November 4Nov 4 I install the image from this page: https://armbian.com/boards/aml-s9xx-box.Choose the version:Debian 13 trixie Minimal (CLI) — current 6.18.60 361 MBroot@aml-s9xx-box:~# uname -a Linux aml-s9xx-box 6.18.60-current-meson64 #1 SMP PREEMPT Fri Oct 30 12:06:41 UTC 2026 aarch64 GNU/LinuxI have successfully run with SDCard, but cannot install it to eMMC.root@aml-s9xx-box:~# ./install-aml.sh Start script create MBR and filesystem /dev/mmcblk1 Start backup u-boot default 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 1.29 s, 3.3 MB/s Start create MBR and partittion Start restore u-boot 442+0 records in 442+0 records out 442 bytes copied, 0.0070075 s, 63.1 kB/s 8191+0 records in 8191+0 records out 4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.499351 s, 8.4 MB/s Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.2 (2021-01-31) done. Copying BOOT...done. Edit init config...done. sed: can't read /ddbr/install/boot.ini: No such file or directory done. Formatting ROOT partition... /dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC' last mounted on /ddbr/install on Wed Nov 4 20:50:00 2026 e2fsck 1.47.2 (1-Jan-2025) ROOT_EMMC: clean, 12/385024 files, 46947/1539328 blocks done. Copying ROOTFS. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Copy LIB64 tar: lib64: Cannot stat: No such file or directory tar: Exiting with failure status due to previous errors Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR Copy fstab rm: cannot remove '/ddbr/install/usr/bin/ddbr': No such file or directory ******************************************* Complete copy OS to eMMC *******************************************Even though it says Complete, but it cannot boot from eMMC, stuck in a loop. I notice it said "sed: can't read /ddbr/install/boot.ini: No such file or directory", which in this system, there is no boot.ini.root@aml-s9xx-box:~# ls / bin boot ddbr dev etc home lib lost+found media mnt opt proc root run sbin selinux srv sys tmp usr var root@aml-s9xx-box:~# ls -la /ddbr total 12 drwxrwxrwx 3 root root 4096 Nov 4 22:35 . drwxr-xr-x 20 root root 4096 Nov 4 20:46 .. drwxr-xr-x 2 root root 4096 Nov 4 22:35 install root@aml-s9xx-box:~# ls -la /ddbr/install total 8 drwxr-xr-x 2 root root 4096 Nov 4 22:35 . drwxrwxrwx 3 root root 4096 Nov 4 22:35 .. root@aml-s9xx-box:~# uname -a Linux aml-s9xx-box 6.18.60-current-meson64 #1 SMP PREEMPT Fri Oct 30 12:06:41 UTC 2026 aarch64 GNU/LinuxI look up and see some suggest using armbian-install, but this image don't have that.I tried to copy the armbian-install raw file from ophub github, but it failed at the checking for ophub release file step.So how can I install it to eMMC?Thank you for your help. Edited November 4Nov 4 by tyrys
November 7Nov 7 Without logs from the boot, I can't quess at why this is failing. You will need to get and post logs from your failed boot.
November 8Nov 8 Author 12 hours ago, SteeMan said:Without logs from the boot, I can't quess at why this is failing. You will need to get and post logs from your failed boot.I did take a picture of when it boot, please see the attached image.More info: I also compile the new u-boot based on one of the comment on the other thread, in /boot/build-u-boot/readme.txt, I follow that with the s905x-s912.patch uboot 2020.07. Then I reflash the Android firmware using Burning Tool v2. Reflash the armbian img to the sdcard, using the patched uboot. It booted using sdcard. After that I run install-aml.sh, it said "Completed", then I poweroff, remove the sdcard, plug it back on. And this screen show up, its stuck there.And this is the log using armbian-debug (armbianmonitor -u), when I successfully boot with sdcard : https://paste.armbian.com/ojuzarutuhThanks SteeMan Edited November 8Nov 8 by tyrys
November 8Nov 8 Guia_Armbian_eMMC_X96_Max.docxHello,I had the same problem when trying to install Armbian on the eMMC of my X96. I'm not a programmer, but with the help of AI I managed to get it working.I'm sharing the guide where I documented all the steps, in case I need to go through the process again in the future. The guide is in Spanish, but I hope it will be helpful to you.Best regards!
November 11Nov 11 Author On 11/8/2026 at 1:32 AM, SteeMan said:Without logs from the boot, I can't quess at why this is failing. You will need to get and post logs from your failed boot.@SteeMan This is the boot log I got from uartbootlogGXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 163558 BL2 Built : 19:41:49, Jun 20 2016. gxl ge299011 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 2 CPU clk: 1200MHz DDR3 chl: Rank0+1 @ 912MHz - FAIL DDR3 chl: Rank0 @ 912MHz - PASS DQS-corr enabled DDR scramble enabled Rank0: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00014400 Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x000a7e00 NOTICE: BL3-1: v1.0(debug):c813a61 NOTICE: BL3-1: Built : 14:39:44, Jun 16 2016 aml log : bl31 normal boot ! [Image: gxl_v1.1.3137-2517a7a 2016-06-24 11:31:11 xing.xu@droid05] OPS=0x82 46 e4 57 f1 8a ee 6 5d 77 86 84 cf [0.505223 Inits done] secure task start! high task start! low task start! INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-g8d898ad-dirty (Aug 09 2016 - 13:58:51) DRAM: 1 GiB Relocation Offset is: 36ecb000 register usb cfg[0][1] = 0000000037f5f990 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpp: vpp_init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033ecb6b0 aml_priv->desc_buf = 0x0000000033ecd9d0 SDIO Port B: 0, SDIO Port C: 1 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 [mmc_startup] mmc refix success [mmc_init] mmc init success mmc read lba=0x14000, blocks=0x400 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 1g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 0 start dts,buffer=0000000033ed0270,dt_addr=0000000033ed0a70 parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000060000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 get_dtb_struct: Get emmc dtb OK! overide_emmc_partition_table: overide cache [mmc_get_partition_table] skip partition cache. Partition table get from SPL is : name offset size flag =================================================================================== 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 60000000 1 13: data b7c00000 11a400000 4 mmc read lba=0x12000, blocks=0x2 mmc read lba=0x12002, blocks=0x2 mmc_read_partition_tbl: mmc read partition OK! eMMC/TSD partition table have been checked OK! mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=cold_boot hpd_state=0 cvbs performance type = 6, table = 0 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] read emmc dtb Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p212 variant: 1g dtb 0 soc: gxl plat: p212 vari: 1g dtb 1 soc: gxl plat: p212 vari: 2g Find match dtb: 0 Net: dwmac.c9410000 wipe_data=successful wipe_cache=successful upgrade_step=2 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]load fb addr from dts [OSD]failed to get fb addr for logo [OSD]use default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [CANVAS]canvas init [CANVAS]addr=0x3d800000 width=3840, height=2160 amlkey_init() enter! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 get_cpu_id flag_12bit=1 saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc get_in_range <min> <max> - return 0 if current value in the range of current channel InUsbBurn noSof Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 card out emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** reading emmc_autoscript 174 bytes read in 3 ms (56.6 KiB/s) ## Executing script at 01020000 ## Error: "bootfromsd" not defined reading u-boot.emmc 641479 bytes read in 13 ms (47.1 MiB/s) ## Starting application at 0x01000000 ... Edited November 12Nov 12 by tyrys
