gailu Posted February 1, 2018 Share Posted February 1, 2018 Hi Experts, Setup: Ubuntu Xenial image on Orange Pi Zero Target boots fine and WiFi working stable. If I remove xradio_wlan module (rmmod xradio_wlan) target start rebooting (shutdown followed by reboot) automatically within 2 minutes and no information is captured in syslog to indicate the reason of reboot. I understand that something is dependent on wlan that is causing system to shutdown. I am looking for help to identify what causes shutdown. Can you provide some pointers which log/service should I look at? Thank you in advance Link to comment Share on other sites More sharing options...
guidol Posted February 1, 2018 Share Posted February 1, 2018 37 minutes ago, gailu said: Setup: Ubuntu Xenial image on Orange Pi Zero Target boots fine and WiFi working stable. If I remove xradio_wlan module (rmmod xradio_wlan) target start rebooting (shutdown followed by reboot) automatically within 2 minutes and no information is captured in syslog to indicate the reason of reboot. Which network will you use, when unload the xradio_wlan (which should be the working stable WiFi)? How about to blacklist xradio_wlan in /etc/modprobe.d/blacklist.conf with blacklist xradio_wlan Will you OPi Zero start with a blacklisted xradio_wlan? (do you see the serial log via USB-TTL serial dongle) Link to comment Share on other sites More sharing options...
gailu Posted February 1, 2018 Author Share Posted February 1, 2018 Actually I am facing issue - when my AP is OFF and I boot OPI Zero board boots and automatically shutdown and this cycle continues. If AP is ON then it connects with AP works perfectly and no automatic shutdown happens. To recreate scenario I just unloaded unloaded xradio_wlan module (rmmod xradio_wlan) and I could see the same behaviour that target reboots without doing anything else. My aim is to stop automatic shutdown/reboot when AP is off, so that connect to AP whenever it is switched on. But I am not able to find the reason why the target reboot if WiFi radio is down or configured WiFi AP is not available. One I know the reason I may try to find the workaround Please find the console log below. Ubuntu 16.04.1 LTS orangepizero ttyS0 orangepizero login: root Password: Last login: Thu Feb 1 17:15:00 IST 2018 on ttyS0 Error: Broken packages exist. ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.25 stable Ubuntu 16.04.1 LTS 3.4.113-sun8i System load: 1.50 Up time: 1 min Memory usage: 29 % of 494Mb IP: 192.168.1.12 CPU temp: 32°C Usage of /: 66% of 3.2G /dev/mmcblk0p5 /media/root-rw/data ext4 rw,relatime,data=ordered 0 0 root@orangepizero:~# ifconfig eth0 Link encap:Ethernet HWaddr ee:87:90:c2:da:e5 inet6 addr: fe80::ec87:90ff:fec2:dae5/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:3 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:238 (238.0 B) Interrupt:114 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wlan0 Link encap:Ethernet HWaddr dc:44:6d:e3:d0:72 inet addr:192.168.1.12 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::de44:6dff:fee3:d072/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:86 errors:0 dropped:0 overruns:0 frame:0 TX packets:52 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:9894 (9.8 KB) TX bytes:6852 (6.8 KB) root@orangepizero:~# echo "Everything is fine and WiFi working without any issue" Everything is fine and WiFi working without any issue root@orangepizero:~# rmmod xradio_wlan [ 158.540068] [WSM_WRN] Issue unjoin command(TX). [ 159.470267] [STA_WRN] !!! xradio_remove_interface: vif_id=0 [ 159.560185] xradio wlan power off [ 159.629941] [XRADIO] Remove SDIO card 1 root@orangepizero:~# root@orangepizero:~# date Thu Feb 1 23:23:30 IST 2018 root@orangepizero:~# date Thu Feb 1 23:23:45 IST 2018 root@orangepizero:~# date Thu Feb 1 23:23:48 IST 2018 root@orangepizero:~# date Thu Feb 1 23:23:52 IST 2018 root@orangepizero:~# date Thu Feb 1 23:23:55 IST 2018 root@orangepizero:~# date Thu Feb 1 23:23:59 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:02 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:07 