8 hours ago8 hr I am using a rather (small value) SBC... but the latest armbian (debian 13 trixie variant) support has been vastly improved compared to past OS images. But the following issue was a surprise, package conflict? armbian-firmware vs. firmware-realtek?My SBC, IndieDroid NOVA... really fast compared to a Pi4 or even Pi5... By the way there appears to be no 'tag' for the IndieDroid NOVA SBC? Can that be added? Since armbian supports it?# fastfetch .. root@schizo `:]x**j-,' ----------- .,+t***********z\<" OS: Armbian 26.11.0-trunk.145 trixie aarch64 ?******************; Host: Indiedroid Nova '*n` .'`^,;;,^`'. ,cc. Kernel: Linux 6.18.64-current-rockchip64 -<. .[l Uptime: 55 mins // ^^ ^^ \\ Packages: 471 (dpkg) !^ ^^ ": Shell: bash 5.2.37 'tt}` !~]rj_ ")t/. Terminal: /dev/pts/0 10.0p2 Debian-7+deb13u4 Itttt?' ~~]rr] `{tttt, CPU: rk3588s (4+4) @ 2.40 GHz \tttttt!""I_]r("""~tttttt1 Memory: 470.39 MiB / 15.34 GiB (3%) '_tttttttttttt)ftttttttttttti. Swap: 0 B / 7.67 GiB (0%) \*ztttttttttttttttttttttttttf**[ Disk (/): 2.51 GiB / 28.93 GiB (9%) - ext4 l**c)tttttttttttttttttttttttt(z**, Disk (/media/samba/Data): 24.00 KiB / 57.03 GiB (0%) - ext4 .z*x.`tttttttttttttttttttttttt.`u*n Disk (/media/samba/Portable 01/Data): 2.03 MiB / 1.79 TiB (0%) - ext4 >` (tttttttttttttttttttttt] "I Disk (/media/samba/Portable 01/Time Shift): 2.03 MiB / 916.14 GiB (0%) - ext4 ,tttttttttttttttttttttt` Disk (/media/samba/Portable 02/Data): 2.03 MiB / 1.79 TiB (0%) - ext4 ./tttttfttttttttfttttt( Disk (/media/samba/Portable 02/Time Shift): 2.03 MiB / 916.14 GiB (0%) - ext4 'I)))(\()(tt))|\()({;' Disk (/var/log): 7.73 MiB / 46.84 MiB (16%) - ext4 .~~~~~~~|)~~~~~~~< Local IP (bridge0): 192.168.1.20/24 '[)))))1|()))))))? Locale: en_US.UTF-8 ",,," ",,,^ When I install firmware-realtek package, this resolves my bluetooth issues. But to try to resolve panthor GPU support it appears I have to install armbian-firmware package.[ 13.077656] panthor fb000000.gpu: Direct firmware load for arm/mali/arch10.8/mali_csffw.bin failed with error -2 [ 13.077663] panthor fb000000.gpu: [drm] ERROR Failed to load firmware image 'mali_csffw.bin' [ 13.077822] panthor fb000000.gpu: probe with driver panthor failed with error -2I am not sure why this packages are in conflict...# apt install armbian-firmware Installing: armbian-firmware REMOVING: firmware-realtek Summary: Upgrading: 0, Installing: 1, Removing: 1, Not Upgrading: 0 Download size: 174 MB Space needed: 525 MB / 28.0 GB availableIs this something the package maintainers need to address? Any help greatly appreciated.The bin file I apparently need is present in the firmware-realtek package...# apt-file search mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch10.10/mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch10.12/mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch10.8/mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch11.8/mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch12.8/mali_csffw.bin firmware-misc-nonfree: /usr/lib/firmware/arm/mali/arch13.8/mali_csffw.binBut I still get the following issue...[ 13.077656] panthor fb000000.gpu: Direct firmware load for arm/mali/arch10.8/mali_csffw.bin failed with error -2 [ 13.077663] panthor fb000000.gpu: [drm] *ERROR* Failed to load firmware image 'mali_csffw.bin' [ 13.077822] panthor fb000000.gpu: probe with driver panthor failed with error -2 Edited 8 hours ago8 hr by Palm Desert Oasis Administrative Access
