KV1 Posted 3 hours ago Posted 3 hours ago When trying to rebuild the kernel, the image is not taking the updated kernel image: ./compile.sh BOARD=espressobin CLEAN_LEVEL=make-kernel RELEASE=trixie ..... -rwxrwxr-x 1 root root 296665952 Apr 7 16:47 vmlinux.unstripped -rw-rw-r-- 1 root root 220926 Apr 7 16:47 modules.builtin.modinfo -rw-rw-r-- 1 root root 16667 Apr 7 16:47 modules.builtin -rwxrwxr-x 1 root root 296215160 Apr 7 16:47 vmlinux drwxrwxr-x 23 root root 12288 Apr 7 16:47 kernel/ drwxrwxr-x 79 root root 12288 Apr 7 16:47 fs/ drwxrwxr-x 5 root root 36864 Apr 7 16:47 crypto/ drwxrwxr-x 22 root root 20480 Apr 7 16:47 lib/ drwxrwxr-x 27 root root 4096 Apr 7 16:47 sound/ drwxrwxr-x 23 root root 12288 Apr 7 16:47 scripts/ $ armbian-imager # installed the new image... 16:55:21 ● custom_image: Check decompression for /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img: false 16:55:21 ● operations: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb (verify: true) 16:55:21 ● flash::linux::writer: Starting flash: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img -> /dev/sdb 16:55:21 ● flash::linux::writer: Image size: 2252341248 bytes (2.10 GB) 16:55:21 ● flash::linux::writer: Unmounting device partitions... 16:55:21 ● flash::linux::writer: Writing image... 16:55:27 ● flash::linux::writer: Write complete: 2148.0 MB in 5.4s (avg 398.9 MB/s) 16:55:27 ● flash::linux::writer: Starting verification... 16:55:27 ● flash::verify: Starting verification of 2252341248 bytes (2.10 GB) 16:55:32 ● flash::verify: Verify complete: 2148.0 MB in 4.9s (avg 441.9 MB/s) 16:55:32 ● flash::linux::writer: Flash complete! 16:55:32 ● operations: Flash completed successfully 16:55:32 ● custom_image: Deleting decompressed custom image: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img 16:55:32 ● custom_image: Attempted to delete file outside custom-decompress cache: /srv/development/espressobin-ultra/armbian-build/build/output/images/Armbian-unofficial_26.05.0-trunk_Espressobin_trixie_edge_6.18.21.img $ sudo mount /dev/sdb1 /mnt/ $> ls -ltr /mnt/boot/vmlinux-6.18.21-edge-mvebu64 -rw-r--r-- 1 root root 36108800 Apr 3 18:36 /mnt/boot/vmlinux-6.18.21-edge-mvebu64 When booting: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.18.21-edge-mvebu64 (build@armbian) (aarch64-linux-gnu-gcc (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Thu Apr 2 07:23:33 EDT 2026 [ 0.000000] KASLR enabled
KV1 Posted 1 hour ago Author Posted 1 hour ago Even more confusing the file on the disk, written with armbian-imager is a text file, looks like an apt sources file: > file /mnt/boot/vmlinux-6.18.21-edge-mvebu64 /mnt/boot/vmlinux-6.18.21-edge-mvebu64: ASCII text, with very long lines (1483) > head /mnt/boot/vmlinux-6.18.21-edge-mvebu64 com/daniel-casanueva/haskell/graphviz Description-md5: bd02d2c14f791ffca367313e1957b329 Ghc-Package: graphviz-2999.20.2.0-JKUYtUkvYwE3GbOspxTTfB Section: haskell Priority: optional Filename: pool/main/h/haskell-graphviz/libghc-graphviz-dev_2999.20.2.0-1+b1_arm64.deb Size: 3696512 MD5sum: 36c93a1f30f0234eadffbf9ae0d2336b SHA256: 5b95053c25c02020e9eca717df070591259432e5c125435f5514761417bc8879 The built file looks fine: 1348921 717100 -rw-rw-r-- 1 root root 734305912 Apr 7 17:45 ./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o > file ./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o ./cache/sources/linux-kernel-worktree/6.18__mvebu64__arm64/vmlinux.o: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), with debug_info, not stripped
