kronOSX Posted 18 hours ago Posted 18 hours ago Hi i have done a few boxes with armbian installed, some boxes wifi do not work but that is to be expected.But i got a amlogic box now that is giving me intrm error,It seems i can boot armbian and it loads up but after the loading it just get stuck at intrims.This has somethnig to do with the boot process from sd card.When i boot it form usb stick it works fine but the same setup from sd card gives me that error. I suspect the second part to boot the os is controlled by the box,I need to have first boot all the time What can i do to modify the sd card. 0 Quote
SteeMan Posted 16 hours ago Posted 16 hours ago You need to provide a lot more information. Lets start with logs/screenshots of what you are experiencing. What Box, what uboot, what dtb are you using? What armbian image are you using? 0 Quote
kronOSX Posted 2 hours ago Author Posted 2 hours ago (edited) i will get that information for you.Sorry i did not give it sooner Box: H96 model x3 cpu-s905x3 rom 64gb the config file is kernel /Image initrd /uInitrd fdt /dtb/amlogic/meson-sm1-h96-max.dtb append root=UUID=54072e2a-0ddf-4b60-930c-f13cc5fc51b1 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles I will post a neofetch of the usb flash that armibian works from on the same box strange enough when i take the sd card out the port on the box and place it in a usb card reader then boot armbian boots up ok and works(except the wifi) WHen i place the sd card back into the slot i get no errors but get stuck on initram Edited 1 hour ago by kronOSX added text 0 Quote
