parsable Posted January 29, 2018 Share Posted January 29, 2018 Hello again. I am beating my head against the network configuration again and would dearly love some help. I have two orange pi pc boards with static ip's in the 192.168.1. range. They are only connected to each other. They can ping and ssh each other just fine. I am trying to set up nfs shares between them without success. In /etc/exports I have: /home/martin/folder 192.168.1.*(rw,sync,no_subtree_check,nohide) I have "ALL: 192.168.1." in my /etc/hosts.allow. In /etc/fstab I have: 192.168.1.XXX:/home/martin/folder/from_lev /home/lev/folder/to_martin nfs rw,sync,noauto,user,x-systemd.automount 0 0 And vis-versa on the other pi. The folders all exist. I've rebooted, and tried a bunch of other things, but am still stuck. "sudo mount -a" returns without an error, although with that automount in there I'm not sure if it's trying anything. When I attempt to go into /folder/from lev the command line just hangs. A "sudo showmount" command returns "clnt_create: RPC: Program not registered." Google searches bring up a bunch of information about other distros, so I don't know if I have a firewall problem, port problem, services problem. . . Any ideas? Thanks in advance. Link to comment Share on other sites More sharing options...
