Skip to content
View in the app
Armbian Community Forums
Orange Pi Zero 3 (4 GB): BL31 PSCI panic on trunk.137, trunk.130 boots on the same SD card
Featured Replies
Following up here after the Armbian build issue was redirected to the forum. On my Orange Pi Zero 3 (Allwinner H618, 4 GiB RAM, AXP313), the published Armbian Community Debian Trixie Minimal image 26.11.0-trunk.137 consistently stops during a cold boot in TF-A BL31. The earlier 26.11.0-trunk.130 image boots on the same board and microSD card.
Same-board, same-card comparison
  • 26.11.0-trunk.137 (6.18.64-current-sunxi64) stops in BL31 before U-Boot proper and Linux. The failing image is from build revision 1ce67c259.
  • 26.11.0-trunk.130 (6.18.63-current-sunxi64) boots, and I was able to log in over SSH.
Both SD-card writes passed a full read-back comparison against their source images.
UART excerpt (115200 8N1)
U-Boot SPL 2026.10_armbian-2026.10-S5508-Pecd5-H5c9e-V0472-Bd800-R448a (Nov 20 2026 - 11:14:25 +0000)
DRAM: 4096 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.14.11(debug):armbian
NOTICE:  BL31: Found U-Boot DTB at 0x4a0bd550, model: OrangePi Zero3
INFO:    PMIC: found AXP313
INFO:    PSCI: CPU suspend is available natively
ERROR:   PSCI: core 1 did not power down
PANIC in EL3.
The error text matches the timeout in sunxi_cpuidle_park_secondaries() in the Armbian downstream TF-A patch, where it waits for the secondary core’s power-clamp status to reach 0xff. The change is in Armbian build commit 3ac70d27. This is a comparison of two published images with multiple changes. I haven’t isolated the patch in a single-change test.
Can anyone with a 4 GiB Orange Pi Zero 3 reproduce this on trunk.137, or point me to a newer prebuilt image with an updated BL31 that I can test?
Original GitHub report (#11549) · Same-card test details
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
