Helios64 rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp Kernel 6.18.10 Crash/Freeze
Hi everybody,
I running Helios64 with kernel 6.12.58 since a long time and the prahal dtb file rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and my helios64 work well.
Today, Armbian upgrade to 6.18.10 kernel.
Is this update use the same change or patch like in rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp ?
Is rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp work with 6..18.10 kernel ?
Is I must to downgrade to 6.12.58 kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze at this kernel version ?
Thanks for answer.
Edited by BipBip1981
For information:
First reboot and crash same that before use rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp. 😞
Back to 6.12.58, rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze to this setting
Me and my brother have helios64 with 6.18.10 Kernel :
RAID 10 / LVM / LUKS and crash always when "cryptsetup open..." start
Crash when many I/O
Crash when use Full CPUs
With rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and Kernel 6.12.58 or 6.12.(XX below):
Me, never crash but I reboot often and power off often for personal choice.
My brother have uptime upper than 100 or 200 days with problem, freeze or crash
Bye
  • BipBip1981 changed the title to Helios64 rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp Kernel 6.18.10 Crash/Freeze