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:11 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:16 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:20 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:29 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:37 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:45 IST 2018 root@orangepizero:~# date Thu Feb 1 23:24:53 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:01 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:06 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:14 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:23 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:31 IST 2018 root@orangepizero:~# date Thu Feb 1 23:25:42 IST 2018 root@orangepizero:~# Stopping Session 1 of user root. Stopping User Manager for UID 0... [ OK ] Stopped target Graphical Interface. [ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch. Stopping Authenticate and Authorize Users to Run Privileged Tasks... [ OK ] Stopped target Multi-User System. Stopping LSB: Starts LIRC daemon.... Stopping LSB: Start/stop sysstat's sadc... Stopping System Logging Service... Stopping OpenBSD Secure Shell server... Stopping Regular background program processing daemon... Stopping LSB: Armbian gathering hardware information... Stopping LSB: Set sysfs variables from /etc/sysfs.conf... Stopping LSB: disk temperature monitoring daemon... [ OK ] Stopped target Login Prompts. Stopping LSB: Advanced IEEE 802.11 management daemon... Stopping Save/Restore Sound Card State... [ OK ] Stopped target Sound Card. Stopping RFID Reader Service... Stopping Serial Getty on ttyS0... [ OK ] Stopped target Timers. [ OK ] Stopped Daily apt activities. [ OK ] Stopped target System Time Synchronized. [ OK ] Stopped Daily Cleanup of Temporary Directories. [ OK ] Stopped Regular background program processing daemon. [ OK ] Stopped System Logging Service. [ OK ] Stopped OpenBSD Secure Shell server. [ OK ] Stopped Authenticate and Authorize Users to Run Privileged Tasks. [ OK ] Stopped RFID Reader Service. [ OK ] Stopped Serial Getty on ttyS0. [ OK ] Stopped User Manager for UID 0. [ OK ] Stopped Session 1 of user root. [ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon. [ OK ] Stopped Save/Restore Sound Card State. [ OK ] Stopped LSB: Armbian gathering hardware information. [ OK ] Stopped LSB: Starts LIRC daemon.. [ OK ] Stopped LSB: Start/stop sysstat's sadc. [ OK ] Stopped LSB: Set sysfs variables from /etc/sysfs.conf. [ OK ] Stopped LSB: disk temperature monitoring daemon. [ OK ] Stopped User Manager for UID 0. Stopping LSB: set CPUFreq kernel parameters... [ OK ] Removed slice User Slice of root. Stopping Login Service... [ OK ] Removed slice system-serial\x2dgetty.slice. Stopping /etc/rc.local Compatibility... Stopping Permit User Sessions... Stopping Access Control Service... [ OK ] Stopped Login Service. [ OK ] Stopped /etc/rc.local Compatibility. [ OK ] Stopped Permit User Sessions. [ OK ] Stopped target Network is Online. [ OK ] Stopped Network Manager Wait Online. [ OK ] Stopped Access Control Service. [ OK ] Stopped LSB: set CPUFreq kernel parameters. Stopping LSB: Load kernel modules needed to enable cpufreq scaling... Stopping MySQL Community Server... [ OK ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling. [ OK ] Stopped target Remote File Systems. [ OK ] Stopped target Remote File Systems (Pre). [ OK ] Stopped MySQL Community Server. [ OK ] Stopped target Network. Stopping Network Manager... Stopping WPA supplicant... [ OK ] Stopped WPA supplicant. [ OK ] Stopped Network Manager. Stopping D-Bus System Message Bus... [ OK ] Stopped D-Bus System Message Bus. [ OK ] Stopped target Basic System. [ OK ] Stopped target Sockets. [ OK ] Closed Syslog Socket. [ OK ] Stopped target Paths. [ OK ] Stopped Forward Password Requests to Wall Directory Watch. [ OK ] Stopped Dispatch Password Requests to Console Directory Watch. [ OK ] Stopped target Slices. [ OK ] Removed slice User and Session Slice. [ OK ] Closed D-Bus System Message Bus Socket. [ OK ] Stopped target System Initialization. Stopping