Commend2086 Posted 9 hours ago Posted 9 hours ago Armbianmonitor: https://paste.armbian.com/ginunemepi Hi, First time poster, so immediately confused with the tags. tag was required but could not find one for Radxa Rock 4se. I want to get the raspberry pi camera working in ubuntu on my rock 4se. I tested with the image radxa provides and the hardware works. Then i switched to the community ubuntu image and it seems i need an overlay to tell the linux device tree that the rpi camera is there. Can anybody help me with this? Thanks! 0 Quote
eselarm Posted 2 hours ago Posted 2 hours ago (edited) There is only this overlay for vendor kernel: /usr/lib/linux-image-6.1.115-vendor-rk35xx/rockchip/overlay/radxa-zero3-rpi-camera-v1.3.dtbo The mainline based kernel, what you use, there is none. So you would need to port it, from this radxa03 SBC or look at other devicetree overlay files, maybe from RadxaOS, maybe from RPiOS See 'man dtc' as a start, it might be a complete renaming of a lot of the .dtso file is needed, maybe it is just an enable line. Edited 2 hours ago by eselarm 0 Quote
