Hackerman Posted April 24 Posted April 24 How to install Armbian on an eMMC module? Simply using Armbian Imager with the image file doesn't work—the system won't boot. The official Radxa OS boots fine from the same eMMC module. 0 Quote
DTEme Posted 2 hours ago Posted 2 hours ago Can I ask how did you fix it? I have the same problem but cannot get it to make it work. 0 Quote
Hackerman Posted 1 hour ago Author Posted 1 hour ago Honestly, I've already forgotten what the problem was there. Most likely, I used the Armbian installer and specified where to install the distribution in the automatic image download mode. Before that, I had tried writing it manually. Besides that, I found an important nuance — if you install software through armbian-config, for example GNOME and Chromium, the Plymouth splash screen will be automatically configured at boot, and hardware video decoding will be enabled in the browser, which for some reason does not get enabled when installing manually. 0 Quote
