Posted (edited)
Make sure you have ili9486.ko in your ko module folder: modinfo ili9486
Can you use the DTS that I published in:
https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-208446
But change the "compatible" line with waveshare,rpi-lcd-35 ,
Delete the stuff under the "compatible" line, until the "}vsync-len = <0>;", and replace it with what you had in your DTS. Change these lines, if they are different:
                spi-max-frequency = <24000000>;
                rotate = <270>;
                bgr;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
Reference:
https://github.com/raspberrypi/linux/blob/rpi-6.12.y/arch/arm/boot/dts/overlays/piscreen-overlay.dts
Edited by robertoj
