Miguel Manso Posted January 12, 2018 Posted January 12, 2018 (edited) Hi All, I'm using Armbian_5.37_S9xxx_Debian_stretch_3.14.29_xfce_20171226.img image file on an amlogic S912 board. That image doesn't have a usblp module compiled in the kernel. Does anyone can tell me where I can find the kernel used on that image and the .config file with the used options so I can compile the usblp module to use on it? Thanks a lot. Edited January 12, 2018 by Miguel Manso
balbes150 Posted January 12, 2018 Posted January 12, 2018 The configuration that will be used during Assembly to be in the /boot directory on the recorded media. Kernel sources are here. https://github.com/150balbes/Amlogic_s905-kernel/tree/armbian or config https://github.com/150balbes/build/blob/amlogic/config/kernel/linux-amlogics905x-default.config
Miguel Manso Posted January 15, 2018 Author Posted January 15, 2018 Hi there, Thanks for the help. I'm using official armbian build instructions and script and after it downloads everything, I select the option: U-boot a and kernel packages After that it asks me which target board I'm compiling to and I don't find any option for the S912. All I wanted was to include the usblp module into the kernel provided with your image. I'm just a little bit lost on how to use the kernel you made with the generic armbian setup instructions...
balbes150 Posted January 16, 2018 Posted January 16, 2018 10 hours ago, Miguel Manso said: Thanks for the help. I'm using official armbian build instructions and script and after it downloads everything, I select the option: U-boot a and kernel packages After that it asks me which target board I'm compiling to and I don't find any option for the S912. All I wanted was to include the usblp module into the kernel provided with your image. I'm just a little bit lost on how to use the kernel you made with the generic armbian setup instructions... Core to s905 and s912 in common.
