Johannes Posted July 4 Posted July 4 Hi all, recently my Banana Pi Pro running Armbian 26.5.1 with Debian Trixie received a kernel update from 6.16.8 (which it has been running on for quite a while without issues) to 7.0.12. Since then, it randomly freezes shortly after booting, sometimes I also can see a kernel panic (see attached pictures). Has anyone else run into this issue? What can I do to fix this? The old kernel no longer appears to be present in /boot, which makes it difficult to return to another kernel (trying to run something like apt-get typically quickly results in the aforementioned freeze). 0 Quote
eselarm Posted July 5 Posted July 5 Yes, I have similar issues with 7.0.12-edge-sunxi kernel, see serial dump/log below: [ 133.382506] Internal error: Oops - undefined instruction: 0 [#1] SMP THUMB2 [ 133.389572] Modules linked in: rpcsec_gss_krb5 auth_rpcgss nfsv4 nfs lockd grace netfs sunrpc cp210x binfmt_misc usbserial lima gpu_sched nls_iso8859_1 drm_shmem_help er sun4i_gpadc_iio sunxi_cir axp20x_adc sun4i_ts sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc display_c onnector cpufreq_dt evdev cfg80211 rfkill nfnetlink ip_tables x_tables autofs4 btrfs xor xor_neon libblake2b raid6_pq pinctrl_axp209 axp20x_usb_power industrialio sun4i_ gpadc sunxi phy_generic realtek [ 133.437258] CPU: 1 UID: 0 PID: 184 Comm: kworker/u8:5 Tainted: G C 7.0.12-edge-sunxi #2 VOLUNTARY [ 133.447746] Tainted: [C]=CRAP [ 133.450738] Hardware name: Allwinner sun7i (A20) Family [ 133.455991] Workqueue: pm pm_runtime_work [ 133.460075] PC is at __rpm_callback+0x64/0x10c [ 133.464565] LR is at rpm_callback+0x51/0x58 [ 133.468789] pc : [<c06d2e40>] lr : [<c06d2f39>] psr: 400f00b3 [ 133.475083] sp : f0a5de90 ip : 00000018 fp : c2ef5200 [ 133.480337] r10: c01761ed r9 : 000f4240 r8 : 00000008 [ 133.485590] r7 : 00000000 r6 : 00000000 r5 : c06d0aad r4 : c1e25410 [ 133.492146] r3 : 60000000 r2 : c1e25410 r1 : c1e25410 r0 : c06d0aad [ 133.498704] Flags: nZcv IRQs off FIQs on Mode SVC_32 ISA Thumb Segment none [ 133.506135] Control: 50c5387d Table: 43eb406a DAC: 00000051 [ 133.511902] Register r0 information: non-slab/vmalloc memory [ 133.517616] Register r1 information: slab kmalloc-1k start c1e25400 pointer offset 16 size 1024 [ 133.526415] Register r2 information: slab kmalloc-1k start c1e25400 pointer offset 16 size 1024 [ 133.535209] Register r3 information: non-paged memory [ 133.540302] Register r4 information: slab kmalloc-1k start c1e25400 pointer offset 16 size 1024 [ 133.549095] Register r5 information: non-slab/vmalloc memory [ 133.554795] Register r6 information: NULL pointer [ 133.559537] Register r7 information: NULL pointer [ 133.564279] Register r8 information: non-paged memory [ 133.569367] Register r9 information: non-paged memory [ 133.574455] Register r10 information: non-slab/vmalloc memory [ 133.580241] Register r11 information: slab task_struct start c2ef5200 pointer offset 0 size 2624 [ 133.589123] Register r12 information: non-paged memory [ 133.594301] Process kworker/u8:5 (pid: 184, stack limit = 0xe8b1571c) [ 133.600779] Stack: (0xf0a5de90 to 0xf0a5e000) [ 133.605178] de80: 60000000 c1e25410 c06d0aad 0000000a [ 133.613397] dea0: 00000000 00000008 000f4240 c06d2f39 c1e25410 c06d0aad 0000000a c06d3f23 [ 133.621617] dec0: c0ab03bf 00000402 c15b5180 c9306c24 c3790705 c34c3c70 c1813000 bf8e21ad [ 133.629836] dee0: c2ef5200 c1813000 01000000 569e35c7 c34f0c70 c1e254f8 c1e254f8 c1b9de00 [ 133.638054] df00: c1813000 01000000 c1b9de05 c1b72670 c1813000 c06d45a7 c2fb5900 c0141a87 [ 133.646273] df20: c3790000 569e35c7 00000000 c2ef5200 c1813000 c2fb5930 f0a5df50 c2fb5900 [ 133.654492] df40: c1813000 c2fb5930 c1603d80 c1813020 c2ef5200 c181305c c1813000 c0142345 [ 133.662711] df60: f0a5df78 c1603d80 f0a9deb8 c36b8fc0 c2ef5200 c0142245 c2fb5900 c2d35c80 [ 133.670929] df80: f0a9deb8 00000000 00000000 c0149e29 00000001 c36b8fc0 c0149d59 00000000 [ 133.679145] dfa0: 00000000 00000000 00000000 c0100155 00000000 00000000 00000000 00000000 [ 133.687359] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 133.695575] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000 [ 133.703775] Call trace: [ 133.703812] __rpm_callback from rpm_callback+0x51/0x58 [ 133.711641] rpm_callback from rpm_suspend+0xab/0x514 [ 133.716756] rpm_suspend from pm_runtime_work+0x3f/0x70 [ 133.722045] pm_runtime_work from process_one_work+0x12f/0x390 [ 133.727947] process_one_work from worker_thread+0x101/0x254 [ 133.733667] worker_thread from kthread+0xd1/0xec [ 133.738431] kthread from ret_from_fork+0x11/0x1c [ 133.743189] Exception stack(0xf0a5dfb0 to 0xf0a5dff8) [ 133.748280] dfa0: 00000000 00000000 00000000 00000000 [ 133.756494] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 133.764705] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 133.771365] Code: f7ff ff7c 