4c000/mdio@0"; int_mdio = "/soc/bus@ff600000/mdio-multiplexer@4c000/mdio@1"; internal_ephy = "/soc/bus@ff600000/mdio-multiplexer@4c000/mdio@1/ethernet-phy@8"; audio = "/soc/bus@ff600000/bus@60000"; clkc_audio = "/soc/bus@ff600000/bus@60000/clock-controller@0"; toddr_a = "/soc/bus@ff600000/bus@60000/audio-controller@100"; toddr_b = "/soc/bus@ff600000/bus@60000/audio-controller@140"; toddr_c = "/soc/bus@ff600000/bus@60000/audio-controller@180"; frddr_a = "/soc/bus@ff600000/bus@60000/audio-controller@1c0"; frddr_b = "/soc/bus@ff600000/bus@60000/audio-controller@200"; frddr_c = "/soc/bus@ff600000/bus@60000/audio-controller@240"; arb = "/soc/bus@ff600000/bus@60000/reset-controller@280"; tdmin_a = "/soc/bus@ff600000/bus@60000/audio-controller@300"; tdmin_b = "/soc/bus@ff600000/bus@60000/audio-controller@340"; tdmin_c = "/soc/bus@ff600000/bus@60000/audio-controller@380"; tdmin_lb = "/soc/bus@ff600000/bus@60000/audio-controller@3c0"; spdifin = "/soc/bus@ff600000/bus@60000/audio-controller@400"; spdifout_a = "/soc/bus@ff600000/bus@60000/audio-controller@480"; tdmout_a = "/soc/bus@ff600000/bus@60000/audio-controller@500"; tdmout_b = "/soc/bus@ff600000/bus@60000/audio-controller@540"; tdmout_c = "/soc/bus@ff600000/bus@60000/audio-controller@580"; toacodec = "/soc/bus@ff600000/bus@60000/audio-controller@740"; tohdmitx = "/soc/bus@ff600000/bus@60000/audio-controller@744"; toddr_d = "/soc/bus@ff600000/bus@60000/audio-controller@840"; frddr_d = "/soc/bus@ff600000/bus@60000/audio-controller@880"; pdm = "/soc/bus@ff600000/audio-controller@61000"; aobus = "/soc/bus@ff800000"; rti = "/soc/bus@ff800000/sys-ctrl@0"; clkc_AO = "/soc/bus@ff800000/sys-ctrl@0/clock-controller"; ao_pinctrl = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14"; gpio_ao = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/bank@14"; i2c_ao_sck_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/i2c_ao_sck_pins"; i2c_ao_sda_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/i2c_ao_sda"; i2c_ao_sck_e_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/i2c_ao_sck_e"; i2c_ao_sda_e_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/i2c_ao_sda_e"; mclk0_ao_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/mclk0-ao"; tdm_ao_b_din0_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-din0"; spdif_ao_out_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/spdif-ao-out"; tdm_ao_b_din1_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-din1"; tdm_ao_b_din2_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-din2"; tdm_ao_b_dout0_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-dout0"; tdm_ao_b_dout1_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-dout1"; tdm_ao_b_dout2_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-dout2"; tdm_ao_b_fs_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-fs"; tdm_ao_b_sclk_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-sclk"; tdm_ao_b_slv_fs_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-slv-fs"; tdm_ao_b_slv_sclk_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/tdm-ao-b-slv-sclk"; uart_ao_a_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-a-ao"; uart_ao_b_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-b-ao"; uart_ao_a_cts_rts_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-ao-a-cts-rts"; uart_ao_b_2_3_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-ao-b-2-3"; uart_ao_b_8_9_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-ao-b-8-9"; uart_ao_b_cts_rts_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/uart-ao-b-cts-rts"; pwm_a_e_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-a-e"; pwm_ao_a_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-a"; pwm_ao_b_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-b"; pwm_ao_c_4_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-c-4"; pwm_ao_c_6_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-c-6"; pwm_ao_d_5_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-d-5"; pwm_ao_d_10_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-d-10"; pwm_ao_d_e_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/pwm-ao-d-e"; remote_input_ao_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/remote-input-ao"; remote_out_ao_pins = "/soc/bus@ff800000/sys-ctrl@0/pinctrl@14/remote-out"; vrtc = "/soc/bus@ff800000/rtc@a8"; cec_AO = "/soc/bus@ff800000/cec@100"; sec_AO = "/soc/bus@ff800000/ao-secure@140"; cecb_AO = "/soc/bus@ff800000/cec@280"; pwm_AO_cd = "/soc/bus@ff800000/pwm@2000"; uart_AO = "/soc/bus@ff800000/serial@3000"; uart_AO_B = "/soc/bus@ff800000/serial@4000"; i2c_AO = "/soc/bus@ff800000/i2c@5000"; pwm_AO_ab = "/soc/bus@ff800000/pwm@7000"; ir = "/soc/bus@ff800000/ir@8000"; saradc = "/soc/bus@ff800000/adc@9000"; vdec = "/soc/video-decoder@ff620000"; vpu = "/soc/vpu@ff900000"; cvbs_vdac_port = "/soc/vpu@ff900000/port@0"; hdmi_tx_port = "/soc/vpu@ff900000/port@1"; hdmi_tx_out = "/soc/vpu@ff900000/port@1/endpoint"; gic = "/soc/interrupt-controller@ffc01000"; cbus = "/soc/bus@ffd00000"; reset = "/soc/bus@ffd00000/reset-controller@1004"; gpio_intc = "/soc/bus@ffd00000/interrupt-controller@f080"; watchdog = "/soc/bus@ffd00000/watchdog@f0d0"; spicc0 = "/soc/bus@ffd00000/spi@13000"; spicc1 = "/soc/bus@ffd00000/spi@15000"; spifc = "/soc/bus@ffd00000/spi@14000"; pwm_ef = "/soc/bus@ffd00000/pwm@19000"; pwm_cd = "/soc/bus@ffd00000/pwm@1a000"; pwm_ab = "/soc/bus@ffd00000/pwm@1b000"; i2c3 = "/soc/bus@ffd00000/i2c@1c000"; i2c2 = "/soc/bus@ffd00000/i2c@1d000"; i2c1 = "/soc/bus@ffd00000/i2c@1e000"; i2c0 = "/soc/bus@ffd00000/i2c@1f000"; clk_msr = "/soc/bus@ffd00000/clock-measure@18000"; uart_C = "/soc/bus@ffd00000/serial@22000"; uart_B = "/soc/bus@ffd00000/serial@23000"; uart_A = "/soc/bus@ffd00000/serial@24000"; sd_emmc_a = "/soc/sd@ffe03000"; brcmf = "/soc/sd@ffe03000/wifi@1"; sd_emmc_b = "/soc/sd@ffe05000"; sd_emmc_c = "/soc/mmc@ffe07000"; usb = "/soc/usb@ffe09000"; dwc2 = "/soc/usb@ffe09000/usb@ff400000"; dwc3 = "/soc/usb@ffe09000/usb@ff500000"; mali = "/soc/gpu@ffe40000"; cpu_thermal = "/thermal-zones/cpu-thermal"; cpu_passive = "/thermal-zones/cpu-thermal/trips/cpu-passive"; cpu_hot = "/thermal-zones/cpu-thermal/trips/cpu-hot"; cpu_critical = "/thermal-zones/cpu-thermal/trips/cpu-critical"; ddr_thermal = "/thermal-zones/ddr-thermal"; ddr_passive = "/thermal-zones/ddr-thermal/trips/ddr-passive"; ddr_critical = "/thermal-zones/ddr-thermal/trips/ddr-critical"; xtal = "/xtal-clk"; tdmif_a = "/audio-controller-0"; tdmif_b = "/audio-controller-1"; tdmif_c = "/audio-controller-2"; cpu0 = "/cpus/cpu@0"; cpu1 = "/cpus/cpu@1"; cpu2 = "/cpus/cpu@2"; cpu3 = "/cpus/cpu@3"; l2 = "/cpus/l2-cache0"; cpu_opp_table = "/opp-table"; mono_dac = "/audio-codec-0"; dmics = "/audio-codec-1"; emmc_pwrseq = "/emmc-pwrseq"; hdmi_connector_in = "/hdmi-connector/port/endpoint"; ao_5v = "/regulator-ao_5v"; dc_in = "/regulator-dc_in"; emmc_1v8 = "/regulator-emmc_1v8"; vddao_3v3 = "/regulator-vddao_3v3"; vddao_3v3_t = "/regulator-vddao_3v3_t"; vddcpu = "/regulator-vddcpu"; vddio_ao1v8 = "/regulator-vddio_ao1v8"; sdio_pwrseq = "/sdio-pwrseq"; wifi32k = "/wifi32k"; }; }; Edited February 6 by gnutux landia 0 Quote
SteeMan Posted February 6 Posted February 6 2 hours ago, gnutux landia said: sd-card put it on a usb with sd-card reader and boot the tvbox Why are you using USB? Does the box not have an SD card slot? Also what method are you using to enable multiboot? 0 Quote
SteeMan Posted February 6 Posted February 6 3 hours ago, gnutux landia said: I want some graphical friendly image to test the performance of tvbox as mini pc Have you used Armbian on other amlogic TV Boxes? I would never recommend using an amlogic TV Box as a mini pc. The graphical performance is poor. See the FAQ for TV boxes pined in this forum. 0 Quote
