v25.8 rolling for aml-s9xx-box running Armbian Linux 6.12.35-current-meson64
Printer is Canon G2770
I suspect its a driver problem since gutenprint does not have the exact same model (I chose Pixma G2000 Driver in CUPS "Add Printer" menu)
#When Adding Printer
d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{default_name=Canon_G2070_series\", out=0xffffb9ff1520...
d [20/Feb/2026:03:19:36 +0700] [CGI] \"{printer_uri_supported}\" at 367...
d [20/Feb/2026:03:19:36 +0700] [CGI] \"{$org.cups.sid}\" at 452...
D [20/Feb/2026:03:19:36 +0700] [CGI] Regular expression \".*Clean.*\"
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_commands~.*Clean.*\" at 639, result=0...
d [20/Feb/2026:03:19:36 +0700] [CGI] Skip first part...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 639...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 700 on character \':\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Output second part...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 700...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 701 on character \'}\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_commands~.*Clean.*\", out=0xffffb9ff1520...
D [20/Feb/2026:03:19:36 +0700] [CGI] Regular expression \".*PrintSelfTestPage.*\"
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_commands~.*PrintSelfTestPage.*\" at 742, result=0...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 742...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 809 on character \':\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 809...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 810 on character \'}\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_commands~.*PrintSelfTestPage.*\", out=0xffffb9ff1520...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting \"{printer_state=5\" at 828, result=0...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 828...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 882 on character \':\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Starting at file position 882...
d [20/Feb/2026:03:19:36 +0700] [CGI] Returning at file position 934 on character \'}\'...
d [20/Feb/2026:03:19:36 +0700] [CGI] Finished \"{printer_state=5\", out=0xffffb9ff1520...
d [20/Feb/2026:03:19:36 +0700] [Client 31] cupsdReadClient: error=0, used=0, state=HTTP_STATE_WAITING, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=0,>
D [20/Feb/2026:03:19:36 +0700] [Client 31] POST / HTTP/1.1
D [20/Feb/2026:03:19:36 +0700] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [20/Feb/2026:03:19:36 +0700] [Client 31] Read: status=200, state=6
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: uri="/", limit=10...
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin/log(10) Limit 7f
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin/conf(11) Limit 7f
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /admin(6) Limit 7f
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: Location /(1) Limit 7f
d [20/Feb/2026:03:19:36 +0700] cupsdFindBest: best=/
d [20/Feb/2026:03:19:36 +0700] [Client 31] con->uri="/", con->best=0xaaaac8741170(/)
D [20/Feb/2026:03:19:36 +0700] [Client 31] No authentication data provided.
d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: con->uri="/", con->best=0xaaaac8741170(/)
d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: level=CUPSD_AUTH_ANON, type=None, satisfy=CUPSD_AUTH_SATISFY_ALL, num_names=0
d [20/Feb/2026:03:19:36 +0700] cupsdIsAuthorized: auth=CUPSD_AUTH_ALLOW...
D [20/Feb/2026:03:19:36 +0700] [Client 31] 2.0 Get-Jobs 3
d [20/Feb/2026:03:19:36 +0700] cupsdProcessIPPRequest(0xaaaac88b11c0[31]): operation_id=000a(Get-Jobs)
#When Trying to Print Test Page
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4699
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Tossing right 0 (0) + 9
d [20/Feb/2026:03:21:19 +0700] cupsdDeleteTemporaryPrinters: Removing unused temporary printers
d [20/Feb/2026:03:21:19 +0700] select_timeout: JobHistoryUpdate=1771607348
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4700
D [20/Feb/2026:03:21:19 +0700] [Job 10] Printing page 1, 67%
D [20/Feb/2026:03:21:19 +0700] cupsdMarkDirty(---J-)
D [20/Feb/2026:03:21:19 +0700] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files"
D [20/Feb/2026:03:21:19 +0700] [Job 10] Set job-printer-state-message to "Printing page 1, 67%", current level=INFO
D [20/Feb/2026:03:21:19 +0700] [Job 10] ATTR: job-media-progress=67
d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=job-progress, dest=0xaaaac8751a40(Canon_G2070_series), job=0xaaaac888e2e0(10), text="Printing page %d, %d>
D [20/Feb/2026:03:21:19 +0700] Discarding unused job-progress event...
d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=job-progress, dest=0xaaaac8751a40(Canon_G2070_series), job=0xaaaac888e2e0(10), text="%s", ...)
d [20/Feb/2026:03:21:19 +0700] cupsdAddEvent(event=printer-state-changed, dest=0xaaaac8751a40(Canon_G2070_series), job=(nil)(0), text="Printer \"%s\" state >
D [20/Feb/2026:03:21:19 +0700] Discarding unused printer-state-changed event...
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4702
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4703
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4704
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4705
d [20/Feb/2026:03:21:19 +0700] [Job 10] Gutenprint: Reading 14874 4706