Entropy daemon using the HAVEGE algorithm... [ OK ] Stopped Create Volatile Files and Directories. [ OK ] Stopped target Swap. Deactivating swap /var/swap... Deactivating swap /media/root-rw/data/var/swapfile... [ OK ] Stopped target Encrypted Volumes. [ OK ] Stopped Apply Kernel Variables. [ OK ] Stopped target Local File Systems. Unmounting /var/log... Starting Unattended Upgrades Shutdown... Unmounting /var/log.hdd... Unmounting /run/user/0... Stopping Restore / save the current clock... [ OK ] Stopped Entropy daemon using the HAVEGE algorithm. [ OK ] Deactivated swap /var/swap. [ OK ] Deactivated swap /media/root-rw/data/var/swapfile. [ OK ] Unmounted /var/log. [ OK ] Unmounted /run/user/0. [ OK ] Stopped Restore / save the current clock. [FAILED] Failed unmounting /var/log.hdd. Unmounting /media/root-rw/data... Stopping Load/Save Random Seed... Unmounting /tmp... [ OK ] Started Unattended Upgrades Shutdown. [ OK ] Stopped Load/Save Random Seed. [ OK ] Unmounted /tmp. [ OK ] Unmounted /media/root-rw/data. [ OK ] Reached target Unmount All Filesystems. [ OK ] Stopped target Local File Systems (Pre). [ OK ] Stopped Create Static Device Nodes in /dev. [ OK ] Stopped Remount Root and Kernel File Systems. [ OK ] Reached target Shutdown. Link to comment Share on other sites More sharing options...
guidol Posted February 1, 2018 Share Posted February 1, 2018 40 minutes ago, gailu said: Please find the console log below. Ubuntu 16.04.1 LTS orangepizero ttyS0 orangepizero login: root Password: Last login: Thu Feb 1 17:15:00 IST 2018 on ttyS0Error: Broken packages exist. Welcome to ARMBIAN 5.25 stable Ubuntu 16.04.1 LTS 3.4.113-sun8i You have broken packages & a "old" version of armbian. I have actually on a Zero with legacy-kernel: Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i I would try the following commands: sudo apt-get clean && sudo apt-get update sudo apt-get upgrade if that doesnt work: apt-get install -f or dpkg --configure -a after that maybe xradio_wlan does work better? Link to comment Share on other sites More sharing options...
gailu Posted February 2, 2018 Author Share Posted February 2, 2018 No difference even after upgrade. Ubuntu 16.04.3 LTS orangepizero ttyS0 orangepizero login: root Password: Last login: Fri Feb 2 07:41:04 IST 2018 on ttyS0 ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i System load: 0.91 0.60 0.24 Up time: 2 min Memory usage: 30 % of 494MB IP: 192.168.1.12 CPU temp: 41°C Usage of /: 59% of 3.2G [ 0 security updates available, 2 updates total: apt upgrade ] Last check: 2018-02-02 07:42 [ Menu-driven system configuration (beta): sudo apt update && sudo apt install armbian-config ] /dev/mmcblk0p5 /media/root-rw/data ext4 rw,relatime,data=ordered 0 0 Warning: a reboot is needed to finish resizing the filesystem Please reboot the system as soon as possible root@orangepizero:~# rmmod xradio_wlan [ 322.130074] [WSM_WRN] Issue unjoin command(TX). [ 323.070700] [STA_WRN] !!! xradio_remove_interface: vif_id=0 [ 323.171445] xradio wlan power off [ 323.249236] [XRADIO] Remove SDIO card 1 root@orangepizero:~# root@orangepizero:~# root@orangepizero:~# root@orangepizero:~# date Fri Feb 2 07:48:35 IST 2018 root@orangepizero:~# [ OK ] Stopped target Graphical Interface. [ OK ] Stopped target Multi-User System. Stopping OpenBSD Secure Shell server... Stopping System Logging Service... Stopping Authenticate and Authorize Users to Run Privileged Tasks... Stopping LSB: Start NTP daemon... Stopping Unattended Upgrades Shutdown... [ OK ] Stopped target Sound Card. Stopping User Manager for UID 0... Stopping Session 2 of user root. ... Link to comment Share on other sites More sharing options...
gailu Posted February 2, 2018 Author Share Posted February 2, 2018 This is to update that problem was not with the Armbian image. There was a third party app (that we outsourced to a freelancer). He made a check when networks goes down and does not recover automatically within two minutes it restarted programmatically. Extremely sorry to trouble you. 1 Link to comment Share on other sites More sharing options...
