I run into problems trying to get application distributed via snaps installed.
Mount snap "core" (3751)
[ 1691.207676] squashfs: SQUASHFS error: Filesystem uses "xz" compression. This is not supported
error: cannot perform the following tasks:
- Mount snap "core" (3751) ([start snap-core-3751.mount] failed with exit status 1: Job for snap-core-3751.mount failed. See "systemctl status snap-core-3751.mount" and "journalctl -xe" for details.
Found out kernel module would need to enable CONFIG_SQUASHFS_XZ.
Could someone help me by adding the module to Kernel or support me in doing so or with a much appreciated workaround.
Thanks!
Any hints? Seems I could modprobe the squashfs but cannot find package from normal repository to install it first.
