Droll Posted May 4 Posted May 4 Hello everyone. I’m attempting to mount a Windows network share on Armbian, but something seems off—both smb://10.10.2.101 and sftp://10.10.2.101 show up in red. The same addresses work perfectly on Rocky Linux; any thoughts on what I might be overlooking? 0 Quote
Sergioclr Posted May 4 Posted May 4 (edited) What kind of device (hardware) are you using? Edited May 6 by Sergioclr reformulate 0 Quote
CryBaby Posted May 4 Posted May 4 You aren't telling us much, like what software you are using. I would expect you to need to give it something like smb://10.10.2.101/NAME_OF_SHARE/ or sftp://10.10.2.101:/path/to/folder You will also need to give it a username and password somehow. But first; have you checked you can reach it on the network? 0 Quote
Vinicius Guastala Posted May 15 Posted May 15 @Droll, something worth to check out is the SMB version your server is running... They have slightly different authentication, so the mount command differs a bit: SMBV1: sudo mount -t cifs -o vers=1.0,username=your_username,password=your_password //server_ip/share_name /mnt/myshare SMBV2: sudo mount -t cifs -o vers=2.0,username=your_username,password=your_password //server_ip/share_name /mnt/myshare 0 Quote
ErinBong Posted Wednesday at 11:03 AM Posted Wednesday at 11:03 AM If Windows can see the share but has trouble connecting, it's also worth checking the SMB version being used on both sides. I've run into cases where enabling the correct SMB protocol or recreating the saved Windows credentials fixed the issue right away. 0 Quote