SteeMan Posted February 6 Posted February 6 1 hour ago, gnutux landia said: I decompile the dtb [meson-sm1-sei610.dtb] to dts any idea if I can edit some option on it ? You don't need to decompile.this as the original source dts is available in the Linux git source code. 0 Quote
gnutux landia Posted February 6 Author Posted February 6 I don't use multiboot. I test also to put the sd-card on the SD-Card of box and with armbian images (both - xfce bookworm or the last version Xfce of the armbian site) don't work. I test images separately, I erase the SD-Card and then try the other version image, One by One. With the steps that I already mention above. I think that I can write documents on the device and system if that boot apps like Office should work I think but I only can test it if the system armbian boot. Thanks. 0 Quote
SteeMan Posted February 6 Posted February 6 8 hours ago, gnutux landia said: I don't use multiboot. This is required to use Armbian on the amlogic TV boxes. Enabling multiboot is one of the steps on the install instructions. 0 Quote
gnutux landia Posted February 6 Author Posted February 6 (edited) I follow this instructions The reset button in the case of my box is inside Av connection, I already boot the images with press the button and maintain IT. The result is a screen with HKSERIES screen, I can wait one hour nothing happens only the image. A video to you see that I press the reset multiboot button. Thanks. Edited February 6 by gnutux landia 0 Quote
SteeMan Posted February 6 Posted February 6 2 hours ago, gnutux landia said: already boot the images with press the button and maintain IT. That is enabling multiboot (what enabled either Armbian or android to boot. I'm going through with you all the basics that you didn't mention in your original post (and that others often forget to do), to eliminate all the basic things. You say "maintain it", but you shouldn't hold that button too long, a few seconds (10 at most is all you need). Holding too long will not work. 0 Quote
SteeMan Posted February 6 Posted February 6 At this point you seem to have done everything properly. The next step would be to find the uart connection point on you board and hook up a usb-uart reader so you can see the debug output from uboot to see what is happening. 0 Quote
gnutux landia Posted February 6 Author Posted February 6 2 hours ago, SteeMan said: At this point you seem to have done everything properly. The next step would be to find the uart connection point on you board and hook up a usb-uart reader so you can see the debug output from uboot to see what is happening. I don't have the usb that you mention. I open the console to clean the fan and I did photos of board but I don' t remember where I place the photos. Give me five minutes to put here photos I need to unmount the box. 0 Quote
gnutux landia Posted February 6 Author Posted February 6 (edited) I record a video of the board to see if with this info I don't need to read the outputs via uart. Can't find how to up images. What uart cable I need ? Can you post one from aliexpress. Thanks. Edited February 6 by gnutux landia 0 Quote
SteeMan Posted February 7 Posted February 7 This video should give you the information you need for setting up a usb debug uart connection: 0 Quote
gnutux landia Posted February 7 Author Posted February 7 (edited) I buy a different USB uart Usbuart Maybe I can do what you suggest. I need to wait to the item arrives at my home. When It arrives I post here to the device read uart method. Edited February 7 by gnutux landia 0 Quote
