Aufa Aji Posted February 19 Posted February 19 v25.8 rolling for aml-s9xx-box running Armbian Linux 6.12.35-current-meson64 Printer is Canon G2770 I suspect its a driver problem since gutenprint does not have the exact same model (I chose Pixma G2000 Driver in CUPS "Add Printer" menu) #When Adding Printer d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{default_name=Canon_G2070_series\", out=0xffffb9ff1520... d [20/Feb/2026:03:19:36 +0700] [CGI] \"{printer_uri_supported}\" at 367... d [20/Feb/2026:03:19:36 +0700] [CGI] \"{$org.cups.sid}\" at 452... D [20/Feb/2026:03:19:36 +0700] [CGI] Regular expression \".*Clean.*\" d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_commands~.*Clean.*\" at 639, result=0... d [20/Feb/2026:03:19:36 +0700] [CGI] Skip first part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 639... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 700 on character \':\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Output second part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 700... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 701 on character \'}\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_commands~.*Clean.*\", out=0xffffb9ff1520... D [20/Feb/2026:03:19:36 +0700] [CGI] Regular expression \".*PrintSelfTestPage.*\" d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_commands~.*PrintSelfTestPage.*\" at 742, result=0... d [20/Feb/2026:03:19:36 +0700] [CGI] Skip first part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 742... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 809 on character \':\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Output second part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 809... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 810 on character \'}\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_commands~.*PrintSelfTestPage.*\", out=0xffffb9ff1520... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_state=5\" at 828, result=0... d [20/Feb/2026:03:19:36 +0700] [CGI] Skip first part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 828... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 882 on character \':\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Output second part... d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 882... d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 934 on character \'}\'... d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_state=5\", out=0xffffb9ff1520... d [20/Feb/2026:03:19:36 +0700] [Client 31] cupsdReadClient: error=0, used=0, state=HTTP_STATE_WAITING, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=0,> D [20/Feb/2026:03:19:36 +0700] [Client 31] POST / HTTP/1.1 D [20/Feb/2026:03:19:36 +0700] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files" D [20/Feb/2026:03:19:36 +0700] [Client 31] Read: status=200, state=6 d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: uri="/", limit=10... d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin/log(10) Limit 7f d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin/conf(11) Limit 7f d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin(6) Limit 7f d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /(1) Limit 7f d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: best=/ d [20/Feb/2026:03:19:36 +0700] [Client 31] con->uri="/", con->best=0xaaaac8741170(/) D [20/Feb/2026:03:19:36 +0700] [Client 31] No authentication data provided. d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: con->uri="/", con->best=0xaaaac8741170(/) d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: level=CUPSD_AUTH_ANON, type=None, satisfy=CUPSD_AUTH_SATISFY_ALL, num_names=0 d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: auth=CUPSD_AUTH_ALLOW... D [20/Feb/2026:03:19:36 +0700] [Client 31] 2.0 Get-Jobs 3 d [20/Feb/2026:03:19:36 +0700] cupsdProcessIPPRequest(0xaaaac88b11c0[31]): operation_id=000a(Get-Jobs) #When Trying to Print Test Page d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4699 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4700 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 D [20/Feb/2026:03:21:19 +0700] [Job 10] Printing page 1, 67% D [20/Feb/2026:03:21:19 +0700] cupsdMarkDirty(---J-) D [20/Feb/2026:03:21:19 +0700] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files" D [20/Feb/2026:03:21:19 +0700] [Job 10] Set job-printer-state-message to "Printing page 1, 67%", current level=INFO D [20/Feb/2026:03:21:19 +0700] [Job 10] ATTR: job-media-progress=67 d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=job-progress, dest=0xaaaac8751a40(Canon_G2070_series), job=0xaaaac888e2e0(10), text="Printing page %d, %d> D [20/Feb/2026:03:21:19 +0700] Discarding unused job-progress event... d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=job-progress, dest=0xaaaac8751a40(Canon_G2070_series), job=0xaaaac888e2e0(10), text="%s", ...) D [20/Feb/2026:03:21:19 +0700] Discarding unused job-progress event... d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=printer-state-changed, dest=0xaaaac8751a40(Canon_G2070_series), job=(nil)(0), text="Printer \"%s\" state > D [20/Feb/2026:03:21:19 +0700] Discarding unused printer-state-changed event... d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4702 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4703 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4704 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4705 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348 d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4706 d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers 0 Quote
