Skip to content
View in the app
Armbian Community Forums
GPIO libraries for the Banana Pi / Banana Pro (A20) fixed for current Armbian, with .deb packages
Featured Replies
Hi all,
I fixed the old LeMaker GPIO libraries so they work again on current Armbian (Debian 13 trixie, mainline kernel 6.18), and I built ready .deb packages for armhf. They were written for the old sunxi 3.4 kernel and had not been updated since 2016-2019.
What's included:
  • WiringBP (WiringPi for C, with gpio readall): kernel GPIO numbers for sysfs and interrupts, I2C bus detection, and PWM no longer switches off the LCD backlight.
  • LMK.GPIO (RPi.GPIO for Python): works with Python 3.13, with board detection, edge events and callbacks fixed.
  • lg (lgpio/rgpio by joan2937, the successor of pigpio, which can't run on the A20): one fix for alerts on GPIO numbers above 255. Most header pins on these boards are in bank PI (256 and up), so Python callbacks on them never ran.
Packages (Debian 13 armhf): wiringbp, python3-lmk-gpio, lgpio, python3-lgpio
cd /tmp
wget https://github.com/cyryllo/banana-a20/raw/master/gpio/pakiety/dist/wiringbp_2.0-1_armhf.deb
wget https://github.com/cyryllo/banana-a20/raw/master/gpio/pakiety/dist/python3-lmk-gpio_0.0.1-1_armhf.deb
wget https://github.com/cyryllo/banana-a20/raw/master/gpio/pakiety/dist/lgpio_0.2.2-1_armhf.deb
wget https://github.com/cyryllo/banana-a20/raw/master/gpio/pakiety/dist/python3-lgpio_0.2.2-1_armhf.deb
sudo apt install ./wiringbp_2.0-1_armhf.deb ./python3-lmk-gpio_0.0.1-1_armhf.deb ./lgpio_0.2.2-1_armhf.deb ./python3-lgpio_0.2.2-1_armhf.deb
Documentation with a pinout, examples (C, Python, libgpiod) and the list of changes: https://github.com/cyryllo/banana-a20/blob/master/gpio/README.md
Boards:
  • Banana Pro: everything was tested on my board.
  • Banana Pi M1 (the original Banana Pi) and M1+: the packages install and lg and libgpiod work, because they use kernel GPIO numbers. WiringBP and LMK.GPIO only know the Banana Pro header. On the M1/M1+ pins 7, 8, 10 and 12 (and 29-40 on the M1+) are wired to different SoC pins, so use those two libraries only on the pins that match, or use lg/libgpiod there. The details are in the README. If someone with an M1 or M1+ can test, I'm happy to add proper support for those headers.
If something doesn't work, write here or open an issue on GitHub: https://github.com/cyryllo/banana-a20/issues
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