gnutux landia Posted Monday at 03:19 PM Author Posted Monday at 03:19 PM Any idea about this → sudo dmesg | grep tty [ 0.471034] console [tty0] enabled [ 633.797008] usb 1-1.4.1.3: cp210x converter now attached to ttyUSB0 [ 1159.103497] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 2713.702725] usb 1-1.4.1.2: cp210x converter now attached to ttyUSB0 [ 3812.350749] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 3812.351220] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 3812.447580] cp210x ttyUSB0: failed set request 0x12 status: -19 [ 3812.447593] cp210x ttyUSB0: failed set request 0x0 status: -19 [ 3812.447923] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 4077.235990] usb 1-1.4.1.2: cp210x converter now attached to ttyUSB0 [ 4098.361943] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 GNU/Linux sudo screen /dev/ttyUSB0 115200. [screen is terminating] 0 Quote
SteeMan Posted Monday at 04:09 PM Posted Monday at 04:09 PM Only a guess, but the first thing I would look at is how this is connected to your t box as it seems to not be connecting correctly. Maybe some pictures of your connection points? 0 Quote
gnutux landia Posted Monday at 04:09 PM Author Posted Monday at 04:09 PM Change the dp dm and gave this. sudo dmesg | grep tty [ 0.471034] console [tty0] enabled [ 633.797008] usb 1-1.4.1.3: cp210x converter now attached to ttyUSB0 [ 1159.103497] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 2713.702725] usb 1-1.4.1.2: cp210x converter now attached to ttyUSB0 [ 3812.350749] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 3812.351220] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 3812.447580] cp210x ttyUSB0: failed set request 0x12 status: -19 [ 3812.447593] cp210x ttyUSB0: failed set request 0x0 status: -19 [ 3812.447923] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 4077.235990] usb 1-1.4.1.2: cp210x converter now attached to ttyUSB0 [ 4098.361943] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 5224.734896] usb 1-1.4.1.3: cp210x converter now attached to ttyUSB0 [ 5248.927091] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 5250.665687] usb 1-1.4.1.3: cp210x converter now attached to ttyUSB0 [ 5600.550201] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 5600.550539] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32 [ 5601.154463] cp210x ttyUSB0: failed set request 0x12 status: -19 [ 5601.154476] cp210x ttyUSB0: failed set request 0x0 status: -19 [ 5601.154818] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 [ 5725.698091] usb 1-1.4.1.3: cp210x converter now attached to ttyUSB0 GNU/Linux When pass → sudo screen /dev/ttyUSB0 115200 Only has cursor blinking. 0 Quote
gnutux landia Posted Monday at 05:23 PM Author Posted Monday at 05:23 PM (edited) Here you have a video of connection. I already rewrite the sd-card image Armbian_community_26.2.0-trunk.357_Aml-s9xx-box_noble_current_6.18.7_xfce_desktop.img , try putty ssh but I have only a black screen when connect to ttyusb0 Test value speed 9600, 115200, 230400. S905X3 Edited Monday at 05:42 PM by gnutux landia 0 Quote
SteeMan Posted Monday at 07:30 PM Posted Monday at 07:30 PM I don't know what pins you are connecting to on the board as your video doesn't show that. But if I had to guess the three pads labeled gnd,rx,tx just above what you are connecting to is what you want to be connecting to. 0 Quote
gnutux landia Posted Monday at 08:22 PM Author Posted Monday at 08:22 PM I improvise a solder points and connect cables to tx, rx, ground, where tx goes to rx and rx goes to tx, but the result is the same, putty terminal only has a blinking cursor. 0 Quote
gnutux landia Posted Monday at 08:29 PM Author Posted Monday at 08:29 PM Now appear this on terminal. 0 Quote
