1 hour ago1 hr I discovered a device tree issue on the Radxa Dragon Q6A (QCS6490) while developing a Linux gaming distribution using the Armbian kernel.Environment:Board: Radxa Dragon Q6A, 12 GB RAMArmbian 26.11.3 (Ubuntu 26.04)Kernel: 7.3.1-edge-qcs6490The UFS thermal sensor reports abnormally high temperatures, approximately 72°C after a cold boot and over 90°C during gaming, even without a UFS module installed.After correcting the ADC pinctrl configuration to set the corresponding PMIC GPIO2 to high impedance, the reported temperature dropped to approximately 46°C, consistent with the other board temperature sensors.This suggests a missing or incorrect ADC pinctrl configuration in the device tree rather than an actual overheating problem.Could the Armbian maintainers investigate this issue and consider incorporating the device tree correction?I can provide the original and corrected DTB files, device tree differences, and thermal sensor readings if required.
