ljones0 Posted April 28 Posted April 28 Hello all! Not sure what is going on at all but I'm having a problem booting the "rolling release" of armbian (debian 14/forky) minimal cli. I'm using a nano pi R76S with 4gb of RAM and 64GB emmc. I can successfully burn a microsd for the previous version (also minimal cli vesion) which boots ok.However if I try to use the newer version nothing happens -- the red LED on the R76S stays permanently on and I get no display or any other life. I did try using different microsd cards but it did not make any difference. I also tried using the same microsd (I wrote the older version first to the microsd which boots) then wrote again on the same microsd. I'm using the download page for the images from here - https://armbian.com/boards/nanopi-r76s ljones 0 Quote
SuperKali Posted April 29 Posted April 29 Hello, Can you connect the UART to the NanoPi and see where it gets stuck? I'll take a look at it over the weekend. Thank you. 0 Quote
ljones0 Posted April 29 Author Posted April 29 Will try to find my UART to USB and see what I get. ljones 1 Quote
ljones0 Posted April 29 Author Posted April 29 Ok, I gave it a go. I used the settings - baud rate 1500000, Data bit=8,Parity check=None,Stopbit=1,Flow control=None. Most of what I got was largely garbled but here's what I could read: [code] DDR fcb0cfd52f cym 24/10/09-19:36:03,fwver: v1.08 In ch1 ddoY�H��~␦j�DR5, 2736MHzttot6 channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB ch1 ttot7 ��@ )�j�-��o � ����������~�����������channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff �h�0 RX Vref:24.9%, RX DQS Vref:30.8%, TX Vref:20.0%,0.0%/� Kk�k|/��~��~������� DQ roc: p4 n0, p7 n0, p4 n0, p3 n0, p5 n4, p1 n0, p7 n0, p0 n2, p0 n0, p4 n3, p2 n0, p5 n0, p3 n0, p4 n0, p4 n0, p5 n0, p0 n0, p3 n1, DQ rds:h1 h1 l0 l0 l0 l0 l0 l0, l0 l0 l0 l0 l0 l0 h1 l0 ��� �B(N@x�|�|�~�~�~~����������CH1 RX Vref:24.1%, RX DQS Vref:29.2%, TX Vre��Jo��{��������������� DQ roc: p6 n0, p2 n0, p7 n0, p3 n1, p1 n0, p0 n2, p3 n0, p7 n0, p3 n0, p3 n0, p2 n0, p0 n1, p6 n0 p1 )��d!�@��DQS roc: p1, n0, p3, n0 stride=0x3, ddr_config=0x2 hash bank_mask0-3 0x0 0x2100 0x44200 0x88400, rank_mask0 0x0 nge to F1: 534MHz >l ttot6 l1 ttot6 ?lange to F2: 1320MHz ch0 ttot8 ch1 ttop8 c@aNg@@ ch0 ttot6 ch1 ttot6 �~l�ange to F0: 2736MHz ����x�x�|�|�������������ch0 ttot7 ch1 ttop7 out U-Boot SPL board init>_p U-Boot SPL 2017.09_armbian-2017.09-S39cd-P60ca-H8822-V586d-B138f-R448a (Apr 27 2026 - 17:35:35) SPL Hotkey: ctrl+` "�!)�#P��K=�|�~�~�~�~���������sfc cmd=0�� )��������������������� @jj��%����������������������. ����ᯍ�������������spl: par�K� y!��������dd�Verified-boot: 0 ~@@�������������������## Checking atf-1 0x40060000 ... sha256(868eaf583a...) + OK � ��/��oo-����������������������%␦� +���������������������� _B��� / ��x����������������������ZH)�)���-�������������������x-�/ �������������������## Checking uboot 0x4020000�����l�e1593752...) + OK �dd�Checking fdt 0x40339460 ... sha256(e3b0c44298...) + OK 6�t_record_lgadable: FDT_ERR_BADMAGIC �@dd�ChekA�;\6�F�f�400f0000 ... sha256(8afb712810...) + OK fdt_record_loadable: FDT_ERR_BADMAGIC �#" Checkin1�� !��������{���+�:�ICE: BL31: v2.3():v2.3-931-g4d7e811c6:derrick.huang, fwver: v1.20 NOTICE: BL31: Built : 19:19:38, May 26 2025 ��NFO: SOC (0x35760101) INFO: spec: 0x1 INFO: test version: 0x0 INFO: cost 477531 us before hptimer restart k������������������INFO: soc cold boot INFO: ARk�P��& b �$@�H@�@� `]w�mask: 1 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x40200000 INFO: SPSR = 0x3c9 No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> initcall sequence 00000000402c54c0 failed at call 00000000402b81e8 (err=-1) [/code] The rest after this was unreadable. ljones 0 Quote
SuperKali Posted April 30 Posted April 30 Thanks for sending the log. This looks like an issue with the vendor U-Boot. We're planning to drop it this Sunday and switch to mainline U-Boot. 0 Quote
SuperKali Posted 44 minutes ago Posted 44 minutes ago @ljones0 in meantime can you test edge kernel images, i'm sure those works. 0 Quote