gnutux landia Posted Monday at 08:38 PM Author Posted Monday at 08:38 PM Now seems that boots, I just need to touch the metal part of power button when click to give power and then starts to message events. [ 27.438701@2] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.442840@2] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.449129@1] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.455380@2] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.461729@2] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.467993@3] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.474575@3] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.480723@3] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.487114@3] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.493447@3] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.499798@1] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.506161@1] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.512469@1] dhd_dbg_set_event_log_tag set log tag iovar failed -23 [ 27.521394@3] dhd_dbg_attach_pkt_monitor, 1501 [ 27.526673@3] net_os_enable_packet_filter: val = 0 [ 27.530649@2] net_os_rxfilter_add_remove: add_remove = 0, num = 2 [ 27.536809@3] net_os_enable_packet_filter: val = 1 [ 27.541011@3] net_os_enable_packet_filter: val = 0 [ 27.544909@3] net_os_rxfilter_add_remove: add_remove = 0, num = 3 [ 27.551271@0] net_os_enable_packet_filter: val = 1 [ 27.555831@1] dhd_set_suspend: Remove extra suspend setting [ 27.560882@1] dhd_enable_packet_filter: enter, value = 0 [ 27.622938@2] init: [libfs_mgr]Unable to open zram conf comp device /sys/block/zram0/max_comp_streams [ 30.111457@3] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0 [ 34.581269@1] [dhd-wlan0] wl_cfg80211_connect : Connecting with 3c:47:11:4d:2a:ff ssid "WiFi_2AFF", len (9), sec=wpa2psk/tkipaes, channel=1 [ 34.581269@1] [ 34.612484@0] dhd_dbg_start_pkt_monitor, 1621 [ 34.612522@0] __dhd_dbg_free_tx_pkts, 1412 [ 34.615294@0] __dhd_dbg_free_rx_pkts, 1431 [ 34.638471@3] [dhd-wlan0] wl_iw_event : Link UP with 3c:47:11:4d:2a:ff [ 34.639572@3] [dhd-wlan0] wl_ext_iapsta_event : [S] Link UP with 3c:47:11:4d:2a:ff [ 34.649918@2] [dhd-wlan0] wl_bss_connect_done : Report connect result - connection succeeded [ 34.685204@1] [dhd-wlan0] wl_add_keyext : key index (0) [ 34.743323@2] dhd_dev_apf_get_version: firmware doesn't support APF [ 34.743986@2] dhd_dev_apf_get_max_len: firmware doesn't support APF [ 34.816935@0] dhd_ndo_remove_ip_by_type: failed, retcode = -14 [ 34.817143@0] dhd_dev_ndo_cfg: failed to update host ip addr: -14 [ 34.856175@0] net_os_enable_packet_filter: val = 0 [ 34.858467@0] net_os_rxfilter_add_remove: add_remove = 1, num = 2 [ 34.871997@0] net_os_enable_packet_filter: val = 1 [ 34.973661@2] dhd_set_suspend: Remove extra suspend setting [ 34.976808@2] dhd_enable_packet_filter: enter, value = 0 [ 35.068208@0] dhd_arp_get_arp_hostip_table: ioctl WLC_GET_VAR error -23 [ 35.070340@1] dhd_aoe_hostip_clr failed code -23 [ 35.076591@1] aoe_update_host_ipv4_table failed [ 50.164518@1] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0 [ 50.945561@3] audit: audit_lost=13 audit_rate_limit=5 audit_backlog_limit=64 [ 50.946974@3] audit: rate limit exceeded [ 53.223909@1] audit: audit_lost=15 audit_rate_limit=5 audit_backlog_limit=64 [ 53.225408@1] audit: rate limit exceeded [ 54.252938@1] audit: audit_lost=28 audit_rate_limit=5 audit_backlog_limit=64 [ 54.254399@1] audit: rate limit exceeded [ 82.286034@3] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 2, bssidx: 0 [ 94.451441@3] dhd_dbg_monitor_get_tx_pkts, 1913 [ 94.451532@3] dhd_dbg_monitor_get_tx_pkts(): no tx_status in tx completion messages, make sure that 'd11status' is enabled in firmware, status_pos=0 [ 94.466807@2] dhd_dbg_monitor_get_rx_pkts, 2010 [ 122.294218@3] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 3, bssidx: 0 0 Quote
SteeMan Posted Monday at 08:56 PM Posted Monday at 08:56 PM What you now need to capture is the initial boot loader messages, what you are showing here look to me to be messages from a booted android linux kernel 0 Quote
gnutux landia Posted Monday at 09:25 PM Author Posted Monday at 09:25 PM (edited) Can't figure how to copy putty terminal output messages, the terminal sent more messages but I can't find how to copy to a text file. Edited Monday at 10:03 PM by gnutux landia 0 Quote
