Folaht Pjehrsohmehj Posted 1 hour ago Posted 1 hour ago (edited) $ swapon -bash: swapon: Unknown command I was about to create a swapfile and then the above command happened. Where can I find swapon? Edited 1 hour ago by Folaht Pjehrsohmehj 0 Quote
IBV Posted 59 minutes ago Posted 59 minutes ago Hi, I think swapon is not visible because you are not root. It should already be there via required package "mount". Try tu "su -" then you will "see" the command. 0 Quote
