Looking in the forums for a few days and reading up on a lot of stuff, I got the zero to boot from spi and USB, fairly easy once you got the right commands, and replacing "linux-u-boot-next-orangepipc2_5.34_arm64" with the version on the image for the board.
The procedure didn't really change, you need to activate the spi-jedec-nor overlay in /boot/armbianEnv.txt :
overlays=spi-jedec-nor
param_spinor_spi_bus=0
Then, after reboot, you should get from "cat /proc/mtd", something like that :
dev: size erasesize name
mtd0: 00200000 00001000 "spi0.0"
Then
cat /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/sunxi-spl.bin /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot.itb > /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin
and flash with
flashcp /usr/lib/linux-u-boot-next-orangepipc2_5.34_arm64/u-boot-sunxi-with-spl.bin /dev/mtd0
The I tried NFS shares and that worked fine to, but now I want to boot directly from another server, providing different folders for each board that I have and use spi for the boot.
The reading the forum again to find out more about NFS booting, and mostly found this "hurray I got it to work" then kind of leaving the rest of us hanging there thinking HOW??? :D
I was then reading about uboot and found out that it have ethernet enabled, so guess it´s prepared for this kind of booting.
So I need to change something in uboot so it will know what ip and folder to look after, since I'm looking into booting different boards?
Oh and heres a picture of my crazy project.
24991386_515020648885013_8887273542297869213_n.jpg.f98464199a73da4824803157cb6b5528.jpg
Nearly a year later, and other people asking me in my inbox if I got it to work.
No I didn't, I'm still on SPI + USB, but if anybody got it to work, please post it here so me and others can get this to work :)
## set this to NFS root path (ip:path)
## or else provide dhcp option 17 (root-path)
#setenv nfs_root
# for DHCP
setenv net_setup "ip=dhcp"
# for static configuration see documentation
# https://github.com/torvalds/linux/blob/master/Documentation/filesystems/nfs/nfsroot.txt
# setenv net_setup "ip=<client-ip>:<server-ip>:<gw-ip>:<netmask>:<hostname>:<device>:<autoconf>:<dns0-ip>:<dns1-ip>"
# you may need to add extra kernel arguments specific to your device
setenv bootargs "console=tty1 console=ttyS0,115200 root=/dev/nfs ${net_setup} rw rootflags=noatime,nodiratime disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 logle
if test -n ${nfs_root}; then
     setenv bootargs "${bootargs} nfsroot=${nfs_root}"
fi
tftp ${kernel_addr_r} ${serverip}:vmlinuz-4.14.91-sunxi
tftp ${ramdisk_addr_r} ${serverip}:uInitrd-4.14.91-sunxi
tftp ${fdt_addr_r} ${serverip}:sun8i-h2-plus-orangepi-zero.dtb
bootz ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
save and do mkimage -C none -A arm -T script -d boot.cmd boot.scr.uimg
copy boot.scr.uimg, vmlinuz,uInitrd, *.dtb to tftp folder and boot.
Working for me
For building nfs image and vmlinuz,uInitrd, *.dtb
On ubuntu 18.04
apt -y install git
git clone https://github.com/armbian/build
cd build
./compile.sh ROOTFS_TYPE=nfs
wait.....................................................................DONE
cd output/images
ls
.....nfsboot-rootfs.tgz
.....nfsboot.img
.....nfsboot-rootfs.tgz tar -xzf to nfs export dir
fdisk -l .....nfsboot.img
         ........Orangepizero_Ubuntu_bionic_next_......._nfsboot.img1               8192 131071  122880    60M            83 Linux
8192 * 512 = 4194304
mount -o loop,offset=4194304  .....nfsboot.img /mnt
copy vmlinuz,uInitrd, and dtb  for you platform to tftp dir
Hi @zux
Thanks for the extra instructions.
I get stuck at 'Uncompressing Linux... done, booting the kernel.'
