Hello guys
I recently moved my build into VirtualBox in order to protect my host's rootfs from potential corruption. Everything went ok, build is working fine.
For my project I would like to share toolchains that Armbian has already downloaded on first start.
Is it possible to customize the path where toolchains are stored so that I can point to a shared folder?
Thank you
ok, thank you
point was to setup the path BEFORE the build framework's first start so that all that huge amount of data is downloaded to correct place.
