Sire Gawain Posted January 10, 2018 Share Posted January 10, 2018 Hi out there! I've managed to build a quite complex system based on Tinker, using 1 Wire sensor, I2C-s, all of all UART's, and all of all remaining GPIO's... :-) Unfortunately a long term test in a climate chamber have failed... (although the core was just heated up to 70 degrees Celsius) The need for a hardware watchdog then arise... I've build new kernel using latest compile.sh with the HW watchdog checked resulting Linux tinkerboard 4.4.110-rockchip #2 SMP Wed Jan 10 16:41:03 CET 2018 armv7l GNU/Linux but there is no /dev/watchdog Not even in /proc/iomem at ff800000... (it seems okay in dtb, as well as in /sys/devices/platform) Now what? Any help would be kindly appreciated, SG Link to comment Share on other sites More sharing options...
Myy Posted January 11, 2018 Share Posted January 11, 2018 Did you enable the Synopsys DesignWare Watchdog Driver ? Check in your .config file if DW_WATCHDOG=m or DW_WATCHDOG=y is present. It's the only watchdog driver compatible with snps,dw-wdt DTB entries. /* drivers/watchdog/dw_wdt.c */ static const struct of_device_id dw_wdt_of_match[] = { { .compatible = "snps,dw-wdt", }, { /* sentinel */ } }; Link to comment Share on other sites More sharing options...
TonyMac32 Posted January 11, 2018 Share Posted January 11, 2018 Thanks for that, @Myy. I'll take a look. [update] @Sire Gawain if you build a "Next" kernel now you will have support. https://github.com/armbian/build/commit/ac76d47785c130a20f8f2c6447bbae7f2c40bc14 Link to comment Share on other sites More sharing options...