This is what I've done:
=> setenv serverip 192.168.1.209
=> setenv ipaddr 192.168.1.170
=> setenv fdtfile sun8i-h2-plus-orangepi-zero.dtb
=> setenv tftpblocksize 1024
=> usb start
=> tftp ${kernel_addr_r} vmlinuz-4.19.17-sunxi
ethernet@1c30000 Waiting for PHY auto negotiation to complete. done
Using ethernet@1c30000 device
TFTP from server 192.168.1.209; our IP address is 192.168.1.170
Filename 'vmlinuz-4.19.17-sunxi'.
Load address: 0x42000000
Loading: #################################################################
         4.4 MiB/s
done
Bytes transferred = 7313648 (6f98f0 hex)
=> tftp ${fdt_addr_r} ${fdtfile}
Filename 'sun8i-h2-plus-orangepi-zero.dtb'.
Load address: 0x43000000
Loading: ######
         3.4 MiB/s
done
Bytes transferred = 28787 (7073 hex)
=> setenv nfs_ip 192.168.1.209
=> setenv rootpath /nfsboot/ubuntu/
=> setenv bootargs earlyprintk console=ttyAMA0 console=tty1 ip=dhcp root=/dev/nfs rootwait
=> bootz ${kernel_addr_r} - ${fdt_addr_r}
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Device Tree to 49ff5000, end 49fff072 ... OK
Starting kernel ...
If anyone can help it would be much appreciated.
I got it working with:
usb start
setenv bootargs earlyprintk console=ttyS0,115200 ip=dhcp rootwait nolock rw nfsroot=192.168.1.209:/nfsboot/ubuntu/,v3 root=/dev/nfs rootdelay=7
Is there a way to 'saveenv' directly to the SPI flash or do I need to modify u-boot with my settings before compiling?
For anyone else who is stuck,
I had lots of issues because my TFTP server was on a different server to where DHCP is served from, I think U-boot expects the TFTP to come from the same source as DHCP server with the default settings.
here is my boot.scr.uimg:
tftp ${ramdisk_addr_r} uInitrd
usb start
bootz ${kernel_addr_r} - ${fdt_addr_r} ${ramdisk_addr_r}
and my /etc/export (NFS shares)
# /etc/exports: the access control list for filesystems which may be exported
#               to NFS clients.  See exports(5).
# Example for NFSv2 and NFSv3:
# /srv/homes       hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check)
# Example for NFSv4:
# /srv/nfs4        gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check)
# /srv/nfs4/homes  gss/krb5i(rw,sync,no_subtree_check)
/nfsboot                192.168.*(rw,sync,no_root_squash,no_subtree_check)
/nfsboot/ubuntu                192.168.*(rw,sync,no_root_squash,no_subtree_check)
Dude
option tftp-server-name "a.b.c.d"; // option 66 from RFC
life hack
option host-name = concat("node", concat (
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), "",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), "",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), "",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), "",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), "",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,6,1))),2)
will do hostname like node+MAC
option root-path = concat("192.168.11.130:/mnt/main/arms_hdd/", concat (
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,1,1))),2), ":",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,2,1))),2), ":",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,3,1))),2), ":",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,4,1))),2), ":",
                suffix (concat ("0", binary-to-ascii (16, 8, "", substring(hardware,5,1))),2), ":",
mount dir is "MAC" but need use ${nfs_root} int boot.cmd
ahh sorry, sure thats params just for dhcpd.conf
example
subnet 10.100.100.0 netmask 255.255.255.0 {
 range 10.100.100.10 10.100.100.200;
 option routers 10.100.100.1;
 option broadcast-address 10.100.100.255;
 option domain-name-servers 192.168.11.1;
 option domain-name "cluster";
 option subnet-mask 255.255.255.0;
 option root-path = concat("192.168.11.5:/mnt/main/arms_hdd/", concat (
 default-lease-time 604800;
 max-lease-time 604800;