4640 f7ef (fd27) f104 [ 133.776186] ---[ end trace 0000000000000000 ]--- [ 133.780834] note: kworker/u8:5[184] exited with irqs disabled [ 154.802648] rcu: INFO: rcu_sched detected stalls on CPUs/tasks: [ 154.808663] rcu: 0-...0: (10 ticks this GP) idle=4c4c/1/0x40000000 softirq=7570/7571 fqs=2625 [ 154.817336] rcu: (detected by 1, t=5252 jiffies, g=14613, q=22 ncpus=2) [ 154.824076] Sending NMI from CPU 1 to CPUs 0: It was 3 weeks ago I did see this while doing some maintenance,upgrades,tests,experiments. Mine is a Bananapi M1, I use sun7i-a20-bananapi.dtb as DTB, and should be same for U-Boot, although I would need to check again what version/build I use. A difference is WiFi and some others, but my guess is there is something wrong/ongoing that is getting worse over time, as also with less newer kernels, it locks up after a few days quite often. This has been the case since december 2024 kernel 6.6.x as far as I see that written in my notes. I noticed that because I have used my Bananapi as NAS (blocklevel NBD). But it were paging issues and never really could find a pattern, always random. This error message is different, but might have same root-cause. Kernel 6.16.x I have run, but it lacked AXP PMU driver for the LiPo battery powering/charging which I use every now and then (is a great UPS like that). 6.18.x had it back again, but also lockups (same paging issue, I have already a kernel log dumping 24/7 to try to figure out what is wrong, but actually have no clue). I also used 6.12.90+deb13.1-armmp, so vanilla Debian kernel, but it has no overlays available and also no AXP PMU module, so that make it less useful. I set it back to 6.12.58-current-sunxi so that at least it runs reliably for a few days and I can use it ad-hoc as a serial console terminal for a Raspberrypi4 that also used to crash randomly due to USB3 stack issues and also for debugging and testing rather complex networking issues. I am using custom partition layout, the whole thing also runs as 32-bit UEFI KVM as well as systemd-nspawn container (same cloned MAC address so I un-power the real Bananapi then). The setup uses custom extlinux and standard grub-efi. I could easily test 7.0.x or later in a KVM, but assume it will run fine. It is really something about a combination of A20, platform HW, U-Boot, DeviceTree I think. It is a pity as this SBC is about the most useful I have due to its onboard SATA and LiPo battery management, although not 64-bit. 0 Quote
eselarm Posted July 5 Posted July 5 The forum returned 'nginx bad gateway' but I see draft of may message is still there. In the meantime, I did a simple 'apt update && apt full-upgrade && reboot' and now I have: U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Hb9d3-Vf23c-Bb703-R448a (Jun 21 2025 - 02:53:13 +0000) Kernel: Linux 6.18.35-current-sunxi I might look into HW watchdog things, no clue if it is there and able to work, but used it successfully for Raspberrypi4 to workaround USB3 lockups/crashes. 0 Quote
eselarm Posted July 5 Posted July 5 OK I see: # dmesg | grep watchdog [ 0.462093] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) That would mean study 'bark' or so, forgot most of it. I guess the board should restart if IPv6 LL connection is not there for more than 1 minute or so, but in relation to NAS makes then only sense if I move from NBD to iSCSI or so. 0 Quote
Johannes Posted July 5 Author Posted July 5 I tried to downgrade to 6.18, unfortunately it froze during the process, which left the kernel and boot loader in an incomplete state. I have decided to re-image the whole thing with 6.18.x and for now it appears to be stable again. 0 Quote
eselarm Posted Wednesday at 10:18 AM Posted Wednesday at 10:18 AM Good that your bpi appears to be stable. My did hang again, no reaction on serial console, no reaction on IP networking. So I enabled the watchdog, uncommented the 'ping 192.168.1.1 line' and made it ping 192.168.1.100 and temporarily added that address to another computer: ip addr add dev br0 192.168.1.100/24 Then removing it: ip addr del dev br0 192.168.1.100/24 and after a minute or so: [ 263.929336] systemd-journald[236]: Received SIGTERM from PID 1071 (watchdog). [ 265.185973] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 265.221538] systemd[1]: Detected architecture arm. [ 269.100327] systemd[1]: Failed to fork off sandboxing environment for executing generators: Protocol error [!!!!!!] Failed to start up manager. [ 269.146571] systemd[1]: Freezing execution. This looks like HW watchdog does not work. Same trick on NanoPi-NEO, so also sunxi kernel although 7.0.12-edge-sunxi, it resets. So appears to work although no proof that it is HW reset. I have not checked live dmesg or so, just noticed it went offline and came back later when I also added that .100 IP address again. 0 Quote
